Automatics and low range descent - transfer cases
Submitted: Monday, Feb 02, 2004 at 18:21
Drew
I have a 100 Series petrol automatic. The car is great and overall I am happy with it. The only thing I would change is low gearing for downhill descent. Since Low Range is engaged at the transfer case, is it theoretically possible for a rock crawler type gearing to be installed for Low Rang Low Gear use only? I am not particular gifted in the mechanical area but thought maytbe someone could enlighten me.
Reply By: Member -Bob & Lex (Sydney) - Monday, Feb 02, 2004 at 20:55
yes, try Marks or rockhopper they are about $1000. Just do a google search or try a business search on this siteRegards Bob
Where to next
45216
Follow Up By: Truckster (Vic) - Monday, Feb 02, 2004 at 22:27
Nope, Does he mean just the 1 gear, or the whole range, cause Marks and Rockhoppers affect the whole of Low Range, not just 1 gear, or am I reading it wrong.
307334
Reply By: Eric.- Monday, Feb 02, 2004 at 21:58
From what I have heared , you can add a second transfer case with lower gears , for your down
hill desent , I am looking at the moment for something similar for my auto 80 series . If you change your ratio in your transfer case, you may not like the drive you get when low rance is needed for climbing . If Truckster see's this post he will point you in the right direction. He is the guru when it comes to these mods .
Venus Bay
45223
Reply By: Truckster (Vic) - Monday, Feb 02, 2004 at 22:35
There are 2 things you can do.
1) Add a second transfer case, which will give you multi ranges
HIGH HIGH
HIGH LOW
LOW HIGH
LOW LOW (you can put Marks or Rockhoppers in the second transfer case, giving you the Ultimate!!!)
2) add Marks or Rockhopper Gears, but this changes the whole of low range, 1st,2nd,Drive in Low range.
1st option
Advantage
You can still cruise along in low range as you do now.
Cheaper than Rockhoppers to buy ($1000 V $1200)
Disadvantage
Depending on your car, you can have viabration issues from the shorter tailshaft.
More expensive than Rockhoppers to install
2nd option
Advantage
Transforms the car, cheaper and I think better option.
Easily reversable if you want.
Disadvantage
You cant cruise along in low range as you do now on general firetrails with a few hills etc which would be annoying.
Food for thought.
45228
Follow Up By: Drew - Tuesday, Feb 03, 2004 at 16:30
I had a reply from Marks. They have a product called a cruisercrawler but it costs $3500 and requires mods to the vehicle height (2 inch lift which is already done) and the
fuel tank. Out of my league for this purpose.
307403
Reply By: Member - Raymond - Tuesday, Feb 03, 2004 at 07:42
Hi Drew
Depends on how much offroad and the type of offroading you are doing. We were away for the weekend and two of the vehicles were autos, both petrol and they handled the tracks around
Licola with no problems. The patrol had one advantage that it could use it transmission brake, which sadly toyota does not have. Other friends have fitted rock crawlers and are rapped in them, they just have to change back to high range if they are on fire
trails that are fairly flat
Raywanderin' in retirement. victor 2010
45248
Follow Up By: Drew - Tuesday, Feb 03, 2004 at 16:32
I am still waiting on info re the rockhopper. Changing back to high does not bother me. I just want to be able to crawl down slippery steep hills without the sliding going on quite so much.
307404
Reply By: Member - Jeffrey - Tuesday, Feb 03, 2004 at 10:56
Hi Drew
I have the same problem ( condition ) my patrol really gets goig down
hill , but luck has one of my club mates has been there done that ! all he done was change the torque converter, works a treat, all up he spent aproximately $660.00. Hope this helps.
All The Best In Health And Wealth
Jeff
45264
Follow Up By: Drew - Tuesday, Feb 03, 2004 at 16:33
It would if I knew where I can get the beast. Do you have any ideas where I can buy a torque converter?
307405
Follow Up By: Member -Bob & Lex (Sydney) - Tuesday, Feb 03, 2004 at 17:08
I'd be interested toRegards Bob
Where to next
307406
