Keeping water clean in water tank
Submitted: Wednesday, Aug 11, 2010 at 13:22
Rosy
Hi We have a tank to store
water under our camper. When we are not using the camper should we keep the tank as empty as possible or can we leave
water in it. Should we use any sort of purifier in the tank either while storing it or when on the road in case it gets mildew or some such.
Thanks for your help.
Rosy
Reply By: Member - Mark G Gulmarrad - Wednesday, Aug 11, 2010 at 13:25
Rosy
when we arn't using our
water tank i drain it completly and leave the filler open so air can get into it and keep the tank dry inside.never had any problems with the tank when i fill it next time.
cheers.
426942
Follow Up By: Member - Myles F (QLD) - Thursday, Aug 12, 2010 at 20:20
G’day Mark, G’day Rosy,
I do exactly the opposite. I fill it to the brim when I get
home…. No air…. No light…. = No fungi…. And I don’t have to fill before I leave..... Makes for a quick get away. hehehe
Mark… have you been away since last we spoke?
Myles.
697668
Reply By: briancc - Wednesday, Aug 11, 2010 at 14:10
We've had our camper trailer with 40 L tank under, for 17 years. I just fill it up before we go away (hopefully a few times a year). I think I may have cleaned it out once in that time, just because it was out for another reason. The
water in it appears OK, doesn't smell or taste funny, no floaties. I don't do anything special, our
water doesn't have a use by date, it's great!
426947
Reply By: CJ - Wednesday, Aug 11, 2010 at 15:47
We do the opposite.
1) When returning from a trip, I drain all the
water.
2) If during the trip we used non-tapwater (read non-chlorinated) then we fill up and drain again to clean out.
3) We then fill the tank to the brim leaving no air.
My theory is that the tapwater contains some chlorination and is better than leaving it with O2.
An emptied tank will always have a little
water in it as it can never be completely drained; even dampness, when left, can then lead to mould.
My theory anyway, Never had a problem
Cheers, CJ
426953
Reply By: Notso - Wednesday, Aug 11, 2010 at 15:50
The thing with
water tanks is that they are opaque and don't allow light to get to the
water, this generally prevents anything like algae etc from growing, although I hear there are a few types that grow in the dark.
If the
water is clean potable
water when you put it in it should stay that way. I always empty and refill my tanks before I head off on a trip.
I fill with whatever
water is available wherever we travel. Some is pretty smelly and hard, but we've never had any problems with gross contamination of the tank.
If you do notice lingering smells, you can try Bi carb soda to make it smell nice again, or if it's really bad about 250 mils household bleach in a full tank and let it soak overnight before draining it and flushing it out
426954
Reply By: Motherhen - Wednesday, Aug 11, 2010 at 16:44
Hi Rosy
Unless the
water tank is clear and the sunlight can readily shine on it, you can leave the
water in the tank for years. We do (after all, the rain just tops up the tank at
home and can stay for years - or could in the good old days when it rained enough). We don't put
water into the caravan tanks unless it passes the 'cup of tea taste
test', and if need be, use
water direct from a bucket if it is not good enough for our tanks. We have never needed to bleach our tanks or purify the
water. We do not have a fancy filter for filling, but just use a food grade hose. A couple of times we have been caught with
water that didn't taste good, and using the
water and refilling was sufficient.
426960
Reply By: Rosy - Thursday, Aug 12, 2010 at 09:54
Thanks very much to everyone for their advice. I would say we will probably just keep it full of
water from home while we are not using the camper. Didnt even think of the chlorine from home. That should keep it pure. We always fill it with potable
water while away and have run out a couple of times but of course there is always some left in the tank.
Cheers Rosy
427007
Reply By: Polaris - Thursday, Aug 12, 2010 at 10:36
Provided the tank and all associated plumbing is not clear, then you can leave the
water in the tank and just top up for the next trip.
Algae will only grow in the presence of light. If you happen to have any clear (food grade) plumbing - just lag it with loom tube and zip ties to prevent any light.
Water is a very precious commodity - don't waste it by simply draining and dumping.
427011
Follow Up By: CJ - Thursday, Aug 12, 2010 at 11:55
Draining the tank goes straight to the garden bed adjacent or even
the pool. No waste in draing a tank once a month (often once in 6 months as we have that damn day job!)
697603
