Is my Vacuum Saver good enough
Submitted: Friday, Aug 20, 2010 at 15:20
Member - Tony W (WA)
We decided to purchase a vacuum saver machine from ebay after hearing a lot of people purchasing good ones from there.
We are looking at sealing the meat that we take on trips so only using the fridge.
Im not sure though if the vacuum is good enough to do the job properly though
I just bought some deli ham and wanted to split it into smaller packs.
Can anyone with a good machine tell me if you are still able to squish the meat between your fingers after vacuum sealing and if you are able to pull the 2 sides of the bag apart. I know it wouldnt be as good a pack as the butchers but is it normal to be able to do that?
To me i have this sinking feeling that it should be a much tighter pack as im worried about meat going off if its not sealed
well enough. The other 2 packs i just did, the seal had melted the bags which were supplied with the machine.
I hope i havent wasted $68.
Did think about the sunbeam ones, are they any better. The one we saw at the camping show in
perth was really good but expensive.
Any help would be very appreciated
Reply By: Member - John and Val - Friday, Aug 20, 2010 at 16:39
Tony,
You might need to practice a bit to get it right. Can you see any air bubbles in the bag? If so you haven't got all the air out. We have an eBay machine and bags and it/they work fine, but we did have to experiment a bit at first.
Val
| J and V
- Albert Einstein
427865
Reply By: Member - Trevor H (SA) - Friday, Aug 20, 2010 at 17:30
Hi Tony
The small units (non commercial) are great for when you are away and want to pack meats purchased while on the road.
When you start out get the meat from a butcher and pack it in small meal size bags (most butchers will pack it free for you) the use the small unit while away.
The small unit will extent the life by about 14 days in the fridge provided the seal does not let go.
Follow the instructions and like the first reply said practice before you go. the bag quality also plays a big part of the keeping ability. go the stronger bags for off road use, the cheaper bags for hi way touring.
If the seal goes look at the following before eating.
Cooked meats
- any sign of slippery moisture (bacterial is slippery to the touch)
- any un pleasant odour when you open the bag.
- discolouration (ham ect should colour up when it is open this is the cure working with the air. if this reaction does not happen then it is most likely the preserving action of the cure has been used up and the seal has already gone)
- Vacuum sealing will extract the moisture from the meat so expect some moisture.
Red meat
- don't pack anything with bone and expect the seal to keep (even from the butcher)
again expect some moisture when you open the bag
The meat should;d then bloom
the will be some unpleasant odour (depending on how long it has been packed) this should "gas off" or dissipate once removed from the bag and allowed to breath.
If this odour is very strong and does not dissipates then feel the surface of the cut again bacteria is slippery so the more slimy the surface the stronger the chance of it being off.
Press the meat if there feels like if has gas trapped in it then do not use it but if it feels mildly slippery and the colour has come back red then it should be good.
The absolute final
check is give it to your dog if he berried it then it is ok if he eats it straight away then it is most likely off and already smells like he has berried for a week.
please remember though it still needs to be kept as cold as possible.
Trevor
(Self proclaimed meatoligist and a legend in my own lunch box)
427867
Reply By: hazo - Friday, Aug 20, 2010 at 18:18
We bought the el cheapo ebay one and was never happy with the results.
We now have an Orvid Eco sealer (made in Italy, they manufacture commercial seal & vacs) and it is just so much better.
When meat or fish is vacced and sealed correctly the pack is almost "rigid".
I tried to vac some frozen doughnuts and it squashed them!
I have eaten fish recently that I caught last year and vac bagged and frozen, and it was perfect.
I feel its the old adage "you gets what you pay for".
427874
Follow Up By: Member - The Bushwhackers -NSW - Friday, Aug 20, 2010 at 21:45
Hi Hazo
I agree that you get what you pay for, but with correct use (and plenty of practice) Our 'Ebay' vacuum sealer does exactly as you describe yours doing.
Maybe lucky :))
Cheers, Dave
698587
Reply By: i'machocoholic - Friday, Aug 20, 2010 at 18:38
Hi Tony,
After reading previous threads on this topic, I bit the bullet and bought one off of ebay about 4 weeks ago. It's brilliant!!! I first experimented with a handful of almonds and it did an excellent job, so then got carried away and practiced everything else. The almonds I sealed are as stiff as a board and can't move they're in that tight. I have recently bought a bucket load of meat and chicken, freezed the lot, and now vacuum sealed the lot and returned them to the freezer. I haven't got to the point to pulling it out the freezer yet to defrost so that will need to be next.
Also done some cheese and salami, again they're in as tight as tight. No movement whatsoever.
The unit came with a couple of rolls for bags, but I have since bought extra bags and a set of 3 cannisters off ebay too. All work a treat.
427877
Follow Up By: i'machocoholic - Friday, Aug 20, 2010 at 19:18
I tried to add a picture so I could show you the one I had but it didn't work. If you can let me know the one you have and I'll be able to see if it's the same as
mine - the one I have has a storage area on the machine for the bag roll and a bag cutter.
698555
Reply By: Member - Duncan W (WA) - Friday, Aug 20, 2010 at 19:44
Tony because the meat is soft it will still feel soft. What you may of done is sucked some moisture through the seal and thus it isn't 100% sealed. I usually do a double row of seal to be safe.
427881
Reply By: BuggerBoggedAgain - Friday, Aug 20, 2010 at 19:53
When I was at the Wauhope Caravan show last week, the spruiker said not $400 not $350 but a show special just $299.00, boy, after reading and learning from this site, it just goes to show you,specials ain't specials, sometimes.
Then I read the post about the Sunbeam for $70.00, unbelievable what some ppl pay for stuff.
Should always
check here first before parting with ones monies.
427883
Reply By: Member - Bruce T (SA) - Friday, Aug 20, 2010 at 20:58
Hi Tony,
We have one of the really early ones. It is in fact badged as a Sunbeam these days. Ours is called a Food Saver. We use it every time we go away and it is just brilliant.
We always have a freezer full of meat and we take out what we want, don't thaw it and vacuum pack it. We have had meat packed like this and used
well over 8 weeks after we left
home.
It is recommended that sausages and mince are frozen before packing. We also use glad go between to wrap sausages, mince etc and have never had a problem.
We keep it in our Engel.
We wouldn't be without it; just fantastic.
Di
427888
Reply By: Member - Prickle (SA) - Friday, Aug 20, 2010 at 21:18
Tony,
Hint - freeze everything before you vac pack it.
If the unit is working properly there will be no air inside and you will not be able to pull the plastic away from the food.
We might do, say a curry, put it in a decor type container (which we know is enough for the two of us), freeze it, then vac it.
Our experience for what it is worth.
427889
Reply By: Member - Tony W (WA) - Friday, Aug 20, 2010 at 21:46
Thank you to all whom has replied. Some excellent tips &
feedback, much appreciated. The Cryvac Machine we have purchased is not even sucking out the air anymore (Lasted 1 day), the ol saying is, you get what you pay for. So looks like we are now in the market for a more better quality cryvac machine. Cheers to all Tony
427890
Follow Up By: Outa Bounds - Friday, Aug 20, 2010 at 22:30
That's a real shame to hear!
I also brought a vac seal machine off ebay, thought it was a good idea for camping. It did ok with the use it had at
home (never actually got around to using it much at all for camping). But in the end I wasn't entirely happy with it and I don't think I would have the confidence to use it for meat etc that we would have to rely on whilst camping.
In the end since it was still working perfectly fine I gave it away to the local Lions Auction, hopefully someone else gets use out of it.
You certainly do get what you pay for, but at the same time it depends on your usage doesn't it? For example not everyone needs to buy the top of the line off road camper trailer if they only go a few hundred clicks down the road and
camp for a week during the school holidays. I'd say the ebay ones might work reasonably
well for certain things, but it's ebay there is bound to be some cheap and nasty products there as
well as some diamonds in disguise! Pot luck sometimes I guess.
698596
Follow Up By: Sand Man (SA) - Saturday, Aug 21, 2010 at 13:43
Tony,
Before you throw it away, just ensure that you are not covering the vacuum hole. The edge of the plastic must sit below the hole.
I originally couldn't justify $300 of so to try out a vacuum sealing machine.
Eventually noticed one advertised on Deals Direct.
It is a "made in china" device and cost $69.95 from memory.
It is called a "Eurolab Vacuum Sealer" and has worked extremely
well for oh three years or so now.
I figured for $70.00 it was "worth the rist".
Still laughing at the "deal".
It is still advertised although currently shown out of stock.
Deals Direct
So you don't need to buy a Rolls Royce when a Ford Falcon will do the job.
Bill.
698629
Follow Up By: OREJAP - Sunday, Aug 22, 2010 at 10:11
As per what Bill has said, you may have wet bags on the wrong ones or just not doing it properly. We bought a $100 unit off Evil Bay and the cutter on the machine wasn't any good contacted the supplier in
Ballarat & what great service he sent another without hesitation.
698692
Reply By: Mike DiD - Sunday, Aug 22, 2010 at 18:31
Bought a $99 one off ALDI years ago - Excellent.
428049
