Friday, Oct 04, 2013 at 12:48
Will - That's a really nice tidy old BJ40, and there's a lot of kms left in her yet.
Whether it's worth $5000, is up to how desperately you want it, and how keen and negotiable the seller is.
IMO, I'd consider that $5000 is a little high, seeing as it needs some work and it isn't registered. Getting her up to rego requirements will always require another $1000 you didn't see, or count on.
The Redbook Private Sale Price Guide gives the private sale value of this vehicle as between $2200 and $4900. $2200 would be for a rough example - $4900 is for a top-condition, ready-to-drive-away rig.
Accordingly, I'd say about $3750-4000 is around the proper value for this vehicle. You may be happy to pay a little more, if it's close to home and the indicated repairs are not as much as first appears.
The 4 speed Cruisers pedal along O.K. at 100kmh. The 5 speed transmission allows the engine RPM and noise levels to drop, and improves the
fuel economy by probably 5-10%.
Anything over 100kmh, and the 4 speeds start to rev out, make a lot more noise, and use more
fuel.
Remember the old 'Cruisers are pretty agricultural - they're rough riding, noisy, heavy on the steering, and aren't a comfortable long-distance vehicle.
However, from what you've described, this vehicle will fit your requirements to a T - and it has the advantages of being simple to fix, it has proven go-anywhere ability, and parts are cheap.
Everything you ever wanted to know about the early 'Cruisers, is contained in the vast repository of info, on the following website - from the first 'Cruiser designs - through every model change, every body style, S/N and ID info - tips and tricks - and even the various engine swaps, if you like doing that kind of thing.
Despite the website being American, it does cover the Australian models as
well - which is rare to find. Good luck.
http://rustybrain.com/cruisers/faq.txt
799195
