Chain saw bar oil
Submitted: Thursday, Jan 02, 2014 at 18:59
ThreadID: 105656 Views:5070 Replies:17 FollowUps:13
Santa brought me a small chain saw for Xmas question is do I have to buy proper Bar oil or will normal engine oil do .
Reply By: Sir Kev & Darkie - Thursday, Jan 02, 2014 at 19:07
Get the proper stuff, standard engine oil is not thick enough for it to work effectively enough.
Also don't forget to wear the full PPE when using it :)
Cheers Kev
Russell Coight:
AnswerID: 523773
Reply By: Iza B - Thursday, Jan 02, 2014 at 19:08
I suggest proper bar oil is the way to go. I have used motor oil in a pinch but bar oil makes much less mess. Consider getting a second chain. Should you accidently drop the chain into the dirt, quick to replace until you get the chance to clean the grit off the dirty one.
Iza
AnswerID: 523774
Reply By: Slow one - Thursday, Jan 02, 2014 at 19:55
I remember when there was no such thing as special oil for the chain.
Have used engine oil for many years now. I just use what I have left over in a drum after an oil change.
Main thing is to clean the bar and chain then reoil after use, make sure you keep the chain sharp.
AnswerID: 523775
Reply By: Hairy (NT) - Thursday, Jan 02, 2014 at 20:35
Gday,
No you don't.
Its definitely better to use bar oil over engine oil but engine oil is better than no oil at all.
AnswerID: 523776
Reply By: P and JM - Thursday, Jan 02, 2014 at 20:48
Hi New Boy,
Go to Supa Cheap Auto if you can to get the bar oil.
I get mine there and it's cheaper brand name and motor oils.
I think I paid around $12.00 for 5 Litres
Cheers P&J
AnswerID: 523777
Reply By: Member - Howard (ACT) - Thursday, Jan 02, 2014 at 20:55
I save my old diff and gearbox oil for use in the chainsaw
85/140 is a lot stickier than std engine oil.
Howard
Resigned to Retirement
AnswerID: 523778
Follow Up By: Member - Rosco from way back - Friday, Jan 03, 2014 at 12:06
I've also heard on more than one occasion where blokes who use a saw a lot are happy to use old engine oil after an oil change. Sometimes they strain it through a stocking to get out any gunk. An old bushy mate of mine reckons bar oil is a con, but as always .. it's horses for courses.
FollowupID: 805366
Reply By: Smiley Bill - Thursday, Jan 02, 2014 at 22:30
Hi new boy,
Use proper chain lube mate. It's formulated to stay on the bar and chain when doing high revs where other types of oil will be thrown off and you will have no lubrication/excessive wear.
SB
AnswerID: 523783
Reply By: yarda - Thursday, Jan 02, 2014 at 23:17
Chain and bar oil is the lighter viscosity grade, single grip harvester oil is the heavy viscosity version.
Can you use motor oil or gear oil in it? Yes for short term or top up if you don't have c&b available. They both happen to be in c&b anyhow.
C&b is a blend of all the various oils left over from production runs, the tail ends and line drains, plus the magic ingredient - a heap of tackifier.
If this is your first chainsaw, please consider doing a chainsaw safety course, these things no matter how big or small can do serious damage very quickly.
AnswerID: 523784
Reply By: WBS - Friday, Jan 03, 2014 at 09:29
Did Santa also include a user manual? Did the user manual include advice/recommendations on what oil to use for your chain bar? If yes, why not just follow those recommendations.
I use chain bar oil on my chainsaw. It comes in a nice little 1 litre container for easy transport and storage and there's no need to fill from a big container and so on.
WBS
AnswerID: 523797
Reply By: KevinE - Friday, Jan 03, 2014 at 10:43
Hi New Boy,
Firstly, congrats on getting a new saw :)
I'm guessing from your question that you don't have a lot of experience with chainsaws?
Google "arboristsite" & scroll down to the "chainsaws" section mate. It's an American site, but there are lots of Aussie guys on there. You will get HEAPS of valuable info on there. There are a lot of long term pro chainsaw users on there.
I use chainsaws 5-6 hours a day, day in, day out & I would only ever use bar oil mate. As has been said, engine oil just makes a mess - on you - on your saw & everything within cooee! Also, if you use engine oil, it will continually leak out the oil pump onto the ground, your car, your trailer etc when you aren't using it.
What saw did you get?
If you look on the bar up near the engine there will be the number of drive links in the chain, the gauge & the pitch stamped into the bar. You don't need to understand what they mean at this stage, but you do need to know those numbers in order to buy a new chain. So, take a photo of them while the bar is still new & you can read them.
Re a accidentally dropping a chain in the dirt; it's no biggie! just wash it with a hose & then run the saw for a while to pump oil back onto it before using it again. If you have blunted the chain, just sharpen it with a file.
Buy a round file & a flat file & learn how to keep the chain sharp. Drop the depth gauges every 3rd or so sharpening. But don't drop them too much.
One other thing, new chains stretch, so keep an eye on it! If it gets too loose it will come off the bar while you are using the saw. The very best thing that can happen then is that it'll only scare the crap out of you.
" href="https://
" target="_blank">3 of my saws.
" href="https://
" target="_blank">Saw pics
[url=[IMG]http:
AnswerID: 523803
Follow Up By: yarda - Friday, Jan 03, 2014 at 11:37
What make are the blue saws?
FollowupID: 805365
