bush showers
Submitted: Tuesday, Nov 08, 2005 at 21:57
ThreadID: 27939 Views:5384 Replies:12 FollowUps:12
Glind Showers versus Sigston showers. Any comments?
Reply By: Diamond (Vic) - Tuesday, Nov 08, 2005 at 21:59
dont forget theres also the helton.
fantastic unit and half the price.
AnswerID: 138542
Reply By: Trekkie - Tuesday, Nov 08, 2005 at 22:27
Dont know about the others, but I have been using a Glind for 3 years - has NEVER caused a problem.
AnswerID: 138549
Reply By: Truckster (Vic) - Tuesday, Nov 08, 2005 at 22:34
I love my $25 Coleman portable thing. That and a square plastic box to stand in and recycle the water. Great !
AnswerID: 138556
Follow Up By: Sand Man (SA) - Wednesday, Nov 09, 2005 at 08:25
Yep, I'm with you Truckie,
Not restricted by distance from vehicle because it has its own set of batteries. And nothing wrong with recycling the water, or heating it on the fire first. Easy as!
Bill
FollowupID: 392281
Reply By: kev.h - Tuesday, Nov 08, 2005 at 22:34
know of glind & heldon but what type is sigston & where from??
AnswerID: 138559
Reply By: Haza - Tuesday, Nov 08, 2005 at 22:50
Just got a Helton, installed it on saturady, great customer service. On a Rodeo found I needed to have a rev above 1800rpm on the diesel. Got the hot water unit as I'm down Melb and will use it in the colder months. Works well as tested so far. It's efficent for it size. I chose it as when working out the space required the Helton was more suitable in size and fitting placement. I purchace my own Ecopump(auto shut off at 35psi) pretty much the same at the flojet the glind have in there full size unit all works to expections. Time to have a shower.
AnswerID: 138565
Reply By: gramps - Tuesday, Nov 08, 2005 at 22:51
Happy with $20 unit from Jaycar, plastic storage tub and a bucket of hot water. How much time (and $s) do you guys waste in these fancy shower thingies?
AnswerID: 138566
Follow Up By: Member - Duncs - Wednesday, Nov 09, 2005 at 00:32
If it's too cold to swim we just stinck together.
FollowupID: 392241
Follow Up By: gramps - Wednesday, Nov 09, 2005 at 00:36
LOL ya beat me to the cheapest and probably most luxurious option. Well done :)
FollowupID: 392244
Follow Up By: flappa - Wednesday, Nov 09, 2005 at 10:12
Depends on how many you are trying to shower.
I have probably used the majority of known showers , and made a few of mine own over the years.
Sure , boiling water , solar bag etc , are good for 1 or 2 people.
Providing showers for 6 brings a WHOLE new set of problems , that I have found is best suited by a vehicle shower.
FollowupID: 392301
Follow Up By: gramps - Thursday, Nov 10, 2005 at 18:20
I see your point Flappa.
FollowupID: 392600
Reply By: madcow - Wednesday, Nov 09, 2005 at 07:30
Not forgetting the Twine unit also. Very happy with it on my 4.2tdi GU
AnswerID: 138597
Reply By: Alloy c/t - Wednesday, Nov 09, 2005 at 07:43
Coleman ,dont have to start the car , can use anywhere anytime.
AnswerID: 138598
Reply By: Member - Pesty (SA) - Wednesday, Nov 09, 2005 at 08:37
Yep love my heldon unit , well made, and 10 minutes from cold start to nice shower and a little bit of juice in battery while doing it, and can use left overs to do dishes as well. Had a couple of the cheap $28 dollar ones and they need to be thrown away when they sieze up every 12 months, cant be bothered, heldon unit all stowed, connected, under bonnet except bucket and water. EASY.
Another tip, use a canvas bucket hung on bullbar as it folds away easy.
But never go past a chance to swim instead if you are camped in that situation.
Cheers Pesty
AnswerID: 138605
Reply By: Redback - Wednesday, Nov 09, 2005 at 08:54
Yep Helton as a vehicle shower, but for the ultimate i use this little beauty,
Bosch gas hot water system, it gives 300l of continuous hot water per hourand it was cheaper than the Coleman and Primus, my next step is hot water in the sink :-))))
Baz.
AnswerID: 138608
Follow Up By: flappa - Wednesday, Nov 09, 2005 at 10:02
You got a washing machine hooked up to that Baz.
Good idea though. Does it just run off your gas bottle ?
Shouldn't be too hard to get it hooked to the sink.
FollowupID: 392300
Follow Up By: Member - Duncs - Wednesday, Nov 09, 2005 at 10:58
How is it on gas consumption?
What do you use for a water supply? Does it have a pump?
Must say I have wondered about that type of thing.
FollowupID: 392305
Follow Up By: Member - Beatit (QLD) - Wednesday, Nov 09, 2005 at 11:14
Ok so tell us more! Like what are the dimensions (looks like it's in a trailer) and weight. Also does it have a pilot light and how quickly does it heat from cold start?
Kind regards
FollowupID: 392308
Follow Up By: Redback - Wednesday, Nov 09, 2005 at 12:16
Yep runs off one of 9kg bottles on the trailer, and no Graeme no washing machine.
Don't know the weight off hand, it's very light though, lighter than the Coleman and the Primus.
Our CT water tank is the supply and we have a shurflow 60psi pump, this is critical as it has to have a minimum of 40psi pressure to run and has to have water in the exchanger to start.
Gas consumption is good about the same as a stove and has a pilot light and as you turn the water on and the temp up, the burners cut in, it has 4 burners and when you stop the water it goes back to the pilot lightonly.
It's 62cm tall, 22cm wide and 20cm deep approx, about the size of a jerrycan, only half as wide.
We have used it 3 times now and it's just like showering at home, well almost.
We were lucky as it was a factory second and was $324 from Caravan accessories/Camec.
A workmate has one of these in his home, the natural gas version of coarse.
Baz.
FollowupID: 392324
Follow Up By: flappa - Wednesday, Nov 09, 2005 at 12:53
Baz , is it mounted inside the CT ?
How is it legally ?
Not that I care what YOU do with it , but interested anyway.
I guess these are the same/similar that can be used at home (on bottled gas) , or RV/Cvan HW heaters ?
FollowupID: 392334
Follow Up By: Redback - Wednesday, Nov 09, 2005 at 13:13
It is designed for caravans and campers and as long as it is installed by a licenced plumber/gas fitter it is perfectly legal and it is well ventilated, which it is as it is not used unless camper is open.
Quote;
Yes, they also are availible in 240v and natural gas for home.
Baz.
FollowupID: 392338
Follow Up By: fatz - Thursday, Nov 10, 2005 at 11:52
Baz is getting a water bed to keep the supply up to it :)
FollowupID: 392552
Reply By: Member - Trevor R (QLD) - Wednesday, Nov 09, 2005 at 12:41
David,
9 yrs of a glind without trouble through 3 vehicles says a lot for the robustness of the glind. To me it takes everything I throw at it and keeps on giving me lovely bush showers. We used this unit solid for 2 - 3 yrs with at least 150 showers by 2 people per year no probs. If I was buying another unit today I would look at the Coleman/Primus type units for their self sufficiency, but if you can live with the glind attributes then I feel the unit should outlast you and your camping days. (not having a go just a figure of speach)
Hope this helps Trevor.
AnswerID: 138638
Reply By: Tim_N - Thursday, Nov 10, 2005 at 13:09
Also the pumps on most of the other systems are small submersible or bilge type pumps that will deliver about 2l/min. Even the smallest Glind will give over 4l/min at 35 psi and these pumps are marine grade and suck water from 20' away.
The glind doesn't need gas bottles and the hardware is already on the vehicle, so it is one less thing to pack or leave behind like my mate did. I think the price is about the same too.
AnswerID: 138794
