EPIRB Feedback
Submitted: Sunday, Oct 25, 2009 at 20:15
ThreadID: 73298 Views:4615 Replies:5 FollowUps:6
good information, now where do I get a unit that suits my 4wd and kayaking as well as hiking adventures
Reply By: Member - Sigmund (VIC) - Sunday, Oct 25, 2009 at 20:23
GPSOz or marine supply places.
The odd one comes up on Ebay but make sure it's the current frequency, 407mHz IIRC.
Mine had to suit outback trips as well as XC ski touring; got the GME job with inbuilt GPS.
AnswerID: 388684
Follow Up By: Stu & "Bob" - Sunday, Oct 25, 2009 at 22:38
I thought that the new digital units were 406MHz??
FollowupID: 656401
Reply By: Member - Stephen L (Clare SA) - Sunday, Oct 25, 2009 at 20:29
Hi Jack
I have the GME MT410G GPS equipped PLB for the same reasons as you. If you have to set the unit off, it gives the search authorities your location at a starting point of less than 45 metres. Once you buy a unit, make sure that you register it with the Government Authorities.
AnswerID: 388687
Follow Up By: Sand Man (SA) - Sunday, Oct 25, 2009 at 20:51
Yep, me too!
Bill.
Bill
FollowupID: 656376
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Oct 25, 2009 at 21:40
Hi Bill
Your new bus looks good, now you will have to take it bush, to run it in and put a few of those tell tale bush scratches on it. LOL
FollowupID: 656386
Reply By: PatrolBen - Monday, Oct 26, 2009 at 00:20
Just be aware that in QLD (I know for sure) that the MT410 and the MT410G are not acceptable for use in boats going into Beyond Partially Smooth waters.
I know you said kayaking, but not many stores will tell you this.
Northside Marine in brisbane has them for $549
AnswerID: 388714
Follow Up By: Sand Man (SA) - Monday, Oct 26, 2009 at 07:33
The reason for this is not because PLB's (Personal Locator Beacons won't work, but because boating regulations call for an automatically activated EPIRB when immersed in water, must operate for a minimum of 48 hours and have a lanyard to secure it to a floating object.
Regulations vary from State to State but there is no rule against not having both types for boating purposes.
(Extract)
Types of distress beacons
* EPIRBs used in ships and boats are designed to float in the water to optimise the signal to the satellite. An EPIRB is required to operate for a minimum of 48 hours continuously once activated. It has a lanyard used to secure it to something that is not going to sink so that it can float free.
* Personal locator beacons are designed for personal use in both the land and marine environment. Personal locator beacons are required to operate for a minimum of 24 hours once activated.
Bill.
Bill
FollowupID: 656423
Follow Up By: Shaker - Monday, Oct 26, 2009 at 17:44
QUOTE "because boating regulations call for an automatically activated EPIRB when immersed in water,"
That is incorrect.
FollowupID: 656504
Follow Up By: Sand Man (SA) - Monday, Oct 26, 2009 at 18:58
Shaker,
Yes mate, if you wish to be pedantic, I misquoted that particular point.
However, I subsequently pasted an extract from AMSA which better defined requirements.
Bill.
Bill
FollowupID: 656518
Reply By: Member - Graham H (QLD) - Monday, Oct 26, 2009 at 00:47
DONT buy one from am overseas seller as I have read they are not registerable other than in the country of origin.
In other words buy from USA it cant be registered here.
AnswerID: 388715
Reply By: Member - Jack & Lorraine B (QL - Monday, Oct 26, 2009 at 07:21
Thanks very much for the replies!
Yes it is a trap if you can't register them in Australia.
That GME MY410g seems to be popular.
I had a look at Johnny Appleseeds website. there is a deal going there.
You even get a light with it.
AnswerID: 388725
