Cleaning car water tank
Submitted: Sunday, Oct 10, 2010 at 09:09
Member - Vern
I am looking for information as to what is the best way to clean out the 60lt
water tank in my Pathfinder. I use this
water for everything from drinking to washing and I want to maintain good
water quality. I do run the
water through a filter when I fill the tank.
Reply By: Sand Man (SA) - Sunday, Oct 10, 2010 at 09:34
Hi Vern,
Unless the
water tastes "tainted" you probably don't need to bother, but if you find you do need to clean your tank, there are a few products (some quite expensive) to try.
On the rare occasion I clean the camper tank, all I do is drain the existing
water, add the required amount of
Milton's Baby bottle wash solution to the empty tank, then fill with clean
water.
Leave this for a day or two, then drain the tank again and refill.
The reason I like Miltons is that it is not a major cost and it is easy to determine the amount required per litre of
water as this is shown on the bottle's label.
I never bother with a filter when adding
water to the tank, but I do use a "food quality" rated hose to do the job.This will stop any contamination transferring from normal plastic hoses that have laid out in the sun for long periods of time.
The hose is white with a blue stripe and available from Clark Rubber stores and Caravan outlets.
Bill.
432572
Follow Up By: Member - Vern - Sunday, Oct 10, 2010 at 10:23
Thanks for the advice there Sand man, i have been using the food quality hose to fill the tank. The tanks has only been in for 1 yr and it was cleaned prior to this, i have noticed some floaties in the
water but I am not sure if it is coming from the tank or the poly hose running to the back of the car.
703388
Follow Up By: kev.h - Sunday, Oct 10, 2010 at 11:56
Hi Vern
If THE poly hose is clear or light coloured and can get a reasonable amount of light it could be algae growth in the hose you did not say what the tank is made of, if its light plastic may be the same problem
Milton as above is good i also find baking soda and white vinegar is good for cleaning the tank removing that plastic smell and flavour from the
water
Cheers Kev
703389
Follow Up By: Member - Vern - Sunday, Oct 10, 2010 at 12:35
The tank is a stainless steel tank. I am thankfull for all your thoughts and advice on this subject
Vern
703392
Reply By: Member - Warren R- Karratha - Sunday, Oct 10, 2010 at 13:38
Reply By: Steve63 - Monday, Oct 11, 2010 at 13:48
Depends where you filled your tank. If only city
water it is likely to be bits of plastic. If you have filled from wells or rivers it could be anything. There are plenty of bugs around that will grow in
water as
well as algae. Contaminated
water can be clear and smell fine so it is no way to tell. As an example pseudomonas aeruginosa (can appear black or vivid blue green) grows in fresh and sea
water and even petrolium products. It is difficult to kill off and usually requires the use of hypochlorite based bleaches (Miltons for example). I usually rinse ours before use for a few days, then flush
Steve
432694
