confused about tube in tyres
Submitted: Monday, Mar 18, 2013 at 13:36
allein m
Ok I must have ran over a china man Saturday after driving all over
Broken hill dirt tracks ect on just legal tires we bought brand new set geotred dependa 1857514 and 3 weeks in and we get a flat Tyre turns out the tubeless valve need to be replaced.
first flat in years I must admit I have been lucky with tires
Now the spare is legal but has a slow leak so I asked fro him to put a tube into it and he said no way cannot do .
so is there a law or is it due to the way they make the tires if tubes are not safe why do the split rims run on tubes
I do remember years ago that's what they did for a slow leaking spare.
I asked the guy but he said he was busy
thank you for your help and opinions
Reply By: Wilgadene - Monday, Mar 18, 2013 at 18:03
Hi Allein m, very hard to find much about this so I can only pass on what I was told.
I had a slow leak in a tubeless tyre on my caravan while in outback Qld. I couldn't get a replacement because of the size and a cause of the leak couldn't be found at the time. I asked a tyre centre to fit a tube for me and he said that it was not acceptable to do that. The reason he said was that at highway speeds the heat build up caused by flexing and rubbing tube against tyre has been proven (by who??) to cause premature tyre failure and blow outs. He also said that the insides of tubeless tyres have been known to be quite rough and do cause abrasions to the tube causing them to fail. Sounded like logic at the time. (The cause of t he leak was later found to be faulty rims)
507053
Reply By: RobAck - Monday, Mar 18, 2013 at 18:22
Tubeless tyres are exactly that. Their design, in general terms, allows for slow deflation if you have a small puncture. Anything with a tube deflates immediately so creating a greater risk of an incident due to rapid loss of control. You will find that in most if not all jurisdictions it is therefore illegal to put a tube in a tubeless tyre and your insurance company will frown upon it as
well. Unless it is a really badly damaged carcass many can be repaired by the application of a decent patch but sometimes not at all. Hit a really big rock on a muddy track coming into
Broken Hill one year and whilst it could have been patched it would only have been OK for a rarely used spare so it was thrown away and it was new from
Adelaide so only crossed the Simpson
Split rims operate completely differently from tubeless tyres by design which makes them easier to pull apart to replace tyres. Having seen more than a few blow a retaining ring out after being put back together I know which I prefer and you will not find too many organisations with strong OHS&W policies that use them these days
Depends on the damage that causes the slow leak but it can either be patched and made completely workable or not
Rob
507057
Follow Up By: Bazooka - Monday, Mar 18, 2013 at 21:51
Rob
The supposed illegality has been discussed on many forums for years but I've yet to see any actual evidence to support it. Do you have a link to a regulation which might clarify the legal position? There have been plenty of comments re possible blowouts caused by the tube rubbing on stickers inside the tyres mainly but others saying they've driven for 10s of thousands of kms with tubes in tubeless tyres without problem. General consensus seems to be to only do it for "emergencies" .
784238
Follow Up By: get outmore - Tuesday, Mar 19, 2013 at 14:58
I call b.s
Ive checked the net extensivly and asked alot of tyre fitters as
well ad doing more than a few myself and found no evidence of lv split rims ever coming apart in normal operation or fitting.
Has happened with hvs but the construction for them is different
784310
Reply By: allein m - Monday, Mar 18, 2013 at 18:25
Thank you for your reply that does make a lot of sense cheers
507058
Reply By: Member - Frank P (NSW) - Monday, Mar 18, 2013 at 18:35
G'day allein m
I googled a bit and the consensus from tyre technical sources is that putting tubes in tubless tyres is unwise.
This exerpt from
this link gives a bit more detail than most:
"Automobile/Truck Tires
Do not install tubes into a radial automobile or truck tire. Most tubeless rims have a drop center. The drop center prevents the tube from making good contact with the tire. This can lead to damage to the rim or the sudden escape of air trapped beneath the tube and a drop in air pressure within the tube body. Tubeless tires have thicker sidewalls than tube tires. The inner tube helps support tube tire sidewalls, and this helps maintain positive contact between the tire and the inner tube. The stiffer radial sidewalls cause friction with the inner tube, and this can lead to failure of the tube or the sidewalls, and a sudden blowout while driving."
507059
Follow Up By: allein m - Monday, Mar 18, 2013 at 19:06
Frank P thank you
784221
Reply By: Rockape - Monday, Mar 18, 2013 at 22:14
allein,
on that old spare you could use a product like this.
Tyre sealant
They used it on all the machines where I worked to not only seal the tyres but to also make them easy to get off the rims. I ran it in tractor steer tyres because I was always getting stakes. Problem gone once I used it.
507078
Reply By: Member - Ed C (QLD) - Monday, Mar 18, 2013 at 23:22
A few years ago, one of my tyres had developed a slow leak, and I couldn't for the life of me find the source of the leak (using the soapy
water method)...
So down to Beau's I go, and says "This tyre's got a slow leak, can ya's fix it?"
Bloke says "Yeah, no worries, leave it with us and come back in a coupla hours" (or words to that effect)
Came back a couple of hours later, there's the wheel/tyre by the door, and I says "Is she ready?" .. Bloke says "Yep, all done, ready to go, that'll be $xx thanks"..
Pays the moneys, throws the wheel/tyre in the back, and away I go....
It wasn't until some time later, during a routine inflation/deflation/pressure check or whatever, that I actually noticed that the valve stem was ummm, "different"...
Turns out that they'd simply stuck a tube in the (tubeless) tyre.
Maybe they couldn't find the leak either...............
Since that time, said wheel/tyre has covered many thousands of kms (on highway & off-road), been from one side of the country to the other & back (via "the middle") at least 3 times (the last couple of trips on the c/t), and has been run at reduced pressures for much of the time....
I keep telling myself that "one o' these days" I'm going to rip that tyre off the rim, remove tube, and have another go at finding that d@mn leak, but haven't gotten 'a round tuit' yet ;-)))
Here's what Mick Hutton has to say about the matter >>
Beadell Tours - Tubes for Tyres
Note the reference to **Talcum Powder**
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
507085
Reply By: allein m - Tuesday, Mar 19, 2013 at 14:25
thanks for that i will put some of the sealant into the Tyre Ed C thanks
507135
Reply By: allein m - Tuesday, Mar 19, 2013 at 14:38
well worth reading thank you I am saving up to buy a landcruser standard with split rimes and that is information worth keeping
507139
