TD42 Fuel Pump issues
Submitted: Saturday, Aug 03, 2013 at 20:34
MNW
Hi all,
I have a 91 GQ TD42 with 240,000. I was hoping that someone could give me some advice regarding the
fuel pump. The engine seems to hunt especially when cold and at low RPM i.e. in
forth at 60k. It doesnt really get cold up here in
Townsville but I always let it idle and warm up for a few minutes anyway. I dont know anything about this particular pump and was wondering if I should have the pump reconditioned or atleast tested on a dyno. Also I know that introducing a turbo is really worth the cost but the state of the pump is my real concern. Does anyone know what may be causing this. I have removed the gauze filter and I get roughly 650k around town from a full
tank. I add diesel plus to every second
tank and service every 5000k.
Reply By: Axle - Sunday, Aug 04, 2013 at 09:42
G/Day Mate, Are you sure its the pump.?..sounds more like a issue with air getting in the system, ..If its not blowing heaps of black smoke I would look elsewhere first.
Cheers Axle.
515880
Reply By: member - mazcan - Sunday, Aug 04, 2013 at 13:54
hi MNW
gauze filter is that the one in the
fuel pump inlet pipe ?
surging in a diesel is usually the result of either air in the system or a filter partially blocked with dirt or
water contamination
I would change your
fuel filters and clean out the
fuel bowl etc and renew all the orings/seals then bleed the system sounds like
fuel flow/air problem to me
that's what ive found over many years of diesel experiences
515889
Follow Up By: member - mazcan - Sunday, Aug 04, 2013 at 13:58
also drain your
fuel tank if it has a drain bung
you will get a surprise as what comes out
it an old vehicle '91 and the
tank has had a lot of
fuel through it
795172
Reply By: Member - nick b - Sunday, Aug 04, 2013 at 20:46
MNW : A mate of
mine has one of these vehicles & i think similar problem , he was ready to replace pump but when he took it to his mechanic he replaced a small filter in side banjo fitting at the end of
fuel pipe to the pump , all fixed .
when you say (I have removed the gauze filter) is this the same filter ....you removed it or replaced it ?? ....when ?
515922
