Thursday, Jan 26, 2017 at 09:54
Steve B, The
Great Central Road should be very much thought of as two things: the NT section, which is awful, and the WA section which is excellent.
The NT section from Kata Tjuka (The Olgas) to the WA border near Docker River is usually rough, corrugated and somewhat
rock strewn. You should certainly lower your tyre pressures and slow down (probably 80 or 90 max) to avoid shaking your rig to bits. Also camping is officially somewhat more restricted to either end, ie Uluru and the public
campsite just west of Docker River, although we did see people camping amid desert oaks in the eastern half. The desert oak groves are a real highlight, like funny little enchanted forests in the vast outback. It is possible this section of the road is being upgraded right now as considerable funding has been allocated to the NT govt for this purpose. The Docker River office will be able to tell you.
An alternative to this 180 km teeth rattler is the
Sandy Blight Junction Road which is maintained by the (WA) Shire of Ngaanyatjarraku to a similar standard as the WA roads, but requires a bit of a rejig of your itinerary as its a bit hard to leave from Uluru. You would normally leave from
Alice Springs and head west through the spectacular West McDonnell Ranges toward
Kintore and then take the SBJ Rd south toward Warakurna.
The WA section, conversely, is like a billiard table in comparison! As you will generally be able to thunder along at full noise you'll need your tyre pressures right up, to avoid blow outs. I would recommend you get a permit to visit Surveyor-General's Corner, near Wingellina at the tri-state border, not that the corner itself is that interesting, but the drive from Wingellina to Blackstone to Jameson and
Warburton skirts the spectacular Blackstone Ranges, which I think is one of the great pleasures of the outback.
If you want to visit the
Giles weather Station near Warakurna, which I'd also recommend, it will necessitate a 35-odd km back-track to the Wingellina turn off, which is on the Docker River side of Warakurna. You should be able to get from Docker River to Warakurna back to Wingellina and then through
Warburton in a day to be able to
free camp west of
Warburton, if that's what you prefer. This distances aren't massive. Otherwise, I've always been happy to
camp at the
campsite enclosure behind the
Warburton Roadhouse.
You get your WA permits online from the Department of Aboriginal Affairs website
here or the Ngaanyatjarra Council
here. The NT permits are similarly available online from the Central Land Council
here.
But you SHOULD DO IT! It's wonderful country and a great experience.
All the best
607993
Follow Up By: Zippo - Thursday, Jan 26, 2017 at 12:41
Paul B: "The NT section from Kata Tjuka (The Olgas) to the WA border near Docker River is usually rough, corrugated and somewhat
rock strewn."
We've been through there each of the last three years. The first two gave us tooth-rattling corros, but no rocks strewn around. Last year it was more like a billiard table, except for the bog patches. These were east of Docker River.
Westwards to the border was fairly rough once you pass the new sealed "highway' section. It was almost as though the graders don't venture there.
877767
Follow Up By: Member - Paul B (WA) - Thursday, Jan 26, 2017 at 23:26
Thanks Zippo, you information is more current that
mine. I was last through the NT section 18 months ago in July 2015, however the NT section was identical to my previous 2 times on it going back 4 & 10 years.
We had a
rock break a water pipe out of an underslung
water tank on the heavy offroad camper on the way across and another through not just the repaired hose, but also broke the elbow out of the tank to which the hose was connected on the way back. We've never had these problems on any other roads despite thousands of
miles on dirt roads and tracks.
We also had a flat tyre with a large
rock cut from the edge of the tread up the wall. We met other traffic with similar problems. We also met a guy with a smashed windscreen.
That's why I say it was somewhat
rock stewn. I also note in your videos there are some quite large stones near the water across the road, which would probably account for you not particularly noticing them rocks, but if the road was dry they would certainly have been as brutal as I have described.
I also added the caveat that it might have been substantially upgraded following the allocation of $50 million (from memory) for that particular section of the Great Central in this financial year, so I was unsure whether the work had been done yet. From what you are saying, it appears some of it has been but the western end of the NT section is still awful. Brutal is how some have described it, hence my preference for the
Sandy Blight Junction Road.
877779
Follow Up By: Member - Rod N (QLD) - Monday, Jan 30, 2017 at 11:20
Mention has been made a few time on travelling the
Sandy Blight Junction Road. Is this road suitable for towing an 'off highway' caravan?
877880
Follow Up By: Baz - The Landy - Monday, Jan 30, 2017 at 13:11
Hi Rod
Anything is possible, but given you note it as an "off highway" van, as distinct from an "off-road" unit I will say no...
The track itself is not arduous, but sandy in some sections - if it was one of the more reputable units like a smaller Bushtracker unit (for example), one might be willing to attempt it with the right care and experience...
it will be interesting to hear if others have, and I would defer to the experience of someone like frequent EO visitor "Motherhen" ...
I have done it with a TVAN and it presented no problems, although it isn't a caravan.
Good luck with your travels.
Cheers, Baz - The Landy
877883
Follow Up By: Member - Rod N (QLD) - Monday, Jan 30, 2017 at 13:22
Thanks Baz, I thought as much but just wanted it clarified as the SBJ Road has been touted a few times as an alternative to part of the GCR. In fact it appears it is not suitable for the general traveller.
877884
Follow Up By: Peter_n_Margaret - Monday, Jan 30, 2017 at 15:57
One bit in 2003....
877887
