Wednesday, Mar 06, 2013 at 15:07
Bob your argument is very valid but applies equally to most full size 4wds straight out of the show room. Most have P rated tyres, many are lower profile, have weak springs and poor shocks and have just as many issues if over loaded - when most buy a new 4wd to actually go offroad they head straight to the accessory
shop to get their vehicle up graded.
The same should apply to a softroader - I had one for 8 years and had LT tyres on it - in my case a
suspension upgrade was not needed and the ground clearance was no worse that some of the new full on 4wds - but you do need to know your vehicle.
If outback touring and not intending to do "technical" 4wding then I think a softroader is fine as long as you make the same mods as you would a full on 4wd - the main issue is their smaller size and lower load carrying capacity - the question will be can you carry all the gear that you need too and not be overloaded.
Would I take a softroader to the high country or
Cape York - probably not, but on outback roads - sure (softroaders are generally superior in sand than full on 4wds) - but the 6 Ps apply Prior Preparation Prevents Piss Poor Performance.
Garry
783128
