Tuesday, Mar 12, 2013 at 14:35
G'day Mally
The
old engine oil debate eh.
Fact 1.
On another 4wd site MANY, MANY, MANY, hilux owners use PENRITE and have oil problems,blowby past rings, with gumming, oil burning and failed turbo's etc.
The number of people who are having problems with that oil is incredible. You can read it for yourself.
Fact 2.
Those who have changed from PENRITE and used a good world recognized brand often had the symptoms disappear or largely reduce with regard to oil burning rates and premature oil contamination.
Besides the quality you require the viscosity is also important.
Unless your engine is stuffed it will never ever in it's life require a 60W oil. Your engine is a precision machined engine unlike a Harley Davidson.
If you put diff oil in your engine it will also instantly raise the oil pressure too, while not suited to engines the diff oil,it like the 60W, will cause more fluid drag, is harder to pump, doesn't get to the turbo quickly and causes more
fuel use just to throw it around in the engine.
Do you value your turbo? Do you really? Then don't put thick oil in it.
An old SAfrican? What about an old Australian?
You want to talk to someone who has some knowledge of what modern engines require and it isn't 60W oil for sure.
Castrol Magnatec isn't usually recommended for a diesel. Although it has it's use mentioned for for petrol engines and diesels it isn't recognized as a diesel engine oil at all.
The specs for a diesel engine oil are usually different to petrol engine and I would use something which is squarely aimed and formulated for a diesel instead of a dual purpose, "one size fits all oil". You may find Castrol will sludge your engine. It is know to do this.
I agree with Allan, why listen to two people you don't know and have no idea of what they understand about oil. Then again don't listen to me either, I might be leading you up the garden path too.
Use what trucking companies use.
Mobil Delvac MX or better, possibly the synthetic
Mobil for diesels OR
Caltex Dello 400.
Both of these oils are world wide proven to perform oils and give excellent results unlike the crap Penrite and the lesser than world class Castrol.
I wouldn't put Penrite in my motor mower because I like my motor mower.
When you listen to others I call it being MATED. me mate said type stuff.
That sort of hearsay has ruined more engines than you have had hot dinners. Mates generally do not know. Some do but who are they.
Yours Sncerely, in the long life of your engine.
Ross M
506644
Follow Up By: Grant L - Tuesday, Mar 12, 2013 at 14:54
Ross M
Magnatec comes in two guises "Magnatec petrol/diesel" or "Magnatec diesel", its harder to find and even some outlets don't no its available, comes in two weights 10/40 or 15/40 semi synthetic.
regards
grant
783667
Follow Up By: Ross M - Tuesday, Mar 12, 2013 at 15:43
G'day Grant L
Thanks for that, I did look briefly at a Castrol site PDF and it didn't mention the dedicated diesel one.
Still not much good to anyone travelling and wanting to obtain the unobtainable and rarely seen.
Wouldn't be my choice. Castrol made a mane many years ago but I think they have been surpassed.
A local trucking firm used
Mobil Delvac in their B doubles and one or two engine used more than they should, so they changed to
Mobil full synthetic and with testing now have less oil use and longer service intervals of 20,000km. They find it cheaper to use the full synthetic for their purpose.
783669
Follow Up By: Member - MUZBRY(Vic) - Tuesday, Mar 12, 2013 at 16:14
Gday
Ross
The old South African was possibly Willem....
783673
Follow Up By: Ross M - Tuesday, Mar 12, 2013 at 16:48
Sorry about the lysdexic fingers on the keyboard. Must be the heat getting to me.
783676
Follow Up By: MEMBER - Darian, SA - Tuesday, Mar 12, 2013 at 19:27
He he ..... very funny
Ross... do you have a routine on tyres .... maybe something on batteries .... :-o) ?
783691
Follow Up By: Member - Toyocrusa (NSW) - Tuesday, Mar 12, 2013 at 20:36
Would go over a lot of heads these days Muz.
783706
Follow Up By: Member - MUZBRY(Vic) - Tuesday, Mar 12, 2013 at 21:53
Good evening Toyo
He was good around the
camp fire , Mampur, guitar, any old song in Afrikaner...
783714
Follow Up By: Member - MUZBRY(Vic) - Tuesday, Mar 12, 2013 at 22:02
Good evening Toyo
783716
Follow Up By: Axle - Wednesday, Mar 13, 2013 at 22:51
G/day Muzbry,.. Miss him around here!, Man he used to get me going!....silly bugger let pride get in the road of things...lol.
Cheers Axle.
783797
