Thuray XT Lite Sat Phones
Submitted: Sunday, Jun 14, 2015 at 08:09
D-Max Dave
Anyone using a Thuraya XT Lite Sat phone, if so how do you find it ?
Also does having a Omni-directional antennae, make it harder to make calls with the phone, if you have to hold it at an angle of 25 - 50 degrees in a NW direction to get coverage it would be difficult to hold the phone to your ear wouldnt it ?
Reply By: Member - Boobook - Sunday, Jun 14, 2015 at 11:42
Dave, not sure about the phone, but if it has an omni-directional antenna, that means it will work in any direction.
555944
Reply By: Member - TonyV - Sunday, Jun 14, 2015 at 14:44
I have one via Pivotel, It is easy to use and works
well. No need to hold it on any angles it often works under cover.
the 25 to 50 degree is to sight the satellite which id 35kms above Singapore.
Melbourne 25 degrees
Darwin 50 degrees.
I use it on the Cape and West of
Cairns and have no issues.
I suggest that you have a read through son providers info,
SatPhones link here is a good read.
555948
