I need help
Submitted: Saturday, Mar 16, 2013 at 13:18
ThreadID: 101121 Views:2907 Replies:10 FollowUps:4
Morning I have a HJ75 landcruiser and something is wrong with it. No mechanic here knows whats wrong so I thought I would ask you.
The cruiser is boiling all the time even with short drives, we are forever topping up the coolant, we have noticed that the fluid is not been sucked back into the radiator and it goes into the overflow bottle - then just spews out of the overflow hose we have tried 3 different radiators and the are all doing the some thing, so we have come to the conclusion that the motor might be broken. so my question is has this happened to anyone before if so what have you had to replace, the whole motor or just bits or what. If we replace the motor we will be up for $10000+ anybody got any ideas. thanks
Reply By: Dust-Devil - Saturday, Mar 16, 2013 at 13:32
Went through this exercise last year. Cracks in head (Combustion Chambers) were the culprit. The head was condemned as unfixable by machine/reconditioning shop and a new After Market head was supplied with new valves, guides, seats etc etcby the Machine shop.
Simply amazing result - No O/heating and running way better.
DD
AnswerID: 506895
Reply By: Ross M - Saturday, Mar 16, 2013 at 13:36
Tanya h1
If the system doesn't suck back the fluid when cold then the radiator cap may no tbe sealing properly.
If the engine spews out coolant shortly after starting and before it has heated the water then it may be a cracked head.
If it only spews it out after it has warmed up and then gets HOT it may just be the thermostat sticking shut and any mechanic with a small amount of ability should be able to boil it in water and see if it opens or not.
I would imagine somewhere there lies the problem.
Cap not good, but not the issue.
Thermostat or cracked head. Possibly!
Ross M
AnswerID: 506897
Reply By: member - mazcan - Saturday, Mar 16, 2013 at 13:57
hi tanya
water does not get sucked back to the radiator it is circulated by the water pump has anyone checked to see if the drive belt is missing and/ or the water pump is working remove the radiator cap and watch the water you should be able to see it circulating but only do this when its not boiling has anyone removed the thermostat housing and checked the thermostat condition because it does control the flow and heat
if the water pump is working the head gasket may be letting the compression into the water jacket which will pressurise the radiator water
are the radiator hoses collapsing check along the hoses if you squeeze them and they squash easily and are very soft they will more than likely be colaspsing which will stop circulation
have you pulled the dipstick to see if there is any water mixed with the oil if so the oil will be a whitish grey/brown sludgy colour if there is the head gasket is blown
it will be more than likely be water pump/thermostat/belt or hoses problem the mechanics there cant know much if they cant find the problem that's just a few symptoms I can think of on the spur of the moment
AnswerID: 506899
Reply By: greybeard - Saturday, Mar 16, 2013 at 14:25
Try driving down a flatish road at ~70-80kmh. This should provide a good flow of air through the radiator with not to much load on the engine. If the temperature is a little high and not in the red I'd say the cooling system is probably ok and so is the engine. What may be the problem though is the cooling fan. The silicone oil in the fan may need replacing. The fan looks like it's working ok but it isn't really pulling any air through the radiator. It's about $10-$20 for the silicone oil and about a 20 minute job to replace it.
Google on the LCOOL website for Toyota silicone fan replacement.
We found this the hard way after removing radiators, replacing thermostats, removing heads, replacing head gaskets etc. It's a pretty common Toyota problem we discovered after a couple of days in the sun at the back of the Roma caravan park pulling a Tojo apart :(
AnswerID: 506900
Reply By: Member - Scott M (NSW) - Saturday, Mar 16, 2013 at 15:20
Tanya, seeing any oily residue in the coolant??
AnswerID: 506904
Reply By: pop2jocem - Saturday, Mar 16, 2013 at 15:41
tanya, If you don't have a "mechanic" that can go through a process of elimination and test for the faults that have been listed already you really need to find a mechanic that has got a little more ability.
It 'ain't rocket science to go through the possible problem areas listed above and eliminate them one by one. Do you know what they have done so far other than playing musical chairs with the radiators?
Pop
AnswerID: 506909
Follow Up By: Mick O - Saturday, Mar 16, 2013 at 17:24
I concur with Pop. I'd suggest taking it to a proper mechanic. It's quite a simple test to ascertain if combustion contaminants are present in the radiator water (thereby indicating the head gasket may be gone). I find it hard to believe that a mechanic who is worth his salt would not have identified the issues through a simple process of elimination.
If it is something relatively simple (in the grand scheme of things) such as the head gasket, to continue driving it in the situation you describe is inviting a lot of bigger issues and more expensive damage to the party.
FollowupID: 784030
Follow Up By: Tim - Saturday, Mar 16, 2013 at 17:47
Spot on....
FollowupID: 784032
Reply By: Member - outbackjack 1 - Saturday, Mar 16, 2013 at 17:23
Hi Tanya h1
I had the same problem with my 75 series Troopy, I found by changing the viscus coupling( genuine toyota part) never had a problem again,in saying that I might have been lucky, just a suggestion only. Use genuine parts only if possible, you will pay a bit more, the quality is much better than aftermarket parts.
Ian
AnswerID: 506912
Reply By: Tim - Saturday, Mar 16, 2013 at 17:47
Have you done a pressure test on the system?
Tim
AnswerID: 506915
Follow Up By: get outmore - Sunday, Mar 17, 2013 at 00:12
Pressure tests rarely pick up cracked heads. Been there done that a few times.
FollowupID: 784066
Reply By: Bushranger1 - Saturday, Mar 16, 2013 at 18:59
G'day Tanya,
Get a mechanic to do these 2 pressure tests.
The engine needs to be cold for this.
Remove the radiator cap & Connect pressure tester to radiator in its place . Pump up the Pressure tester to required pressure & watch the tester gauge to see if the system holds pressure or falls away. This will indicate a leak somewhere internally or externally if the pressure falls away.
Now to narrow things down a bit. With pressure still in the system get someone to start the motor. An immediate fast rise in pressure indicates a head gasket or cracked head.
Get the mechanic to watch the gauge during this test because the pressure will rise very quickly & the gauge could be damaged. You will need to shut the motor off immediatly if this is the case.
Hope this helps
Stu
AnswerID: 506921
Reply By: get outmore - Sunday, Mar 17, 2013 at 00:09
Cracked head. Moderatly common
AnswerID: 506947
Follow Up By: auzinomad - Sunday, Mar 17, 2013 at 12:20
Could be collapsed lower radiator hose.
Lots of vehicles have a coiled wire like a spring in them to stop this from happening.
Look at the lower hose when hot and someone bringing the engine speedup to about 1500 RPM. If the hose sucks in there's your problem.
If not add it to the list of tests done to eliminate a cracked head or blown head gasket.
R
FollowupID: 784107
