Restarting a Diesel Motor that has run out of Fuel
Submitted: Thursday, Apr 11, 2013 at 16:42
Member - Lynton B (QLD)
Hi Fellow Travellers: I am currently experiencing a problem with the
fuel gauge for the main
tank of my GU Nissan Patrol 4.2 Turbo Diesel. Even when I believe the
tank is nearing empty, the gauge shows 5/8 full. My concern is running out of diesel. I intend to have the gauge looked at when next near a Nissan dealer.
In the meantime, could some kind person advise me: What are the problems, if any, with restarting a diesel motor which has run out of
fuel? How do you start the vehicle?
The vehicle has a 30 litre sub
tank which in the past I have transferred when the yellow low
fuel warning light comes on. I have not been game enough to run the car so low in diesel to see if the warning light still works. I suspect not.
Reply By: Swartsy - Thursday, Apr 11, 2013 at 17:02
Just fill her up, crack one of the injectors and crank over the motor until she fires. Keep it running til she stops spluttering and farting then tighten up the injector and you will all good.
508744
Follow Up By: Ross M - Thursday, Apr 11, 2013 at 18:50
Swartzy
If the line is empty the battery may go flat and the starter will overheat/burn before you get the engine pump to prime and deliver to the inj pump.
Cracking one injector line will only bleed that injector IF and only IF the
fuel is being delivered by the injector pump.
Not what I would do first up.
Ross M
786340
Reply By: Dust-Devil - Thursday, Apr 11, 2013 at 17:04
Dude! How come you have all the luck.
This is what you do if the problem is definitely NO
fuel.
(1) Get some
fuel back into the main
tank.
(2) Locate the Diesel filter and on the top of the filter carrier there should be a priming device ( usually a black plastic/rubber disc of some description) that you operate up and down with the palm of your hand. This is a mini
hand pump that drags
fuel from the main
tank up to the filter.
(3) Once you have loaded the filter canister with
fuel and think you can't get any more into it, crank it over with the key and see if you can get it to start.
No start = more pumping on the priming pump until you get the
fuel up to the filter Pack. The lift pump should then drag it through. (usually)
(4) If you have a passenger, get them to crank it over whilst you operate the priming pump.
I've kept it simple simple and 9 times out of ten this will work. The tenth time may including bleeding the mother at the filter, or between the filter and the pump.
This is only for when you have RUN OUT of
fuel.
In the mean time use your trip gauge to avoid embarrassment/s. Zero it each time you fill it and then you know how many Kilometers you have done, and should know how many you can do before the
tank is dry again.
DD
508745
Follow Up By: pop2jocem - Thursday, Apr 11, 2013 at 18:52
All good info DD but I think your last paragraph was the most important piece of advice. Priming a diesel isn't rocket science but a nasty smelly job and easy to avoid. (;-))
Pop
786342
Follow Up By: Member - Keith P (NSW) - Thursday, Apr 11, 2013 at 21:11
Another little tip that just might help to get
fuel into the injector pump quicker. Undo the hose from filter to injector pump first (at the pump end if possible)...n stick the end of it in a container of some sort to catch
fuel...pump up the filter to full ..or until it stops bubbling air...reinstall hose ....and then operate
hand pump until hard. Crack 2 or 3 injector lines until motor tries to fire...tighten lines n it will go (
well..mostly) straight away. I used to do this everytime I changed
fuel filter...now I dont have to. Installed a lift pump ages ago...n now just turn key on until
fuel runs outa hose ...hook it back up n shes apples.
Cheers Keith
786370
Follow Up By: Member - Arsenal Phill - Thursday, Apr 11, 2013 at 21:36
I agree with DD. I used to have a dual LPG/Petrol patrol and I used to fill the gas by monitoring the trip meter. I wasn't happy with the diode meter that told me the gas level as it was difficult to see where it had been mounted, down by the steering column.
It was easy and became second nature to wait for my trip meter to clock up around 300-320 km's and fill her up.
786373
Follow Up By: desray (WA - Friday, Apr 12, 2013 at 11:52
Not a good idea to ,, Crack 2 or 3 injector lines ,, a lot of the newer Diesels will not reseat the injector pipes if you undo them ,they are a replace job if taken off .
786432
Reply By: Michael ( Moss Vale NSW) - Thursday, Apr 11, 2013 at 17:58
Lynton!
When you find the problem on the Patrol, let me know. I have the same problem. I have checked the
tank sender but looks ok but who knows? Michael
508752
Follow Up By: Michael ( Moss Vale NSW) - Thursday, Apr 11, 2013 at 18:01
Hmmm ! Don't know what happened there!!
786331
Follow Up By: Axle - Thursday, Apr 11, 2013 at 19:07
Looks like your Puter is running out of diesel as
well Mike!...LOL.
Cheers Axle.
786346
Follow Up By: Ross M - Thursday, Apr 11, 2013 at 19:13
G'day Michael
Is the Patrol sender a wire resistance type or an electronic capacitance type?
If it is a wire type, you may have a resistance problem in the line.
If it read higher than it should you may have a, partial earth or resistve connection to another appliance, of the wire to the
tank gauge which would make the gauge read higher than the true
fuel level.
Anybody done any wiring on the vehicle and added items?
Ross M
786350
Follow Up By: Michael ( Moss Vale NSW) - Thursday, Apr 11, 2013 at 19:41
Axle ! I'm getting old you know, maybe I had a little nap and my forehead hit the space bar! LOL. Michael
786355
Follow Up By: Michael ( Moss Vale NSW) - Thursday, Apr 11, 2013 at 19:47
Ross , its the old resistance type, it all looked good but I couldn't check as my multi meter died. Some Patrol owners say normally a solder joint or something obvious is the problem but it all looked good. I'm not keen on buying a new one until I can be sure its the problem, about $350 for a GU sender and about $80 for a GQ. Michael
786357
Reply By: Member - Morry H (WA) - Thursday, Apr 11, 2013 at 19:08
hi disconnect all batterys for around 30 mins to reset the computer there is a chance that it will zero the
fuel gauge back to default morry
508764
Follow Up By: Michael ( Moss Vale NSW) - Thursday, Apr 11, 2013 at 19:50
Morry! I had the battery disconnected for a day when my two batteries passed away a few weeks ago, it made no difference but I appreciate the info. Michael
786358
Reply By: Michael ( Moss Vale NSW) - Thursday, Apr 11, 2013 at 19:51
Sorry Lynton, I didn't mean to hijack your Post. Michael
508767
Reply By: Life Member-Doug T NSW-Ex NT - Friday, Apr 12, 2013 at 03:09
My old 94 Troopy will fire up after around three or four 15 second cranks on the starter.
508793
Follow Up By: pop2jocem - Friday, Apr 12, 2013 at 09:37
Aww c'mon Doug
You not trying to tell us that when an "old tech" diesel like yours or
mine runs out of
fuel you don't have to dance around it 3 times waving a feather adorned rattle, kneel in front and kiss the 'roo bar and then get it towed to the nearest dealer and have the putor re-programmed????
Pop
786417
