Cut out switch for 12v Batteries
Submitted: Tuesday, Nov 24, 2009 at 09:13
Grass Parrot
I have deep cycle battery in the rear of my vehicle with my fridge hooked up to it. i have a bad habit of letting the fridge run the battery flat. This in turn
ruins the battery over time. Is there a device that will cut the power from the battery when it drops to a certain voltage? If there is such a thing what voltage should it be set at?
Reply By: anglepole - Tuesday, Nov 24, 2009 at 09:44
You can buy a "make up kit" from Dick Smith for a low voltage cut out, set it to what voltage you wish it to cut out.
You also try Jaycar.
392410
Reply By: chisel - Tuesday, Nov 24, 2009 at 11:12
Derek (ABR/Sidewinder) sells one
http://www.sidewinder.com.au/page90a.html
392423
Follow Up By: Grass Parrot - Tuesday, Nov 24, 2009 at 11:27
Chisel,
Thanks for that. Thats what I'm looking for and have already got a merit plug setup between fridge and battery so this should be able to slot inbetween.
Parrot.
660362
Reply By: Rangiephil - Tuesday, Nov 24, 2009 at 11:24
Projecta have one that I bought from Kmart about 10 years ago for about $65.
Works really
well still with my 40 litre Engel .
Be aware that Engel do not have a big start up load like Danfoss compressor fridges, so if you do not have an Engel the cutout may work prematurely as the voltage drops low on startup.
Regards Philip A
392425
Follow Up By: Sand Man (SA) - Tuesday, Nov 24, 2009 at 18:39
The Projecta ones cost about $30 but Derek's is even cheaper.
He had a special going that I couldn't resist, selling them for $15 but his normal price is quite cheap as
Bill.
660421
Reply By: Member - reggy 2 (VIC) - Tuesday, Nov 24, 2009 at 21:44
Were abouts are you i have one i took out of my caravan it kept putting me in the dark it shut down all the lights in the van when the battery went below 10.5 volts
cheers reggy2
392495
Follow Up By: Member - Mike DID - Tuesday, Nov 24, 2009 at 22:26
I'm sure your batteries wish a worse punishment on you, if you regularly discharge them to 10.5 - in fact they may run away from real soon.
660447
Follow Up By: Who was that again? (Vic) - Tuesday, Nov 24, 2009 at 23:14
New set of batteries ordered Reggy? It can happen really quickly as Mike says.
660453
Follow Up By: Grass Parrot - Thursday, Nov 26, 2009 at 17:22
Im in the Riverland - SA. Sorry not to reply sooner but I have been away working for a couple of days.
660702
