Connecting Caravan to Household power
Submitted: Tuesday, Nov 22, 2011 at 10:07
ThreadID: 90227 Views:21747 Replies:11 FollowUps:31
Hello people,
we are about to acquire a new Jayco poptop caravan. What I would like to know is I beleive you can not simply connect the van to the mains supply of the house? If not what do I need so I can and is this the same at powered sites at caravan sites?
Reply By: Rangiephil - Tuesday, Nov 22, 2011 at 10:22
It is the law that you must have a 15amp lead and just about all cravan parks have the correct socket in their power poles. You buy a 15 amp lead from Bunnings or elsewhere and it has the correct plugs.
The only difference is that the earth prong on the plug is wider than a normal 10 amp houshold plug. Some naughty people file down the 15 amp earth prong on their 15 amp lead and stick it in their houshold plug, or you could have a 15amp socket installed at home.
Theoretically you can be fined for having a filed down earth prong, but in all my travels I have never been asked.
Regards Philip A
AnswerID: 470617
Reply By: LeighW - Tuesday, Nov 22, 2011 at 10:24
A caravan requires a 15A power outlet, your normal house sockets are 10A and have a different size earth pin to your van to stop you plugging your vans extension lead into your house outlet.
1/ Therefore you have two options, get a 15A outlet installed at your house to plug the van into.
2/ If you know the van won't draw more than 10A ie then just make up an extension lead with a 10 plug on one end and a 15A socket on the other, not legal but a lot of people do this. Note though if your van has an airconditioner or electric oven you'll most likely trip the circuit breaker on the house circuit if you turn them on.
LeighW
AnswerID: 470618
Follow Up By: oldtrack123 - Tuesday, Nov 22, 2011 at 12:12
Re"2/ If you know the van won't draw more than 10A ie then just make up an extension lead with a 10 plug on one end and a 15A socket on the other, not legal but a lot of people do this. Note though if your van has an airconditioner or electric oven you'll most likely trip the circuit breaker on the house circuit if you turn them on""
No
WHAT is MOST in fact ALMOST CERTAIN, likely is the 10amp outlet will overheat due to IT being overloaded
The result, possible fire, result insurance void due to using an illegal non approved lead
DO it right safegaurd your self,& your home
FollowupID: 745127
Follow Up By: oldtrack123 - Tuesday, Nov 22, 2011 at 12:15
Cannot edit so an extra
The house circuit breaker will be either 16 or 20amp it is very unlikely to trip unless other high consumption appliances are being used onTHAT circuit AT THAT TIME
FollowupID: 745128
Follow Up By: Bonz (Vic) - Wednesday, Nov 23, 2011 at 21:49
Hi Pete,
Why would the outlet overheat? I assume its 2.5mm2 wirting rated at 28a (from what i recall of AS3000) and the 10A and 15A GPO's only differ in the size of the erath pin hole and hardware behind it, the active and neutral on the GPO's are identical?
FollowupID: 745265
Follow Up By: Dust-Devil - Thursday, Nov 24, 2011 at 02:53
Bonz
I concur with the general rationale you have applied above and wish to ask the following using your stated '2.5mm2 wiring rated at 28a' for a 15A lead and plugs.
(a) 28A x 240V = 6720watts (Rated maximum power draw on subject lead)
(b) If the power draw increases above the aforementioned maxim rate this is when the whole shebang starts to heat up.
(c) (b) above is the point where a correctly rated Fuse, Circuit breaker etc blows/trips telling you that you have breached the safety limit of that circuit.
An example of this is the kitchen of our house:- Should we have the vacuum cleaner, microwave and toaster going at the same time using a particular combination of the zillion power points available, then bang! a one of the 16A circuit breakers in the switch box trips.
Now as these are 10A plugs going into 10A sockets/outlets or GPO's that are connected to 2.5mm2 wiring, according to what Pete is saying, they should in fact be hot.
I have immediately checked the leads and plugs on these three appliances a number of times for any signs of heat and all have been as cold as, which I have always attributed to the circuit breaker doing its job.
So as far as I can see, the only purpose for the use of and incorporation of that big mother of an earth pin in the 15A plugs and sockets, is a design standard initiated by authorities to ensure that manufacturers make 15A leads with 2.5mm2 wiring in them and with plugs and sockets that will only interface with 2.5mm2 wiring supplies.
Would this be a reasonable deduction.
DD
PS
(1) Just so you aware, now that I have identified the three offending Socket Outlets in the kitchen area, I desist from using same simultaneously.
(2) For you 'all things electrical experts' I came across this little gem.
General Purpose Outlet - It is an electrical term.
The definition for GPO in the AS3000 – Australian Standard for Wiring Rules is "three pin flat pin 10 amp socket outlet" or power point as commonly known. But now There is no GPO. the definition was removed from the 2000 edition of the wiring rules, those power points are now defined as Socket Outlets.
They are apparently known as Socket Outlets these days dudes.
FollowupID: 745293
Follow Up By: oldtrack123 - Thursday, Nov 24, 2011 at 11:14
Hi Bonz
Re :"Bonz (Vic) posted:
Hi Pete,
Why would the outlet overheat? I assume its 2.5mm2 wirting rated at 28a (from what i recall of AS3000) and the 10A and 15A GPO's only differ in the size of the erath pin hole and hardware behind it, the active and neutral on the GPO's are identical?"end quote]
Perhaps my post was not clear
I will try for a full explanation
[1] the wiring
, 2.5mm2 rating depends on the installation
Table C5 gives the CB rating for 2core &earth in different conditions
25 amp in FREE air
,20amp when in air but enclosed[between walls behind switchboards etc
20amp is the size in general use
The CB is to protect the wiring from overheating
[2] GPO outlet socket
The combination only need to be tested to a 10% overload to comply with the standards
That means it can be designed to only be capable of carrying 11amps continuously WHEN NEW without over heating
Some manufactuers MAY ,for ease of component stocking,use the same switch etc components , but this cannot be assumed
But even if they do use the same compnents they must still have each size marked with the specific rating
If the load connected to the 10amp rated outlet iis exceeded, that outlet could be forced to carry in excess of 100% overload contiinuously before the 20amp CB would trip
Contact resistance is the problem , a 100% encrease in current means AN EXTRA 300% heat generated due to contact resistance
When new ,with clean contact faces, good contact sping pressurre, they may be able to hold that for a short time
BUT with age ,contacts faces tarnish, contact preesure weakens
The heat can rise dramatically & fires HAVE resulted even with an approved 10amp load
The purpose of the BIG earth pin is basically a key
It is to prevent access to an underated outlet socket for the 15amp load
That is why loads which are in excess of 10amps SHALL have a higher rated PLUG fitted otherwise they will not get approval
Your van is classed as such a load, IT requires a 15amp plug
This may be reduced if the vans possible load is reduced by means if a 10AMP CB in the van
I hope all can see this is not really anything to do with house wiring as many seemto assume
IT IS ALL TO DO WITH THE OUTLET BEING OVERLOADED
FollowupID: 745315
Follow Up By: oldtrack123 - Thursday, Nov 24, 2011 at 11:23
Hi Cannot edit
So a little extra
15amp outlets also only have to meet the 10% overload requirement
Be able to carry 16.5 amps continuously WHEN NEW with out overheating
The required pull out pressure for a 15amp is much higher than for a 10amp.
Contact pressure can have a significant effect on contact resistance,even more so with ageing
FollowupID: 745316
Follow Up By: Dust-Devil - Thursday, Nov 24, 2011 at 11:51
Ah! I see it all now (finally) - Contact Resistance is the 'key issue' and I was correct in assuming that the big mother of a 15A earth pin is a device used by the regulators in an attempt to ensure that all 15A plugs and sockets are made to specs that provide the correct 'Contact resistance'
Took awhile but you finally got me over the line on this one Peter.
Many thanks and I think I may renew all my 15A leads as they are approx 10years old and no doubt the plugs and sockets will have deteriorated a tad. More so that I use a generator that has a 15A outlet socket on it.
DD
FollowupID: 745319
Follow Up By: Bonz (Vic) - Thursday, Nov 24, 2011 at 20:30
DD you need only renew the plugs on the leads I reckon and yes as Pete sasy the 15A plug earth is simply a mechanical thing to stop you plugging into a 15a outlet.
Thanx Pete, for the explanation, I can understand the electrics as well as the resistance. Where are the 10% rules from re the GPO manufactuiring things written? Are they in Australian standards?
Bonz
FollowupID: 745344
Follow Up By: Bonz (Vic) - Thursday, Nov 24, 2011 at 20:33
Also DD the ratings and configuration of outlets on circuits takes into account some averagiign of load, i.e there is an assumption that not all points will be in use at the same time. 28A may be the rating of the cable but I wouldnt want to run it at that for very long
FollowupID: 745345
Follow Up By: Bonz (Vic) - Thursday, Nov 24, 2011 at 20:50
Hmm the word I was searching for was "diversified" load
FollowupID: 745347
Follow Up By: oldtrack123 - Thursday, Nov 24, 2011 at 21:15
HI Bonz
RE:-Bonz (Vic) posted:
"Hmm the word I was searching for was "diversified" load"
More commomly called the "diversity factor"
where the total of all the possible loads on a circuit is derated by a factor
Different devises a treated differently
Different combiniations of loads, different factor is applied
Again takes up quite a few pages
But is the reason that it is no just as simple as removing a10amp double outlet & replacing it with a single 15amps
FollowupID: 745352
Follow Up By: oldtrack123 - Thursday, Nov 24, 2011 at 21:54
Hi Bonz
Re:"Thanx Pete, for the explanation, I can understand the electrics as well as the resistance. Where are the 10% rules from re the GPO manufactuiring things written? Are they in Australian standards? end quote
EVERY piece of electrical equipment is covered somewhere in A cross referenced standard
The one covering plugs & sockets is AS /NZS 3112 :2004
I did have a copy on my old Hard drive that crashed.
Lost it & a lot of other good stuff
FollowupID: 745357
Reply By: Hairs & Fysh - Tuesday, Nov 22, 2011 at 10:26
Hi Toby,
I use a made up extension cord, 10amp on the male end and 15amp on the female end the cord is 15amp. I plug it into charge the batteries and to get the fridge down to temp before traveling. If I need to work on the camper, I plug into the houses external power point, not the campers.
I'm lucky my carport has external power points that are weather proof. If your meter box is handy and close and your worried about using the 10 amp outlet, get a sparky to install a 15 amp point for your.
Hope this helps.
Cheers.
AnswerID: 470620
Follow Up By: Hairs & Fysh - Tuesday, Nov 22, 2011 at 10:33
I'll add, I have a 15amp lead with 15amp plugs for use in parks, it stays in the camper.
FollowupID: 745122
Follow Up By: oldtrack123 - Tuesday, Nov 22, 2011 at 12:03
All of the above suggested 10amp to 15amp leads are illegal
Such leads cannot be purchased ,will not be made up be a RESPONSABLE electrician.
IT is illegal in most states for a none qualified person to make up or modify ANY lead
Many using them , does not make them safe or a sensible practise
The supporters put up long arguments for there use
These arguments will not stand up if your house burns down & insurance refuse to pay up Or any other serious consequence occurs
The Two legal options are
[1]get a 15amp power outlet installed
or
[2]purchase a fully approved Amphibian lead specifically made & APPROVED for the purpose
If you wish to see a lot of discussion ,just do a search on ANY forum for "10to 15amp lead"
The final decision is yours!!!
FollowupID: 745126
Follow Up By: Hairs & Fysh - Tuesday, Nov 22, 2011 at 12:43
Hi Peter,
I don't load up my leads and never have, they are never coiled over each other and I use as little draw on them as possible.
As I mentioned I use the house 10amp to get the fridge down to temp and to charge my batteries when needed, never the two at the same time.
I can understand that some will load theirs up with all kinds of appliances and wonder why it keeps tripping out.
Also as mentioned, If I need to use more power I will plug into the houses external power points.
BTW, I don't have 240v lights, all my lights are LED's and run off the 12V system.
FollowupID: 745131
Follow Up By: Meggs - Tuesday, Nov 22, 2011 at 23:43
Jon and Karen rest assured you are not alone you have many mates.
FollowupID: 745197
Follow Up By: Hairs & Fysh - Wednesday, Nov 23, 2011 at 11:41
Cheers :)
FollowupID: 745208
Follow Up By: Member Ray M (QLD) - Wednesday, Nov 23, 2011 at 17:37
Yes I too have made up a "cheater lead" about half a metre long and 15amp lead with a 10 amp plug on one end and just plug into standard 15 amp lead to van
Use it at home and even when friends stay in the van with air con going we have never had a problem.
I know it isn't legal but neither is talking on your mobile while driving (not that I ever do that even on outback roads with no traffic, cough)
Cheers Ray
FollowupID: 745234
Reply By: Bushranger1 - Tuesday, Nov 22, 2011 at 11:52
G'day Toby,
All this advice about 15amp to 10amp adapter cables is illegal!
Purchase a 15amp extension lead & get a 15 amp power point installed at your house & do it properly.
If you start a fire then I suspect your van & house insurance will have a reason not to pay your claim.
Stu
AnswerID: 470626
Reply By: Member - Richard L (VIC) - Tuesday, Nov 22, 2011 at 12:04
Hi Toby
There is an adaptor on the market that legally allows you to plug your trailer into a household power point. Its called amp-fibian rv02.
You might try your local electrical wholesaler for a price comparison before purchase. It will be cheaper than getting a 15A power point fitted in your car port
AnswerID: 470627
Follow Up By: Toby T1 - Tuesday, Nov 22, 2011 at 13:24
Thanks everyone, but this advice is what I am looking for. Only because I would like to park my caravan outside friends and 'simply' plug into their household supply. Otherwise I just get a sparky to install a 15 amp power point as recommended.
FollowupID: 745132
Reply By: Dust-Devil - Tuesday, Nov 22, 2011 at 13:20
Toby
Dude! bet you never expected to get assailed by the 'DO & DON'T Brigade' above to the extent that your head is now spinning like a Merry-Go-Round.
The answer to your question is YES! you can connect your Van to your house supply.
How you go about it is another issue all together. The responses above have described the common methods of doing it, and I am not going to comment on any of them.
What you eventually decide to do is your business.
However I will second whoever it was that mentioned the AMPFIBIAN. This is a piece of gear that has been specifically designed to do what you are asking about.
It is the only Officially Approved device of it's type for commercial sale in Australia (or was the last time I checked)
Ooo! Ooo! brigade note - I specifically stated 'device of it's type'.
I actually have one and purchased it to use with my generator when powering up my Jayco Base Station.
From memory it cost $220.00.
You will find everything you wish to know about it at the following link:
AMPFIBIAN
Have a good one
DD
AnswerID: 470635
Follow Up By: Toby T1 - Tuesday, Nov 22, 2011 at 13:25
Thanks.
FollowupID: 745133
Follow Up By: Toby T1 - Tuesday, Nov 22, 2011 at 13:32
Just looked at the device and silly me thought I could still run my Air con etc using this device! From what I have read about this device it is a legal 10 - 15A RCD and overload device. I will probably purchase one of these so I can plug in legally to friends power supplies, but will install a 15A circuit at home so we can run the van, great for me when I am in the "dog house". ;)
FollowupID: 745135
Follow Up By: Bushranger1 - Tuesday, Nov 22, 2011 at 13:37
Hey DD,
Well you learn something new every day. That AMPFIBIAN looks like a great solution.
Stu
FollowupID: 745137
Follow Up By: oldtrack123 - Tuesday, Nov 22, 2011 at 16:00
Hi DD
Just as you say ,one can do anything they like,legal or not.
All ok until they get caught or something goes wrong
Pleased to see you yourself have enough sense to have an Ampfibian
YES, it still is the only fully approved devise
But sorry one little point
While it gives you a legal lead to connect your genny to the Jayco
PLEASE do not be under misunderstanding that IT's OR your Jayco's RCDs are operative THEY ARE NOT
No plug in RCD can function with an isolated genny or inverter
FollowupID: 745143
Follow Up By: Member - Old Girl - Tuesday, Nov 22, 2011 at 20:49
Thanks DD, you cleared up my questions for me, We collect our BS in a couple of weeks cant wait. Are you happy with yours?
Thanks too to Toby for raising the question.
FollowupID: 745171
Follow Up By: Dust-Devil - Wednesday, Nov 23, 2011 at 11:59
O-G
Yes. we are very happy with our BS.
It is one of the first releases (Ordered 09/07 and received 05/08) and ordered with a Simplicity Suspension and 2 x double bunks (for grand kids)
Being the first of a new model there are the odd 1 or 2 things etc that didn't work as designed such as the table, which I have now modified to my own design and all function as I want them to.
Also added a bucket load of extras to it as you tend to do to get what ever it is to how you like it.
Enjoy
DD
FollowupID: 745210
Reply By: nowimnumberone - Tuesday, Nov 22, 2011 at 17:50
i do as many others have
bought a 15 amp lead
cut the 15 amp male of and refit with 10 amp male
its not hard when you buy a plug they tell you what colour goes where
dosnt get any easier.
but be carefull its illegal blah blah blah blah blah
AnswerID: 470664
Reply By: Mark C - Tuesday, Nov 22, 2011 at 18:37
What a joke, 15 amp plugs and leeds that are about 1.5m2 30mts long.
AnswerID: 470671
Follow Up By: oldtrack123 - Tuesday, Nov 22, 2011 at 22:09
Hi Mark
Where did you see those
25mts is the max for 1.5m2 general purpose 15amp lead
FollowupID: 745189
Reply By: Member - Bruce and Di T (SA) - Wednesday, Nov 23, 2011 at 12:56
Hi Toby T1,
We put in a dedicated 15 amp powerpoint when we got our first van. It's right where we house the van and has been a real boon. We plug in at least once per month to keep the batteries charged up too.
Bruce and Di
AnswerID: 470722
Follow Up By: ozjohn0 - Wednesday, Nov 23, 2011 at 20:27
I can't believe that some posters are not only suggesting but recommending that others should use illegal leads.
That includes Cheat lead, earth contact filed, or the fitting a 10 amp male plug.
To suggest or recommend to some that someone break the law is in itself an offence.
If you (And heaps of others) use an illegal leads, then I suggest you keep the fact to yourself.
Ozjohn.
FollowupID: 745251
Follow Up By: oldtrack123 - Wednesday, Nov 23, 2011 at 20:58
Hi Ozjohn
I can only HOPE that your comments sink in
But sadly , I doubt it will make any difference to them.
After all ,THEY have been doing it for years & nothing has happened
Based on that , in THEIR opinion it must be ok
To those who have some sense ,responsibility, do the sensible thing
GET A FULLY APPROVED & THEREFOR LEGAL ADAPTER
"Ampfibian "
I am sure it will not break your bank &you have a high level of peace of mind
FollowupID: 745259
Follow Up By: ModSquad - Wednesday, Nov 23, 2011 at 21:55
Hi Peter, I reckon you've made your point, and its a good one. In the end people will make their own decision rightly or wrongly and they will live with the consequences. As DD said above there is one legal solution other than the 15A plug install.
Moderation is just rules
FollowupID: 745268
Reply By: david m5 - Wednesday, Nov 23, 2011 at 21:01
If you get a sparky to remove a double 10 amp power point(20 amps total ) and install a single 15amp then all should be good. from what I can tell the wire and breaker will handle it.
AnswerID: 470763
Follow Up By: Bonz (Vic) - Wednesday, Nov 23, 2011 at 21:57
This too is not in accordance with the Australian wiring standard David. There are strict limits on what can be installed on a circuit and its not as easy as removing a double 10A outlet from a circuit. Any reputable sparky will tell you that and refuse to do such a job.
FollowupID: 745271
Reply By: oldtrack123 - Wednesday, Nov 23, 2011 at 22:17
Bonz (Vic) posted:
I forge, therefore I am….. ahead.[end quote]
HI Bonz
I'll 2nd THAT
AnswerID: 470775
Follow Up By: Bonz (Vic) - Thursday, Nov 24, 2011 at 20:34
Hear Hear!
FollowupID: 745346
