Battery
Submitted: Tuesday, Nov 04, 2008 at 20:40
Cram
My deep cycle battery has recently carked it, basically it's not holding charge any more. It charges but rapidly goes flat. This battery would only be just two years of age.
I am after a new deep cycle battery but want something that will hopefully last a little longer then this one.
Any ideas??
Thanks in advance.
Cram (aka Marc)
Reply By: Sand Man (SA) - Tuesday, Nov 04, 2008 at 20:57
Cram,
Any battery may have a reduced working life, depending on how it is treated or used. Prolonged deep discharge will reduce the life of a battery. When a battery becomes sulfated, it will result in the symptoms you describe.
A wet cell deep cycle battery shouldn't be taken below 30% charge. (Some people state 50% but this is impractical IMHO)
An AGM battery, whilst being more expensive to buy, will withstand deeper discharge cycles and charge quicker and more fully than a wet cell battery.
Before adding a low voltage discharge protector to my setup, I killed a couple of batteries that were no older than 6 months each by letting them drain down to dead flat. (Below 10.4 volts)
Bill
333658
Follow Up By: Cram - Tuesday, Nov 04, 2008 at 21:00
Thanks Bill, the battery in question is a wet cell and it has no doubt been discharged in the manner you speak.
Can you point me in the right direction in relation to the low voltage discharge protector that you have mentioned.
Marc
601453
Follow Up By: Sand Man (SA) - Tuesday, Nov 04, 2008 at 22:48
Marc,
One solution is the Projecta OPD 500 battery dischange protector costs about $30 and available from Repco, Kmart, etc.
I bought one of these but cut the ciggy plug and socket off them and replaced with a merit style plug and socket which are "vibration proof".
The OPD 500 cuts out at 11.6v which is approx 30% remaining capacity.
Projecta
Derek from ABR also offers a similar unit and it may pay to check with him and confirm what plug/socket he supplis on his unit.
The ABR unit cuts out at 11.2v which is still OK.
ABR
Price is similar but Dereks unit appears to have a better quality plug/socket.
Bill
601476
Follow Up By: Sand Man (SA) - Tuesday, Nov 04, 2008 at 22:52
Hmm,
Let's try ABR link again.
Sidewinder
601477
Reply By: Cram - Tuesday, Nov 04, 2008 at 21:06
Also Bill, can you explain how you install/set these up....
333661
Follow Up By: Sand Man (SA) - Wednesday, Nov 05, 2008 at 07:07
The Low Voltage Cutout is simply installed "inline" between the battery and the fridge or other high current drain device. (At the device end)
In my case, I replaced the standard cigarette style plug and socket with Merit plug and socket which I have standardized on.
You plug the cutout device into the supply socket (from the battery), then plug the fridge into the other end.
The Merit (or Piranha or Hella) plug has a removable collar which allows the plug to connect to a standard ciggy socket, or into the smaller but more robust counterpart if you buy the socket as
A standard ciggy plug/socket has no locking mechanism which allows the plug to vibrate loose over time.
Bill
601503
Follow Up By: Member - Phil G (SA) - Wednesday, Nov 05, 2008 at 10:09
Low Voltage cutouts do draw a small current of their own, so if you leave it hooked up during storage, it will slowly flatten the battery. Of the ones I've owned, the old relay type draw about 30 milliamps, while the transistorised ones were less than 10 milliamps. I haven't measured any of the many newer ones available now.
601526
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Nov 05, 2008 at 18:14
The low voltage cut out from ABR, Jaycar etc also have a max rating of about 10 amps, so you might need one for the fridge, and another for something else.
But
well worth it, saved mt battery too. Get a fair bit more life out of the 2nd battery now.
601570
Follow Up By: oldtrack123 - Wednesday, Nov 05, 2008 at 21:54
Hi 0ldplodder
A simple solution is to use the 10amp rated unit as a contol relay for a much higher rated 12v relay ie one suitable for total load on aux battery.
I believe they are essential for long bat life, bats don't need to be flattened more than a few times to seriously shorten their life.
601609
Reply By: ExplorOz - David & Michelle - Tuesday, Nov 04, 2008 at 21:33
Cram,
We migrated our second battery to a Full River AGM 100Ah battery and have been very happy since. Like you we were going through wet cell batteries every 18 months or so, we changed to the AGM have have had it in service for at over 3 years (from memory). They are more expensive to buy and weigh a lot more but they are maintenance free and work very
well indeed.
I would strong recommend moving to AGM from the wet cell types. There may be better solutions now and I will stand to be corrected if this is the case but I will be added a dual battery to my boat soon and an AGM is on the buy list.
Good luck.
333667
Follow Up By: Cram - Tuesday, Nov 04, 2008 at 21:36
I think you are on the money, as is Bill.
We have two batteries, one in the trailer that is the wet cell and one in the cargo area that is AGM both are similiar age but the wet cell is the one that's given up the ghost.
Thanks for your input.
601458
Follow Up By: Maîneÿ (wa) - Tuesday, Nov 04, 2008 at 21:47
Cram,
I would also check if the Voltage at the Cranking battery and also the Trailer battery are *identical* when the Alternator is running and charging your battery system.
This will tell you if you are loosing any charging Voltage with-in the cabling between the two batteries.
Mainey . . .
601463
Reply By: Member - Phil G (SA) - Tuesday, Nov 04, 2008 at 22:08
"We have two batteries, one in the trailer that is the wet cell and one in the cargo area that is AGM both are similiar age but the wet cell is the one that's given up the ghost. "
Marc,
Wet cell batteries only usually come with a 6 month warranty because they often die prematurely. They die because of the way people use them, and because they are difficult to fully charge (high internal resistance and need higher voltage), especially in a trailer on the end of a very long cable. I'm guessing the wet cell in your trailer was never fully charged.
So next time round, by all means use an AGM - they are easier to charge off your vehicle's alternator. But its an expensive investment, so you need to look after it, and keep it fully charged as much as possible.
You may want to use an Arrid Twin Charge to boost the voltage they receive.
You may want to regularly use a 3 stage charger, so the AGMs are stored fully charged.
When it is recharging off the alternator, the voltage drop is usually significant, and these batteries need more volts than your alternator puts out anyway. Thats why there is a market for devices such as the Arrid Twin Charge which boost voltage to 14.4. Hooking the trailer batteries up to a 3 stage charger when they get home is also worthwhile.
Assuming good wiring and earthing, An AGM in your trailer will recharge better than the wet cell you had. But its still good practice to rcharge it off a good 240V charger when you get home.
333677
Follow Up By: Member - Phil G (SA) - Tuesday, Nov 04, 2008 at 22:09
Sorry to repeat myself - forgot to delete the last 2 paragraphs :-(((
601465
Follow Up By: Member - Roachie (SA) - Wednesday, Nov 05, 2008 at 08:17
I follow the exact same regime that Phil has outlined. I have 2 x 3 stage chargers. One is permanently mounted in the back box on the Patrol and is hooked up to all 3 batteries that the Patrol uses. The other is mounted in the camper and looks after the Ultimate's 2 Supercharge batteries.
Mounted beside each of the 3 stage chargers, I have an Arrid Twin Charge unit that ensures the 3 auxilliary batteries are being charged properly when I'm driving. (the other 2 batteries are permanently joined and are charged by the alternator).
Roachie
601510
Reply By: Sand Man (SA) - Tuesday, Nov 04, 2008 at 22:35
The only negative the AGM batteries have (besides purchase cost) is the weight and footprint. (size)
Before spending money on an AGM battery, confirm the cradle in the vehicle can handle the extra weight and larger footprint, especially the height.
You may find the largest capacity AGM that will fit an after market cradle in an engine bay is about an 80 Ah.
Bill
333683
Follow Up By: Maîneÿ (wa) - Tuesday, Nov 04, 2008 at 22:57
My AGM battery fits in a normal sized black plastic battery box, so without going and actually measuring it I will say it's the same size as a 'normal' Cranker battery.
Image Could Not Be FoundMainey . . .
601478
Reply By: Member - Brenton W (SA) - Tuesday, Nov 04, 2008 at 23:19
Hi Cram
I too had trouble wioth camper battery, i had a 100 amp agm, no one told me not to leave it flat wich i did reulting in it not holding charge once charged, i have since bought a 120 amp deep cycle thumper for the resone it is supose to beable to recieve charge at 25 amp/ hr i have been told ordinary deep cycle batteries have to be charged slow, but when your camping and need power for fridges you need the battery charged as quick as you can hence the larger one and also have a cteck charger that can charge at "25 amp / hr " the dollars spent to keep things working !!!!!!!
333692
Follow Up By: Maîneÿ (wa) - Wednesday, Nov 05, 2008 at 00:12
Brenton,
What model 120ah "Thumper" do you have ??
The "genuine" 75ah BA7 Thumper is ~$800
The Redback branded 120ah Thumper AGM battery is ~$360
But two totally different products
Paul,
I had a Delkor DC27 (calcium DC battery) which was 6 years old when I removed it and replaced it with AGM's, it was still working too
Mainey . . .
601490
Follow Up By: Member - Brenton W (SA) - Wednesday, Nov 05, 2008 at 00:25
I have purchased a redback 120 amp, i hope i recieved the best advise it seems to be working
601492
Follow Up By: Maîneÿ (wa) - Wednesday, Nov 05, 2008 at 00:40
Brenton,
It's just another brand of AGM battery
it's not a genuine "Thumper" battery
yes, if your happy - then it's 'the best advice'
Mainey . . .
601497
Follow Up By: Member - Brenton W (SA) - Wednesday, Nov 05, 2008 at 01:03
As i said i have 130 watt BP solar panel gen set with 2500 cteck charger i hope that does the job alot of money spent tp keep beer cold!!!!!!!!
601500
Reply By: Member - Paul T (VIC) - Wednesday, Nov 05, 2008 at 00:06
I have had a Delkor Calcium battery in the camper trailer for over 5 years.
It really has been quite neglected & has done heaps of Outback kilometres.
333697
Reply By: Member - Jiarna (NT) - Wednesday, Nov 05, 2008 at 01:50
I'm not sure if this is relevant to your situation, but I have found that under-bonnet temperature kills deep cycle batteries. Since installing a sealed gel battery in the cargo area, I have had no further battery hassles. Just have to fully charge it on a 240V charger every month or so when sitting at
home waiting for its next trip.
333704
Follow Up By: Member - Bob V (QLD) - Wednesday, Nov 05, 2008 at 10:36
Jiarna, you are on the money , heat does kill them, Ford taxis on the sunshine coast put the batteries in the boot because of under bonnet temperatures
BobV
601527
Reply By: MrBitchi (QLD) - Wednesday, Nov 05, 2008 at 08:36
Cram, how long did the battery last???
AGM's are all
well and good but VERY expensive. Maybe justifiable if using it full time but for occaisional intermittent use you can't beat a wet cell for value for money.
I use a Trojan DC and it's been running now for just on 5 years..
333715
Follow Up By: MrBitchi (QLD) - Wednesday, Nov 05, 2008 at 11:08
Sorry, just noticed, 2 years. Not very good....
601530
Follow Up By: Cram - Wednesday, Nov 05, 2008 at 18:00
No however, I think I made a couple of mistakes. Firstly I just left in the shed when not in use, perhaps I should have kept in on the CTek battery charger and secondly I ran it dead flat a couple of times.
The other type of battery that is being recommended to me is gel, but these are the same type of price as AGM
601568
Reply By: kiwicol - Wednesday, Nov 05, 2008 at 22:00
Hi Cram, if you know somebody with a smart charger with the pulsating charge, try that as you will find that if you have been charging the battery solely from the vehicle alternator, you will find that it would not have been fully charged to total reserve capacity of the battery, as a standard alt will not charge any battery to full reserve capacity of the particular type or design. You will find many people on this site disagree with these remarks, but if you try the smart charger on what you think is a stuffed battery and then put it back in service, you may save your self a lot of dollars over many replacement batterys. If you find this solves the problem the money you would spend on a new battery could be spent on a smart charger, and therefore prolonging the life of other vehicle batterys you may have. Col
333838
Follow Up By: Cram - Thursday, Nov 06, 2008 at 16:57
Hi Col, I have a CTEK charger and had the charger with me when I was away and charged the battery. It charges up ok but loses the voltage very quickly.
The mistake I have made in all of this is not caring for the battery sufficiently in the early days. So its any a costly lesson. I found the receipt for the battery in question last night and I purchased it in September 2006. So I got two years out of it.
601720
