Saturday, Feb 23, 2013 at 22:53
PradoMad
Well, you do have a problem.
The bigger tyres can't be used with the smaller ones, sorry, or even fitted to and used on the vehicle.
The front or rear diff will not like the constant difference in rotational speed.You have gone to 97mm smaller dia and that is around 12+% smaller.
The smaller wheel is 305mm less circumference than the bigger wheel.
The rotational speed may be enough to trigger traction control if fitted.
Definitely the ABS will not know what to do and it would appear to be very dangerous to me.
If used on one wheel or even two
wheels on the same axle then the centre differential will also be running it's spider/differential gears to try and make up for the difference in drive rates being supplied to the front and rear axles.
It will be working overtime, as it is designed to only cater for slight differences of rotational drive speeds when cornering, never constantly being in that situation.
If you have DSC or TC, Directional Stability Control or Traction Control or both, it/they too will be unable to allow for the difference and strange things will happen if and when those systems are activated by the electronics. Probably not good things.
Did you buy those additional rims or did a tyre fitter fit them to those rims? if a tyre fitter did, they would be held responsible for the ensuing accident.
Despite the obvious instability and sudden additional wear rates which will be happening the vehicle will be dangerous and it will sit down on that end or side wherever one of those
wheels is placed.
There will be a myriad of other reasons in addition to what I have mentioned to convince you to sell them and NOT to use them at all.
Normal recommended tyre difference when changing from one set to another size is 2.5% You are nearly 13%.
The jury will decide. I have.
Ross M
505415
