Sunday, Aug 11, 2013 at 11:01
Unfiortunately people have an over simplistic view of the old points ignition.
There is quite a variety of things that can effect what is happening with points.
Because it is a transformer system, what happens at the spark plugs can be refleced back thru the coil into the points.
Our points system of ignition works on the principle of back EMF and a colapsing field causing a spark......and a spark occurs both at the spark plugs and at the points.....we attempt to surpress this spark at the points with a capacitor (condensor) but it is only partly sucessfull at best.
The capacitor is selected bassed on what is known at the time the vehicle was built.
Variations in spark plug, spark gap, compression, dwell, ignition timing and several other things can send this all to pot.
Back in the day when I was running Mazdas, I got sick and tired of cleaning and replacing points, we tried all sorts of things.
We concluded that because i was running more advance and some of the engines where a little tired, this may have been the problem.
Anyway, I built up a transistor assisted ignition from an electronic kit and it was great, I ran the same ignition in 3 cars. The only reason I had to touch the points after that was because the heel block would wear on the dissy lobes and require adjustment.
This particular ignition also gave some extra advance at high RPM, which realy was an improvement.
If you are running gas, and it is running
well you will be running masses of extra advance.
If you are running dual
fuel, the single best thing you can do is get hold of a dual curve ignition.
Back in the day I had a bit to do with LPG vehicles, a mate ran a couple in competition & I drove cabs for a while.
Let me tell you if you are running dual
fuel and you do not have an ignition system that does not adjust the ignition advance between petrol and gass it will be running like a dog on one or the other if not both.
Cant help you with what is available now..sorry.
795522
