Wednesday, Nov 30, 2011 at 11:50
Col,
Your assumption is incorrect, all modern Alternators run as a constant voltage source ie their output voltage is set at around 14.2V.
The Alternator will always try to maintain this voltage no mater what load is applied ie in a Prado 5A - 80A.
Having said that all Alternators also employee temperature compensation, as the temperature in the engine bay goes up and the battery warms up the alternator will gradually reduce its output.
This has no affect on battery charging as as the battery heats up it requires less voltage to fully charge and hence the reason temperature compensation is built into the regulator.
At least that was until recently, in some current models the temperature compensation has been increased well beyond what is needed to protect the battery. This increase has been brought about by changes in emission laws overseas.
To meet these reduced emission requirements the car manufactures have considerably increased the alternator temperature compensation as to lower the load on the engine at idle, it has nothing to do with maintaining the battery.
Thus on these models the alternator will provide a sufficient battery charge to replace what was taken out of the battery during starting and the reduce the charge voltage to lower the load on the engine at idle etc.
Alternators prior to the current generation had no troubles fully charging a battery and have done so for the past 60 years or so, after all thats what they were designed to do!
LeighW
745959
