Wednesday, Aug 21, 2013 at 12:00
The overloading of dual cab utes has been a very real issue for a very long time.....but it is no lesser issue than the overloading of station waggon 4WDs.
I don't know how may dual cab utes I see every day dragging there asses down the road because they have nothing in the front and the whole payload minus the driver sitting behind the rear axle.
One thing we need to undestand is that most passenger carrying is designed around a 75Kg person.
Walk around most building sites and you will be hard pressed to find too many under 75Kg......I don't know about other posters, but I and my doctor would be very happy If I was 75KG..but I'm not.
OH then you look at the published towing capacities on some of these utes, and realise that to achieve that towing capacity the carried load has to be reduced.
For example the mall weight has to be deducted from the payload carried
On another
forum, one of the learned members posted a spread sheet of most of the modern utes listing towing capacity, GVM, permissable ball weight, gross combination masm and some other stats.
It was very interesting.
One of the utes with a generous towing allowance..it worked out to tow capacity, all you would have in the ute was a reasoably slim driver, and equally slim mate, their lunch and a small too box.
One poster on another
forum was scratching his head why he was over loaded in his nice station waggon 4wd.
The original spec's where posted, showing about 600KG total payload, the probable weight of accessories, gear and those aboard and he was hundreds of KG over weight.
Look at some of these waggons with 600ish KG payloads even unadorned by accessories.....If you put 5 average blokes, an overnight bag each and slab of beer ( no ice) and you have just about pulled up the weight limit.
People do take carrying capacity very much for granted.
516843
Follow Up By: pop2jocem - Wednesday, Aug 21, 2013 at 12:17
Yeah right on. Yesterday we were pulled up at a set of lights when a dual cab (Triton I think) pulled up beside us. It turned out it had WA government plates and looked like a DEC vehicle.
There were three reasonable size blokes inside and on the back was about a 300 litre
water tank together with various pumps, hoses, tool boxes and what looked like different size fire extinguishers. This ute also had at least 3 radio aerials, revolving and work lights and who knows what other stuff. It also had a long range
fuel tank because I could see the extra filler cap and a 'roo bar. I didn't get to see the front but I know most of their vehicles are fitted with
winches and auxiliary batteries. Would have been interesting to see what that lot weighed.
Pop
796350
