EO shop
Submitted: Thursday, May 28, 2009 at 21:56
Member - Murray R (VIC)
Is anyone having trouble opening the EO
shop tab, it just comes up with internet explorer needs to close.Click send report button and it closes the site.
Murray
Reply By: Member - Fred B (NT) - Thursday, May 28, 2009 at 22:08
Hi Murray,
No... I placed anorder tonight... no problems.
367262
Reply By: Member - Dunworkin (WA) - Thursday, May 28, 2009 at 22:19
Yep Murray, me too, just went into buy and the error came up.
Will have to go in later.
Deanna
367265
Follow Up By: ExplorOz - David & Michelle - Thursday, May 28, 2009 at 22:42
Deanna,
As a
test try
clearing your temp Internet files and see what happens and then maybe try
clearing your cookies. There is a cookie that holds your
shopping cart and this may be corrupt.
So please try these two things and report back if you can it may help someone else and if you can do these two thing separately and
test it will help me know where to look to try to solve any problem.
David
634972
Follow Up By: Member - Dunworkin (WA) - Friday, May 29, 2009 at 01:06
Hi David, thanks for your reply, I did what you said and still the same, tried another computer and still can't get in. Will turn in for the night and see what I can find tomorrow.
634987
Reply By: ExplorOz - David & Michelle - Thursday, May 28, 2009 at 22:41
Murray this is most strange - we have had over 100 orders today so it does not effect everyone. I have had one other person email me earlier with the same issue however I cannot fault the system.
As a
test try
David
367272
Follow Up By: ExplorOz - David & Michelle - Thursday, May 28, 2009 at 22:50
I have just written a mod that will clear out the cookie if there is an failure of the cookie system. I will need to install this update and compile the site. There are too many users on right now so will do it in an hour or so. If you could try the above tests first this would help me know however if you do it tomorrow it should also work. Let me know either way.
David
634977
Follow Up By: ExplorOz - David & Michelle - Friday, May 29, 2009 at 01:03
Mods installed please try again and let me know what happens.
Thanks David
634986
Follow Up By: Member - Dunworkin (WA) - Friday, May 29, 2009 at 11:52
Hi David, I have tried again this morning and I'm still not able to get into the
Shop, all other
places are OK. As mentioned last night I did what you suggested but still no joy. Not sure if it is my system but I tried to get in on Bevan's laptop but still no joy.
Deanna
635042
Follow Up By: ExplorOz - David & Michelle - Friday, May 29, 2009 at 12:02
Deanna,
Can you try going into
places for me also as this will eliminate the mapping engine - and also try this link which will take you to a specific
shop item and eliminate the
shop index page -
Link to Books for test.
Thanks for helping out I would like to solve this however we have had over 200 orders since the updates on Wednesday so it is not a problem for everyone.
PS: What Internet Security product are you using - this may also be causing a problem.
David
635044
Follow Up By: Member - Dunworkin (WA) - Friday, May 29, 2009 at 12:16
David
I went into
Places and tried going into
Shop from there, (hope that is what you meant) but still came up with the error. (The error is the usual microsoft error which tells you to 'send or don't send' at the end.
I am not very computer savvy so could be a problem here. Am I still the only one that is having the problem.
We are using AVG Internet Security and have done for a number of years.
Thanks for your help.
Deanna
635047
Follow Up By: Member - Donks1 (NSW) - Friday, May 29, 2009 at 13:13
G'day David
I have deleted Temp files & cookies, and can access the
shop through your link above, but not direct from the "tag menus " at the top of screen.
Donks1
635058
Follow Up By: Member - Dunworkin (WA) - Friday, May 29, 2009 at 13:30
David,
As with
Donks1 above I have been able to access the
shop from your link but still not able through the menu.
Deanna
635062
Follow Up By: ExplorOz - David & Michelle - Friday, May 29, 2009 at 20:10
Hi all - can yo please try the
shop home for me again - I think the problem is somewhere in the mapping system but where I am not sure. Anyway please have a try and let me know what happens?
Also can you tell me if
places works (ie: you get the map and can click on things on that map). Thanks again and sorry about the errors.
David
635119
Follow Up By: Member - Dunworkin (WA) - Friday, May 29, 2009 at 21:10
David,
Have just tried '
Places' and the
places on the map works fine, unfortunately the
shop is still not working, it appears that it is only that area (well for me anyway) that I can't get into.
Hope that helps
Deanna
635138
Follow Up By: Member - Dunworkin (WA) - Saturday, May 30, 2009 at 23:22
Hi David, sorry to bother you again with this but I am still having problems getting into the '
Shop'
I've been trying for the past couple of days to renew my
membership but unable to get in there. Is it just me or are others having problems as well?
Deanna
635318
