CTEK vs REDARC
All,
I have just bought a camper trailer and had the 240v kit installed into it, but for some reason this does not include a battery charger. ???
It runs a 100A/H lead free battery
I want to mount this charger permanently inside the trailer so that every time we connect the 15A lead into it that it chargers the 12v system, I have been onto CTEK and RED-ARC and find allot of information that is well above what I know. In reading CTEK have awesome reviews as well as RED-ARC. so not fused in which brand I use, just as long as it does the job and is small to fit under the bed behind battery box.
Reply By: Penchy - Friday, Dec 27, 2013 at 09:25
I use a Ctek and it works fine
AnswerID: 523553
Reply By: HarryH - Friday, Dec 27, 2013 at 09:43
Redarc, Aussie made and great quality and aftermarket service.
AnswerID: 523554
Reply By: Mick O - Friday, Dec 27, 2013 at 10:51
Brenden, trust you had a happy Xmas.
This has been talked about quite a lot and pops up as a regular topic. It can be quite polarising at times. A search of the forum will provide you with any number of threads on both. Here are a few links that may assist.
Redarc-Ctek search No. One
Ctek-redarc search two
CTEK Vs REDARC
I prefer and use Redarc products myself. Personal choice based on range, quality and more importantly, Australian made and serviced. That's not saying anything derogatory about CTEK, just a personal decision made on research much like you are doing.
I have reviewed the products I use here;
Redarc Review on EO Blogs Section
Hope that helps with your choice. All the best for the new year and 2014,
Mick
AnswerID: 523556
Follow Up By: Member - Brenden H - Friday, Dec 27, 2013 at 11:17
Thanks for that, great review, As Redarc is Aussie made, thats made my mind up,
FollowupID: 805045
Reply By: oldtrack123 - Friday, Dec 27, 2013 at 13:41
Hi Brenden
It seems to me that you only want a 240V charger ??
The Redarc units can be found with ALL the bells &* whisles for charging from multiple sources[ONLY ONE source at any time ]alternator, solar, mains.
But if you if you only want a 240V charger to simply plug into a 240 outlet ,they are an over kill
Best to get a top grade MAINS charger
"LEAD FREE" battery ,can you be more specific ?
That may determine just what abililties the charger will need to have!!
PeterQ
AnswerID: 523558
Follow Up By: oldtrack123 - Friday, Dec 27, 2013 at 13:49
HI Brenden
Sone other questions
[a]How is the battery charged at present?:
[b]From the vehicle alternator?
[c]IF so, by a direct connection from the vehicle battery?
IF[ 'b] & [c] does it CHARGE sucessfully ??
IF it does YOU HAVE NO NEED for a DC/dc charger such as the REDARC OR the Cetek DC/ DC charger
PeterQ
FollowupID: 805047
Follow Up By: Member - Brenden H - Friday, Dec 27, 2013 at 14:02
Hi Peter,
The only way the battery charges now is thru one of those 50amp plugs from the car when the trailer is connected. I want to be able to sit that camper trailer say in a caravan park with the 15a lead that will keep the battery charged to run everything like fridge and lights while parked so I do not have to connect to the car to charge the battery. Hope that makes sense?
Brenden
FollowupID: 805050
Follow Up By: oldtrack123 - Friday, Dec 27, 2013 at 23:40
HI Brenden
Just a word of caution .
Some people get carried away with the need for DC /Dc chargers!!
If your trailer battery is satifactorily charged from the vehicle alternator ,when driving, you may have little neeed for a Dc/DC charger
The charge abilty of the direct connection will depend on TWO factors :
[a]The alternator peak voltage that it charges the CRANK battery to
[b]the Size of the cables to the trailer battery with regard to CABLE RUN LENGTH
I do hope you have some form of Automatic isolation between the car & trailer battery ??
A multi stage MAINS charger could well be ALL you need.
But please confirm the ACTUAL battery TYPE you are using
A MAINSs charger would not need to be anything like the 40A some suggest for a Dc /Dc charger
It should be just large enough to supply your max Current being used plus about 10A for 110Ahr LEAD ACID battery
Note: A bigger charger does not necessarily mean the battery can use ALL that Amps
The accetpance capacity of the battery at the CHARGER's boost voltage determines the max current the battery can draw
PeterQ
FollowupID: 805074
Follow Up By: Dennis K - Wednesday, Jan 01, 2014 at 18:07
Hello
I maybe unpopular but I would go a Projecta.
You can select what battery type and it will automatically do the charging for you.or it can be a 12 volt supply.
I just purchased the 2500.its 25 amps.i have a calcium battery 170ah .the charger has a 7stage cycle to keep the batty in. Perfect condition.
Even if yo u have a lead acid you can use the projecta charger.
They are standard figment on coramal caravans now.
Mine comes with a remote to control and monitor battery condition and charging.
Purchased from good old eBay.
Dennis
FollowupID: 805296
Reply By: Member - Cruiser74 - Friday, Dec 27, 2013 at 17:17
I had the same decision to make recently. Got some great advice from the guys at Challenge batteries in Perth. They pretty much said that the C-tek is great value and does exactly the same job as the Redarc. Advantages of Redarc is a slightly more robust unit and a higher level of after market service. Very hard to organise warranty claims with C-tek but pretty much no questions asked with Redarc, even if you are remote they will assist with getting you a new unit. Worth the extra few $$ long term.
AnswerID: 523562
Reply By: Member - Bruce C (NSW) - Friday, Dec 27, 2013 at 18:31
Hi Brendan,
As you are leaning toward the redarc then that is the way I would go in this instance.
Buy the biggest amp output you can afford, say around 25 amp if possible, as you are charging a big battery.
The faster you put it back in the longer the battery will last provided you use a multi stage chager of course such as a redarc or ctek. These will protect your battery.
Not only that but you will have some capacity in reserve so that if you decide to increase the number of batteries you will have room to accommodate them and you will have put your money into one charger, not the wrong one first then the correct one later when you found you probably had made a mistake by buying too small.
This is my observations based on my experiences anyway.
There are several others on the market but Aussie made is a better choice in this instance.
Cheers, Bruce.
AnswerID: 523569
Follow Up By: Member - Frank P (NSW) - Friday, Dec 27, 2013 at 22:02
"The faster you put it back in the longer the battery will last provided you use a multi stage chager of course such as a redarc or ctek. "
Not necessarily, I'm afraid.
Generally, the SOONER you recharge a battery the longer it will last in calendar terms. That does not necesarily mean that you should hit it with a charger with the highest output you can afford, even if it is multi stage.
Many, but not all, deep cycle and dual purpose lead-acid batteries, have a specified bulk charging rate of 10 to 15% of their C20 Ah capacity. So a 100Ah battery might be best charged at an initial rate of 10 to 15 amps.
Additionally the OP said he had a lead-free battery, so we don't know what the chemistry is and what the charging regime should be. Until we know that we are all shooting in the dark.
FollowupID: 805069
Follow Up By: Dennis Ellery - Friday, Dec 27, 2013 at 23:33
It depends on the quality of the battery.
If you have a low resistance battery you can charge it at a much higher rate
My 150 ah battery can be charged at 200 amps or more.
FollowupID: 805073
Follow Up By: oldtrack123 - Saturday, Dec 28, 2013 at 15:16
HI Dennis
Perhaps NAME the battery??
PeterQ
FollowupID: 805092
Follow Up By: olcoolone - Saturday, Dec 28, 2013 at 21:49
Yeap agree, slower the charge the better BUT seeing we don't live in the ideal world charging batteries is a compromise just as the application we use the batteries for.
Getting back to the ideal world; a battery should never be discharged more than 5% as in standby power systems where batteries last 20 years..... in critical care applications it's 10 years before replacing.
Every time you discharge a battery your shortening the life expectancy, a battery 1/4 discharged will last longer than a battery thats been 1/2 discharged regularly all its life.
FollowupID: 805101
Follow Up By: Dennis Ellery - Saturday, Dec 28, 2013 at 22:41
Hi Old Fellas.
Knowledgeable gents like yourselves should be aware of the capabilities of these low resistance batteries – ie Lifeline and Optima, to name a couple - but there are others.
I have an 150 amp hour Lifeline battery which I regularly charge at 100 amps, when repetitive deep cycling, (I would go higher but I’m limited by my charging equipment).
I quote from Lifeline’s Technical Document No. 6-0101
“The charging current during the Bulk stage should be set as high as practical; higher current levels mean faster recharge time. For repetitive deep cycling, chargers should have an output current of at least 0.2C (20 Amps for a 100 Ah battery). If the output current is less than this value, the cycle life of the battery may be negatively affected. Due to the low impedance design, Lifeline® batteries can tolerate in-rush current levels as high as 5C (500A for a 100Ah battery).”
FollowupID: 805103
Follow Up By: olcoolone - Sunday, Dec 29, 2013 at 08:49
Your quite right Dennis, any batter can be charged at very high currents but you have to maintained a maximum battery temp of 25 degrees C...... Even Lifeline and it is referred to in their charging specs.
As temperature increases charge rates decrease for a very good reason.
No matter what battery you have you can not change how chemistry works often referred to physical law or scientific law....... A battery is a big science chemistry set and nothing else.
In an automotive application maintaining a set charge temp can be very difficult especially under a bonnet or in the back of a 4x4 and can become worse with heat soak.
Over 12 months ago you did a similar post. 98620
I am not doubting how good Lifeline are ( They are a premium product) or what they say but there is some things in life that can't be altered. Marketing hype wins in the war of getting customers to by a said product. If you read all battery specs they will say the same thing, some advertise it and others don't .
It's like a tyre company advertising our tyres only require small amounts of weight to be added to become perfectly balanced .... When in fact nearly all tyres only need a small amount of weight to be perfectly balanced....... Those who get in first wins.
People need to look through the smoke hazed hype on a product before making an sensible choice.
FollowupID: 805110
Follow Up By: olcoolone - Sunday, Dec 29, 2013 at 08:56
Dennis, you need to post the whole paragraph when quoting.....
There was two lines you missed out and the most important part when using high charge rates.
“The time to reach full charge at temperatures in the range of 68 to 86°F (20-30°C) can be estimated from the following equation:"
FollowupID: 805112
Follow Up By: Dennis Ellery - Sunday, Dec 29, 2013 at 10:48
Hi Olcoolone.
You quoted “you need to post the whole paragraph when quoting”
The document is many pages long – I included the document number for reference.
You quoted “max battery temp of 25 degrees”
If that was the case I wouldn’t be able to use it – I camp in ambient temperatures of up to 40 degrees - Lifeline quote a max operating temp of 71 degrees.
I have a temperature probe fitted to the battery and it’s temperature rise is about, 5 degrees at a charge rate of 100 amps from 50 precent DOD (hardly thermal runaway).
Lifeline quote “As of this writing, Concorde does not know of any Lifeline® AGM batteries that have failed due to thermal runaway.”
When I am running the caravan on batteries, this is high charge rate is applied a least once a day.
It’s the batteries low internal resistance that keeps its temperature low – my charging regime would destroy a standard AGM on its first charge.
FollowupID: 805119
Follow Up By: olcoolone - Sunday, Dec 29, 2013 at 11:46
Just stating fact.
FollowupID: 805123
Follow Up By: Dennis Ellery - Sunday, Dec 29, 2013 at 13:39
I’ll stick to the manufacturer’s specifications – they will do me as facts in preference to your facts.
FollowupID: 805126
Follow Up By: oldtrack123 - Sunday, Dec 29, 2013 at 14:08
HI
Yes ,Dennis
Low internal resistance does mean less heat generated within the battery
Low internal resistance also means higher charge currents for the SAME applied voltage.
You would be aware of it , but for the benifit of others, THAT means they will need to consider the MAX continious CURRENT rating of the charging source ,[ battery charger, dc /dc charger , unless they have overtemp protection ,] and vehicle alternator .
Some unpleasent surprises with another low impedance battery [LiPo Fe] when that was not recognised.
PeterQ
FollowupID: 805134
Follow Up By: Dennis Ellery - Sunday, Dec 29, 2013 at 14:27
Hi Oldtrack - I have 5 battery chargers, a DC/DC charger, and an inverter all are electronically current limited and over temperature protected. Never struck one yet that didn’t have these protections – wouldn’t buy them otherwise.
FollowupID: 805136
Follow Up By: oldtrack123 - Sunday, Dec 29, 2013 at 20:32
HI Dennis
Yes most are ,but what about the ALTERNATOR
PeterQ
FollowupID: 805146
Follow Up By: Dennis Ellery - Sunday, Dec 29, 2013 at 22:53
Hi Oldtrack,
When stationary - I use the 240V/100 amp charger off my 2.4 kva Yamaha genset.
When moving – the Toyota Troopy’s 150 amp alternator charges the 150 AH Lifeline ok – I haven’t measured its charge rate – but never had a problem.
FollowupID: 805151
Follow Up By: oldtrack123 - Monday, Dec 30, 2013 at 13:18
HI Dennis
NOW THAT does give the necessary details , for OTHERS to understand what is possibly needed with low impedance batterries.
I think you would agree ,everyone do not have 150A altrnators
So to those considering going to fast charge rate, low impedance batteries , CHECK your charging sources ratings!!!
for instance a 60A alternator would not take kindly to trying to pump out 100A for more than a few minutes
There is a degree of self limiting in alternators but THEY DO /CAN BURN OUT DUE TO OVERLOAD
PeterQ
FollowupID: 805184
Reply By: Member - Tony (ACT) - Saturday, Dec 28, 2013 at 06:41
AnswerID: 523584
Reply By: The Bantam - Monday, Dec 30, 2013 at 01:18
Um this lead free battery......this could change everything....exactly what type of battery is it....that may chance your choice of battery.
As far as all this discussion about charge rates.
These discussions are pointless with out knowing the specifcs of the battery in question.
For more or less traditional flodded wet cell batteries ( like trojans) it is strongly recommended ( many sources) that the initial charge rate should be 1/10 the amp hour rate or more.
This ensures that sufficient current flows thru the plates..in particular the bottom of the plates to recombine the sulphates.
most of the traditional wet cell batteries will cop extaordinary initial charge rates..above 50% of the amp hour rate..as long as they are kept watered.
with AGM and other sealed batteries all bets are off.....there is a very popular deep cycle AGM battery that is specifcally limited to under 20 amps maximum initial charge rate for a 100AH battery.
Yet other AGM have the ability to tolerate very high charge rates.
It is a well proven and accepted fact that a discharged lead acid battery should be returned to fully charged as fast as it will tolerate, in the interests of reduction of sulphates.
Trickle charging of batteries...( note I make a difference between trickle charging and float charging, there is a difference )...has never been considered healthy for the battery.....at least not by the reliable sources like the battery companies.
Before any recomendations about charge rate are made, we must now what battery we are talking about.....all capturing generalised recomendations are no longer reliable.
As far as this 25C thing...Oh please......many of the specs are written arround 25C and all lead acid batteries are most comfortable at 25C......but they will all run above and below that temperature.
If it is a good manufacturer thay will publish a set of curves and correction factors for temperatur.
Some of the battery chargers will have some sort of temperature compensation...some just within the charger case others will have a probe for mounting on the battery.
Above all, we need to know what this batter is that the original poster talks of.
AnswerID: 523640
Follow Up By: olcoolone - Monday, Dec 30, 2013 at 12:19
When talking about spec, 25 Deg C is what is stated as a reference. Of course they will comfortable handle temps up to 60 deg C.... So many be a better understand What the post was referring to before any "oh pleases".
FollowupID: 805172
Follow Up By: The Bantam - Monday, Dec 30, 2013 at 13:31
you said
"Your quite right Dennis, any batter can be charged at very high currents but you have to maintained a maximum battery temp of 25 degrees C...... Even Lifeline and it is referred to in their charging specs."
Sorry far from accurate or helpfull.
if you read many of the battery specs..and understand....they have corrected charge voltages for a range of temperatures.
Some batteries will have current limits and those limits may be corrected for temperature.
most likely the current limits will remain but the charge voltages will be varied against temp..so that the currents remain within limits.
This is nothing to do with a maximum battery temperature of 25C.
in the preceeding post you said,
"Of course they will comfortable handle temps up to 60 deg C.... "
sorry this is also inaccurate and unhelpfull.
Almost any lead acid battery will be very unhappy at 60C, that is hot eunough to burn soft skin on contact.
Any battery I found at those sorts of temps I would be taking a couple of calm steps away from, until it proved not to be dangerous and overheated for a reason..
In fact many AGM batteries we find on the market are beyond their specified operating temps at 45 C, 60 C would certainly put many batteries outside their specified storage temps.
This is why we find a lot of AGM performing exceedingly badly in under bonnet situations.
Some of these AGMs being sold into the camping, 4wd and caravan market are unsuitable for use in summer in the shade in free air in some areas.
Some of the battery specs will quote fairly wide operating temps in their general ststements on one hand, but when you get further into the specifics, that is not the whole truth.
Outside a far narrower temp range the performance ( every single parameter) and life of the battery declines dramatically....very dramatically in some cases.
In this day and age, almost all generalisations concerning batteries can be found to be unreliable.
because there have been so many variations in the battery technology come to market we MUST consult the manufacturers specifications......when I say manufacturer I mean just that because some badge engineered battery resellers are slap happy with their claims.
FollowupID: 805187
