User treks map missing
Submitted: Friday, May 06, 2016 at 08:46
Member - Boobook
In the past I could search for user
treks by a map, just like you can still do for EO
treks.
But... the option for map search is missing in user
treks and I have to search by latest or alphabetically by the name the user called the trek in a list. Almost impossible to find anything.
David and co, this appears to be an oversight in the User
treks. Is it coming back?
How on earth will I know for sure that Stephen L and the Landy have beaten me to every corner ( and god dammed confluence point) of WA and SA.
Reply By: Member - Boobook - Sunday, May 29, 2016 at 07:32
Any answer to this?
Why has the map for user
treks disappeared?
You can search for
treks by state and name, but not by the map like you used to be able to do ( and still can with EO
treks)
The names generically give no indication of the location of the trek and make it very difficult to use.
Please put the map back.
600692
Reply By: Member - Boobook - Monday, May 30, 2016 at 13:13
bump.
Michelle / David?
600735
Follow Up By: ModSquad - Sunday, Jun 19, 2016 at 17:19
Hi there, sorry for the long delay we thought we'd got back to you..... and I use the Royal "We" there... We did get a reply back and the map function has been nobbled as some road lines will show over 40 different User
Treks crossing over it so it was impossible to create a map search as there was no way to select one route.
There are other options to search:
a. User
Treks can be found via selecting from lists – to refine results, so via a state, and a region.
b. User
Treks can be found via search – this looks up start/end point place names
One of the difficulties with user generated input is the naming as these are created by the user and "Big Lap" features a bit.
871105
Follow Up By: Member - Boobook - Monday, Jun 20, 2016 at 08:56
That can't be correct. There WAS a map search view until about a year or so agi and it worked
Some
treks are
invalid because of false GPS location readings and these go all over the place but that is still the case with name search.
It WAS working
The problem now is that the search has no correlation to the name of the
treks or the start / end point. For example many ( most?)
treks for
Cape York start and end in
Melbourne or
Sydney. Several of the
Madigan line start in
Brisbane or
Adelaide. Lots even start at position 0, 0 of the west coast of Africa until the GPS obviously started locking into the sats.
The names of the
treks are not standardized. They have names like Wozzo's trip or 2016 outback track.
How do I search for that? The only way to reliably find a trek is by a map that is zoomed in.
It used to be really good, In fact it was the reason I took up
membership again.
Surely it can be put back to what it was a year or so ago to make it useful.
871136
Reply By: ModSquad - Tuesday, May 31, 2016 at 12:01
We'll shoot it to the crew Boobook, you can email too at info@exploroz.com and ask similars.
All the best
The Squad
600772
Follow Up By: Member - Boobook - Friday, Jun 17, 2016 at 07:43
I still haven't got an answer to this.
It it policy to ignore some questions?
870903
Follow Up By: Member - Boobook - Thursday, Jun 23, 2016 at 07:07
I am stunned that lack of support to a paid member can go this long.
871278
