4WD Rust Removal
Submitted: Tuesday, Mar 05, 2013 at 14:13
The Bunyip
Hello all,
Purchased a 2004 Nissan Patrol privately for my wife recently & while I'm no mechanic it looked fine. Was provided with ample paperwork suggesting the car was roadworthy.
Have since been advised the undercarriage has what appears to be superficial rust & has been sprayed with a black solution, either to hide the rust or treat it, which I'm not sure at this stage.
The car was in the UK for 3 years & apparently they use a salt solution over there to clear roads of snow & ice during winter, hence the rust.
The mechanic who performed the roadworthy in
Melbourne appears to think that the rust isn't an issue with regards to the RWC he issued three months ago & is therefore not his problem. Am learning very quickly that this type of thing is very "subjective" in that from one mechanic to the next, they have varied & differing
views on what constitutes a roadworthy car & what doesn't.
So I'm after some advice in terms of what products or steps I should take with respect to removing the rust & having it treated. Naturally, if I leave things they'll only get worse. I live in North-East Victoria so my options with respect to where I take this car are limited. I would imagine specialist 4WD businesses would have seen this problem & know what to do but they are few & far between in these parts.
Reply By: Member - Andrew - Tuesday, Mar 05, 2013 at 17:31
Hi Bunyip
Suggest you take a good look at that black stuff.
Old stuff traps moisture that gets in through the cracks and scratches and festers away and you can end up with major rust underneath. particularly prevalent on imported vehicles from salted road areas.
If its new then why was it added? May be covering something up.
Hopefully its all just because someone wanted to maintain the vehicle.
Worth finding a local roadworthy tester who has a good local reputation and getting it checked out. There have been a number of instances where it wasn't just the body corrosion that was an issue on 2nd hand imports.
If you find problems the local tester can put you in contact with the people who manage the roadworthy scheme who can then follow things up with the original tester and help resolve any issues you find.
Roadworthy complaint process here
I hope your vehicle is ok but if not this process should help you claim against the seller and the original tester.
A
506112
