AnswerID: 386055 Submitted: Tuesday, Oct 06, 2009 at 20:39
Sand Man (SA)
replied:
I also have a Holden Colorado Diesel and didn't even bother to research a second battery in the engine bay. There is just not enough room.
My solution was a "flyer" from
ABR, who advertises on this site.
The flyer has an isolator incorporated inside the battery box and comes complete with the correct cable to run into the engine compartment to connect to the battery.
I ran the cable along the chassis and entered the tub through the dual walls behind the fuel filler. Simply a matter of removing the plastic section in the wheel arch to gain access between the inner and outer steel liners and drilling a hole through the inner one. I terminated the cable with an Anderson connector and use a patch lead to complete the connection.
The other Anderson connector in the photos is for connection of a Thumper I also have.
Flyer installation
Flyer installation
 Click Image to Enlarge |
| HooRoo !
I'm diagonally parked in a parallel Universe! |
Reply 6 of 10
