Friday, Jan 18, 2013 at 09:28
Vicki
Possible situations.
The
water can accumulate over time and then get to a critical switching point suddenly.
The
fuel filter most likely will not have been "water"drained at service time and this can also cause the
water build up. Slack service!
The
fuel just purchased can have a % of
water and it then can suddenly be drawn to the filter because the
water is heavier than
fuel and the
fuel is drawn from the bottom of the
tank where the
water would be, if present in the
tank.
As mentioned it may be a restriction of the filter issue because of the lack of changing filters. Both
water and restriction will usually turn on the filter light so you really don't know which it is.
I know a lot of people talk about
fuel and it's sources ie Singapore etc etc etc. How does that matter, it is what is in your
tank which matters and we have no control over the supply chain.
As it stands I would suspect you may have a
water in
fuel issue or you have a dealer lack of service issue which has meant the filter hasn't been drained/changed and now the inevitable clogging has happened.
If the dealer is the one who now looks to find the problem you may never know what was the real issue cos they aint gunna admit nuffink, particularly if they regard you as not being aware of the factors relating to the issue.
Reports from
forum members can alert you to many things the dealer would prefer/doesn't want you not to know.
I hope all goes
well for you.
Ross M
779384
