Monday, Feb 04, 2013 at 09:29
Rockape
Apparently things weren't so hightech in the mines eh.
Have a look for the sensor you are talking about. From what you say it has to be somewhere along the negative battery cable between the neg terminal and the body.
When you vehicle is charging the "earthiest" ( as one person put it) point you can have is the case of the alternator.
The sensor will be there to read the amount of current returning to the battery from electrical gear and accessories connected to the body work.
If you have
driving lights I would then imagine the earth wires of the lights would need to be also connected to that point.
I hope that sensor wire has a high rating because not only will it have to sense the normal current flows but also ALL extras if it is to sense and do what it is there for.
I presume the engine earth lead to the battery will be that particular earth wire and connect to both the engine and the battery so the sensing can happen.
I suspect your engine has an ECU controlled alternator output and it uses this info to reduce the alts output sometimes in order to save
fuel. at present I'm not fully aware of when and what it does under various situations.
What I have said might help you make sense of other additional info you receive so your system can be connected trouble free and work correctly. PS don't always believe the dealer either sometimes it is spot on and other times erroneous.
780814
