Is Bleeding fuel line necessary after replacing a tank?
Submitted: Friday, Feb 01, 2013 at 15:03
tonysmc
If I disconnect my
fuel line (diesel) where it comes out of the
tank, will I need to bleed the
fuel system once I connect it up again? I am not touching the filter at this stage, just dropping the
tank out and connecting it back up again. I was worried that as there would still be
fuel in the hose and filter, the car would run for quite some time before/if it conks out. I don’t want to be 10 K’s down the road and find out I should have bled the system.
And as there is
fuel in the filter I assume that bleeding will get a lot of
fuel everywhere before I encounter any air which would be further down the line.
Cheers Tony
Reply By: Olsen's 4WD Tours and Training - Friday, Feb 01, 2013 at 15:13
You don;t mention what type of car it is. I am assuming it is not common rail. It is extremely unlikely you will need to bleed it. The system should cope with the scenario you have described, You may need to prime it by pumping the primer if it stops on you, but you should not need to bleed it.
503786
Reply By: Ross M - Friday, Feb 01, 2013 at 16:56
It all depends on the vehicle type and
fuel type. It is best if you bleed a diesel and you don't want air in the system in some.
If CRD the hp pump runs effectively dry for a short time and that isn't recommended.
Most bleed procedures are very easy to do.
503796
Follow Up By: Olsen's 4WD Tours and Training - Friday, Feb 01, 2013 at 17:28
Yes if it is CRD (common rail) then definitely take the extra care.
780544
Reply By: Rockape - Friday, Feb 01, 2013 at 17:29
Tony,
a few months back I dropped the back
tank out of the troopie and when i put it back in in never bled it. All ok.
Today I dropped the
fuel line off the new 3.2 common rail
ranger to install a waterwatch. After finishing I just turned the ignition on and let the Lp pump bleed the system. About 10 seconds if that.
As previously stated. Would be good if people knew what your vehicle is.
RA.
503798
Follow Up By: olcoolone - Friday, Feb 01, 2013 at 21:53
Most vehicles will have enough
fuel in the filter and lines to run for a while until the
fuel in the line from the
tank catches up.
Years ago it was common practice to pre fill the
fuel filters...... on common rail they don't advise to.
780567
Follow Up By: Rockape - Friday, Feb 01, 2013 at 22:56
I can remember a few engines many years ago, that when you ran out of diesel you not only had to prime them manually, you had to crack every filter, then crack the pump and finally crack the injectors.
Thank god times have changed.
780578
Reply By: tonysmc - Saturday, Feb 02, 2013 at 09:01
Yes it is a common rail. 2010 Hilux.
Thanks for all the replies.
Cheers Tony
503842
