Led Lights
Submitted: Thursday, Sep 05, 2013 at 09:16
BJ & Reen
Good morning folks I have purchased a led replacement instead of fluro it is a D Fluro Led Bulb -84 SMD I have by passed the starter from the fluro but when I turn it on it goes very
well for about 5-10 minutes but then starts to flicker if I turn it off and then back on same story wondering if anybody can shed some light (pardon the pun) on the subject
Thanks BJ
Reply By: Kazza055 - Thursday, Sep 05, 2013 at 12:19
I would say it is on the blink. ;=))
517675
Reply By: Notso - Thursday, Sep 05, 2013 at 16:54
Are you sure you've bypassed all the electronics, not just the starter, in the Flouro system.
They should be hooked directly into your 12 volt power. Providing it is 12 volts not 240?
517687
Follow Up By: BJ & Reen - Friday, Sep 06, 2013 at 09:20
Yes Notso hooked directly into 12 volt I think Kazza might be right
797449
Follow Up By: Terry 12 - Friday, Sep 06, 2013 at 21:09
I am having the same trouble with a 84 led fitting, phoned supplier and they are sending me a replacement.
797481
Reply By: The Bantam - Saturday, Sep 07, 2013 at 10:36
we have to get this straight.
There are different products designed for different applications.
There are LED fluro replacements designed to go directly into 240V fittings.
In this case you need to do exactly as the instructions say.
When you say"bypass" the starter what do you mean.
It occurs to me that most of these 240V LED fluro replacements simply require the starter to be removed...that is a different thing to being bypassed.
The starter activates the heaters in each end of the fluro tube and causes a striking voltage from the balast when it opens......none of this is required for LED.
If it is a 12 volt fluro replacement.....that could be a straight forward 12 volt LED array.
The original 12 Volt fluro would have been driven by an inverter....that is a different thing to a starter.
If you have a 12 volt fluro that is running an inverter and you are putting a 240V LED fluro replacement in that fitting, you may have problems because most of the inverter fluros do not operate at 240V and 50 Hz as a conventional fluro does.
You need to know what you have.
517768
