Ctek MXS 10
Submitted: Tuesday, Jan 22, 2013 at 14:04
ThreadID: 100127 Views:4719 Replies:3 FollowUps:9
Can anyone tell me what size generator will run a ctek mxs10 battery charger. I have a honda ex350 geny for camping and was wondering if this will run a ctek mxs10.
Reply By: olcoolone - Tuesday, Jan 22, 2013 at 14:25
Your Ctek will draw about 290 watts at full steam..... you genset should be OK
AnswerID: 503145
Follow Up By: Member - Frank P (NSW) - Tuesday, Jan 22, 2013 at 15:21
Olcoolone,
As best I could tell from googling, that genny has a straight square wave output, no modification at all to try and make it look like a sine wave.
I know motors and some other things don't like that - run hot or don't run at all, whatever. Are battery chargers ok with it?
FollowupID: 779780
Follow Up By: DJS - Tuesday, Jan 22, 2013 at 15:27
I have been running a 12amp two stage protech (i think)charger on that genny for many years now with no problems.
FollowupID: 779781
Follow Up By: DJS - Tuesday, Jan 22, 2013 at 15:29
Sorry powertech charger
FollowupID: 779782
Follow Up By: Ross M - Tuesday, Jan 22, 2013 at 17:15
Olcoolone
A generator like that outputs a sine wave. May not be exactly 240vac or directly on 50Hz but it is not a square wave.
A commonly so called generator, which is really an alternator, can't put out a square wave simply because of the laws of electrical physics and the induction can't suddenly produce a voltage to go instantly from 0 to 240 with no time shift happening.
The inaccurate wave form and the frequency of some "generators" can however, destroy some sensitive switch mode power supplies and electronic gear.
Multi stage chargers can be among them. If they run, they nearly always run hotter than they should as they try to dissipate the spurious energy they can't handle.
This situation happens most when someone runs a bit of gear on a so called "modified sine wave inverter" which is really a modified square wave inverter. They just add the "sine" in the name to make them more saleable and attractive to buyers.
FollowupID: 779795
Follow Up By: Allan B (Member, SunCoast) - Tuesday, Jan 22, 2013 at 21:33
Ross, it was Frank who said it was square wave, not Olcoolone.
But you are right of course about the inherent sine wave output of an alternator.
To add further, an alternator has a magnet (either permanent or DC) rotating inside a set of coils. As the magnet approaches, passes, and departs each coil it essentially traces a sinusoidal path and hence produces a sine wave. It's elementary Watson. LOL
FollowupID: 779811
Follow Up By: Member - Frank P (NSW) - Tuesday, Jan 22, 2013 at 22:43
Guys,
If you look at the handbook for the 120V model, it has an alternator doing all the things you say, followed by an inverter. Discussion by owners indicate it is modified sine wave or modified square wave output (whatever floats your boat) and very square at that. I doubt that the 240V model would be any different, other than the voltage and frequency - but it could be. So I think caution is justified.
FollowupID: 779820
Follow Up By: Allan B (Member, SunCoast) - Tuesday, Jan 22, 2013 at 23:25
Aha, I did not realise that the EX350 was an Inverter model. That changes things a bit.
The handbook shows an alternator followed by an inverter but does not indicate the type of inverter or the output waveform. However this document does identify the EX350 as having a modified square wave output from the inverter. But not "straight square wave", heaven forbid!
So yes Frank, caution is justified.
FollowupID: 779822
Follow Up By: olcoolone - Wednesday, Jan 23, 2013 at 09:18
There is another issues as well with single cylinder motors and frequency variation...... some switch mode stuff don't like it.
Allan I think your right about the output of the EX being modified sine wave........ the EU range are pure sine wave.
FollowupID: 779837
Follow Up By: Member - Frank P (NSW) - Friday, Jan 25, 2013 at 14:39
The generator has two speeds so you can run it slower and quieter for a light load. The frequency is controlled by the inverter, not the engine speed, so frequency shifts would not be an issue.
FollowupID: 779999
Reply By: Member - Frank P (NSW) - Wednesday, Jan 23, 2013 at 00:08
DJS,
The specs of your charger and the specs of your generator suggest that your generator has the capacity to run the charger at its full output, so that part is ok.
However before you plug it in I think the wise thing to do would be to give Ctek customer service a call and ask them if it's ok to plug your charger into an inverter generator with a modified sine wave output.
If you understand the significance of that, great, but if you don't just ask them that question. A yes or no answer is all you need.
AnswerID: 503176
Reply By: DJS - Wednesday, Jan 23, 2013 at 09:46
Thanks guys for your input will ring ctek.
AnswerID: 503194
