motorised jockey wheels
Submitted: Sunday, Nov 24, 2013 at 12:00
ThreadID: 105241 Views:9553 Replies:6 FollowUps:3
good morning everyone, Does anyone have experience with a motorised jockey wheel? Ihave a jayco 16ft discovery and was wondering how good these are. What capacity do they have to push a van up an incline into a garage? thanks johno
Reply By: Notso - Sunday, Nov 24, 2013 at 12:18
The motorised wheels need a fair bit of weight sitting on them to drive a van up an incline.
The other type with a ribbed roller running on two of the van main wheels work better for that type of work.
A friend tried both before he settled on the ones that drive the main van wheels.
AnswerID: 522025
Follow Up By: Steve M1 (NSW) - Sunday, Nov 24, 2013 at 18:49
if you got somebody to stand/sit on the A frame and maybe somebody else help to shoulder the weight pushing up the hill, would that help?
I know it sounds like a bit like defeating the object but if it helps to get the job done???
FollowupID: 802939
Follow Up By: Notso - Sunday, Nov 24, 2013 at 19:25
Yeah, especially if I was the one sitting on the draw bar.
FollowupID: 802943
Follow Up By: Steve M1 (NSW) - Sunday, Nov 24, 2013 at 21:45
oi....I wanted the easy job - big fella like you can get your shoulder into it
FollowupID: 802961
Reply By: Skulldug - Sunday, Nov 24, 2013 at 16:43
Johno,
I agree with Notso (this could only happen in Australia):
I used an easy mover type jockey wheel to get my 16ft Jayco out of my driveway and it will work but only on a very slight incline. The lack of weight over the jockey wheel is the problem.
Skull
AnswerID: 522032
Reply By: Ron N - Sunday, Nov 24, 2013 at 22:49
Johno - I'm not sure what % of incline or gradient you are talking about - but remember, if you're driving a van up an incline, you need to have a pretty sizeable weight of device driving it.
If you used a motorised wheel, and it lost traction, and the van took off, you have no control then whatsoever, as regards where it goes.
As a result, full control when pushing the van up that incline, is what you're seeking - and that can only be done by a push device (or vehicle) that nearly approximates the weight of the van.
The alternative is to set a solid pull point in the garage floor or wall, and attach and use a portable electric winch to pull the van up the incline.
I have a 2000lb electric winch that I carry around in an old Army ammo box for pulling disabled items onto my tiltable tandem car-carrying trailer.
I have an attachment point on the front of the trailer where I sling the winch from, to pull disabled equipment (that can still roll) onto the trailer.
It works a treat, and it can pull a 2 tonne vehicle easily up a 30 degree incline.
I would never consider pushing a heavy item up an incline with anything less than something at least around 2/3rds the weight of the item I'm trying to push.
Cheers, Ron.
AnswerID: 522054
Reply By: Slow one - Monday, Nov 25, 2013 at 06:57
Johno,
Have a look at this lifting winch. It could be used for pulling. Radio control, auto locking and the pull ratio could be multiplied by the use of extra sheaves.
You would just need a backup safety brake man ready if things turned pear shaped.
Winch Link
AnswerID: 522062
Reply By: AdrianLR (VIC) - Monday, Nov 25, 2013 at 19:13
I posted a review of one type on the MySwag forum:
Motorised jockey wheel review
Another diy design is posted later in the thread which may be more suitable to you application.
Adrian
AnswerID: 522089
Reply By: wombat28 - Thursday, Nov 28, 2013 at 12:28
I have a 4 wheel boat trailer that I have to manoeuvre into a small carport which also requires a 90 degree turn . I purchased a 'Parkit 360m' [I think there were 3 sizes]
It connects directly onto the trailer ball, it is driven by a 12v electric motor, driving 2 large rubber wheels . To complete the 90 degree turn I place 2 'Hydraulic vehicle Positioning Jacks' under the back tyres and it turns easily .
I biggest problem I have with the PARKIT is that it is 'fiddly' to connect to the ball of the trailer - [ I might need more practice !]. There is a Parkit importer in Melbourne- there was website with more details
AnswerID: 522245
