Monday, Dec 09, 2013 at 15:21
Hi Peter,
Certainly some people do separate the two batteries in the 100 series, retaining one for the engine and vehicle electrics, and using the other as a deep cycle battery for household purposes. I hope someone who’s done this will comment here. My personal suspicion is that Toyota had good reasons to provide that second battery. My other thought is that it would be better if the battery powering the fridge was closer to the fridge. If in a trailer or van, then certainly I’d opt to have the battery there too.
Re dc-dc chargers. These chargers provide the charging regime required for the battery – initially a constant current stage during which the battery (and fridge) voltage rises to a preset value set by the user to suit the battery type. This is followed by a phase where the voltage remains fixed at that preset level and as the battery approaches fully charged, the charging current drops. Once the current has dropped to a low value the charger switches to a lower “float”voltage to maintain a trickle of current into the battery. The critical factor is that preset voltage, which will typically be set at 14.4 volts for most deep cycle batteries, a little less for gel types, and maybe up to 15V for calcium doped batteries. (These voltages are roughly what your alternator will supply to the starting battery/s.) Most dc-dc chargers also offer the facility to act as a simple power supply delivering up to their rated current at about 13.4 (usually) volts. All these voltages are within the normal range to be found in a vehicle.
The quick chargers that Engel refers to are probably the big mains powered ones that use higher voltages to force charge rapidly into the battery – best avoided in my opinion. The Engel site doesn’t give voltage specs for their fridges, so might be worth asking them just what they mean by “excess voltage”. I would not consider the voltages supplied by a dc-dc charger to be “excess”, but for the sake of your warranty best to ask Engel just what they mean. (FWIW, our Waeco is quite happy to run from the dc-dc charger.)
Is there an easy way of bypassing a dc-dc charger and charging directly from the alternator. Yes! On one trip our alternator failed and I turned the charger around 180 degrees (electrically that is) so as to charge the starting/vehicle battery from the house batteries and roof-mounted solar panels! (Our Troopy is petrol powered, so no electricity means no ignition.) How? Anderson plugs. The line to/from batteries and the line to/from alternator are both fitted with anderson plugs, so can be connected together to provide direct charging. The dc-dc charger is fitted with anderson plugs on input and output and inserted (electrically speaking) between the alternator and battery anderson plugs. (In speaking of connecting to the alternator here in fact the connection is via a circuit breaker and voltage sensitive relay to the vehicle battery, which in turn is connected to the alternator. )
Hope that makes sense!
| J and V
- Albert Einstein
803968
