silicon seals
Submitted: Thursday, Jul 18, 2013 at 08:59
Member bronty
gooday The silicon seals on our 10 month old supreme van are turning black,appears to be mould .Should i be worried.Any ideas how to remove said mould without damaging silicon
thanks in advance
Tony
Reply By: Les - PK Ranger - Thursday, Jul 18, 2013 at 09:45
Tony, is the mould on the outside of the silicone, or underneath ?
If on the outside, have you tried a weak solution of White King or similar bleach ?
Maybe
water down 10
water to 1 bleach to try, use an old tooth brush or stiff old paintbrush.
Silicone is pretty resistant to almost all checmicals I can think of, nothing removes it afaik.
514942
Follow Up By: Lyn W3 - Thursday, Jul 18, 2013 at 10:53
And if the mold is underneath the silicone then you have a real problem.
Mold generally means there is an underlying problem with mold spores trapped in a moist environment through poor manufacturing standards.
If the mold is under the silicone simply stripping out the silicone and reapplying will simply be a temporary fix.
794120
Reply By: hamo - Thursday, Jul 18, 2013 at 10:59
My 24' territory done the same.
Caused by the wrong silicon used.
As yours is still under warrenty, Id have Supreme repair the silicon.
You wont be able to remove the mould with out removing the silicon (i,ve tried)
Hamo
514946
Follow Up By: member - mazcan - Thursday, Jul 18, 2013 at 11:37
hi bronty
if its on the outside use truck-wash CT18 from
supercheap and a stiff brush
i have successfully used this method on my old van after it sat through winter and spring and grew mould on 3 different occasions but if its underneath the silicon surface then its as said above al-cheapo silicon has been used and it needs to be all stripped off and resealed with quality sikaflex silicon
there's far too many caravans been built these days with al-cheapo methods that's why so many of them leak
water and if the joints been sealed are not free of dust before the silicon is aplied then it doesn't adhere properly to the joint in the first place and will leak and start mould and allow
water intrusion
the caravan industry doesn't have very little quality control and companies rely on there staff to do the right thing but there is huge amount of evidence that this doesn't always happen there are plenty of horror stories of buyers of new vans experiencing
water damage after there first trip away
I hope yours isn't one of them
794123
Follow Up By: Member - Boo Boo (NSW) - Thursday, Jul 18, 2013 at 13:41
G'day Bronty
Every now and then I have had mould on our awning and pop top.
I find cleaning vinegar easy to use. Just spray it on and use a soft bristle brush, then wipe off and bobs your uncle.
Oh, leave the vinegar for about 1 minute or so before the brushing.
794131
Follow Up By: Member - Wozikev - Wednesday, Jul 24, 2013 at 16:59
X2 for the Truckwash, it works a treat.
..........................Kev.
794538
Follow Up By: Rockape - Wednesday, Jul 24, 2013 at 21:14
Boo Boo,
I love vinegar. It does the job, big time.
794579
