Protect 3rd battery
Submitted: Monday, Jul 18, 2011 at 20:08
LBGAME
Hi All
This is my first post and i hope this hasen't been covered to death and i haven't noticed. Initially i saw the setup on this site and others on how to set up the battery's so i went with isolator under bonnet to a 75A/H Thumper in the car and a Anderson to the rear of the car. Now i'm in the process of connecting the car wiring to the Battery in the van which is connected to a C-tek 240v charger at this point.
Now, my problem is this. I have been told not to run the battery empty too often and on this site it said to install a meter to monitor the battery.
Is there a way / gadget that cuts power once battery reaches 10.5 volt?
Cheers Frank
Reply By: ABR - SIDEWINDER - Monday, Jul 18, 2011 at 20:33
Frank
You are a bit hard to follow but it sounds like you need a battery protector.
These devices are rated according to current.
We only stock 11.3V cut out 10A units at the moment but will have 60A units available in about 3 weeks that are fully adjustable.
Derek from ABR
460318
Follow Up By: ABR - SIDEWINDER - Monday, Jul 18, 2011 at 20:40
Image Could Not Be FoundSpecs for the SBP60A
733979
Reply By: Mark C - Monday, Jul 18, 2011 at 20:34
Jaycar have them.
460319
Follow Up By: Mark C - Monday, Jul 18, 2011 at 20:36
Sorry Dereks post was not up when I submitted
mine.
733978
Follow Up By: ABR - SIDEWINDER - Monday, Jul 18, 2011 at 20:42
No problem, we have nothing against Jaycar, in-fact we share many similar products and suppliers.
733980
Reply By: Member Al (Sunshine Coast) - Monday, Jul 18, 2011 at 23:53
Hi Frank, 10.5 volts is a bit low to discharge a battery to, even a "deep cycle" type. 11.5v is a better figure if you care about your batteries health. If you are finding it reaching 11.5v regularly it would be better to increase battery capacity by adding another in parallel, but still use a low-voltage cutout device.
460324
Reply By: Sand Man (SA) - Tuesday, Jul 19, 2011 at 07:19
Frank,
To elaborate on Al's comment a little, 10.5 is almost completely flat. A battery should not be drained down this low too often or it will become sulfated and rendered useless.
Most battery protection devices are set at around 11.6 volts or thereabouts, which is around 70% drained.
460330
Reply By: LBGAME - Tuesday, Jul 19, 2011 at 19:14
Hi Guys
Thanks for all the help, that's what i'm after. Derek, on your website i can't find that model, only the plug in type. Would you be able to post a link if it's no trouble?
Also would like to know if your unit has the delay function of these one's:
http://www.snaptec.com.au/battery-low-voltage-disconnect.htmlhttp://www.12volt.com.au/
Thanks again, Frank.
460364
Follow Up By: ABR - SIDEWINDER - Wednesday, Jul 20, 2011 at 08:03
Hi Frank
Email me and I will send you the instruction manual and data sheet, they will be available in 3 weeks.
5 to 10 second start up delay yes.
Derek
734067
