Tuesday, Oct 01, 2013 at 22:11
You will need
the springs extra height/weight carrying ability if you are going to tow and also fit a larger
tank. So keep
the springs or you haven't gained anything, and the ride height without
the springs and also the
tank will mean the
suspension will be so low you won;t have sufficient upward travel left to absorb road undulations and bumps etc.
You have the same as me and with around 80 to 90mm between the axle tube and the bump rubbers on the rear you will require wedges in my opinion.
If you have a low speed takeoff, pull away shake/shudder, it is the centre bearing flicking sideways in it's housing because the centre bearing uni, (just rearward of the centre bearing) is now operating with too much angle. 1st and 2nd are worst.
It is annoying and will eventually damage and destroy the centre bearing rubber mount if left that way.
The wedges are 120mm long and 60mm wide with a 10mm hole in centre. Usually 3 degrees is required.
Mine is 2 1/2 degrees.
Centre bearing needs to be lowered between 15 and 20mm. A special bracket does that. Not available in shops though, they don't know anything about such a bracket.
Are you in Victoria by chance?
About the
tank.
When fitting, get the people to place a loop of nylon string around the
fuel float and have the two ends come up
the neck and out the filler. That way you can connect the electrics and check to see if lowering and raising the float fully as
fuel would do to make the gauge work correctly, Some don't and find out afterwards. Pull one string to remove.
Also get them to ensure the
fuel pick up is at a suitable distance from the
tank bottom. Recently one newly fitted aftermarket
tank sucked air when 1/3 of
fuel remained in the
tank. Excuse was wrong pipes connected. Total rubbish, as all piping is in the OE tank/pump unit base.
PS If you want it to handle replace the front shocks if they haven't already been replaced. I changed
mine at long before 10,000km from new. Nice shocks, they just don't work.
Ross M
799012
