watts to amps?
Submitted: Thursday, Feb 05, 2004 at 19:24
ThreadID: 10301 Views:2699 Replies:2 FollowUps:10
Hi all, looking at a fridge & it uses approx. 70watts, how many amps is this?
Thanks in anticipation,
Rowler (dave)
Reply By: whyworry - Thursday, Feb 05, 2004 at 19:29
e=ir answer 12v 5.8amps. 24v about 3amps
AnswerID: 45588
Follow Up By: Rowler - Thursday, Feb 05, 2004 at 19:33
Thanks for that, I was off searching the web for the answer.... should have done it before.... well it gave you a chance to show your knowledge on the subject.
Got the same answer too!
Cheers Rowler (dave)
FollowupID: 307662
Follow Up By: Member - Ross - Thursday, Feb 05, 2004 at 19:41
Almost correct .. but no quite.
E=IR
i.e Electromotive force (E) = Amps (I) x Resistance (R)
Note E can be taken to mean V
Absolutely correct formula but without a value for R you cannot arrive at the answer.
Try P=VI
i.e. P (Power (Watts)) = Voltage (V) x Amps (I)
Hence 70 = 12 x I or I = 70/12 = 5.8333
Correct answer but stuffed if I know how ya got it.
................. ;-D
CheersFidei defensor
Rosco
FollowupID: 307663
Follow Up By: whyworry - Thursday, Feb 05, 2004 at 19:48
sorry been pulling the plow for to long not using grey matter
FollowupID: 307665
Follow Up By: Rowler - Thursday, Feb 05, 2004 at 20:01
I looked up some web page & it said.... Watts/Volts=Amps
Same answer too :-)
Thanks Rowler (dave)
FollowupID: 307668
Follow Up By: Member - Ross - Thursday, Feb 05, 2004 at 20:02
Ya get that ... knock off and have a beer.
Rosco
FollowupID: 307669
Follow Up By: V8troopie - Friday, Feb 06, 2004 at 00:52
If you want to be *really* pedantic you got to allow for that a 12V battery is pretty flat if you measure 12V on the terminals.
Try doing the calculation again, using 12.6V as per fully charged battery.
Even more pedantic, if you run the fridge while the engine is charging the battery, use 14 - 14.5V for your calculation.
Klaus
FollowupID: 307710
Reply By: Brian - Thursday, Feb 05, 2004 at 19:56
Rosco,
I once worked with a "Rosco" here in the big Sid er nee. He moved to Qld, and we lost contact. You don't happen to live in Brisie do you?
Brian
AnswerID: 45591
Follow Up By: Member - Ross - Thursday, Feb 05, 2004 at 20:00
Brian
Certainly do .... born and bred ... should I say dragged up.. in these parts.
Never worked in Siderley. Great place to visit ... wouldn't want to bloody live there tho'
Fidei defensor
Rosco
FollowupID: 307667
Follow Up By: Brian - Thursday, Feb 05, 2004 at 20:10
Thanks for the reply Rosco. My mate Ross was (is, me as well) a sparky, and you sound like one.
Catch you 'round
Brian
FollowupID: 307670
Follow Up By: Member - Ross - Thursday, Feb 05, 2004 at 20:16
Worse .... ginger beer.........................Fidei defensor
Rosco
FollowupID: 307671
Follow Up By: Brian - Thursday, Feb 05, 2004 at 20:48
Can't help bad luck.
Brian
FollowupID: 307673
