Help! Air con and fan died. Hzj105 Cruiser
Submitted: Friday, Jan 03, 2014 at 22:06
ThreadID: 105671 Views:3864 Replies:5 FollowUps:4
Hi folks. Currently in the road and my aircon and fan have just died. Can't see where fuses for ac are on fuse box diagram. Any ideas??
Reply By: Aussi Traveller - Friday, Jan 03, 2014 at 22:53
Passenger side kick panel.
AnswerID: 523847
Reply By: Sir Kev & Darkie - Saturday, Jan 04, 2014 at 08:20
Did it die or were you driving in hot temps as the AC drops out when the temp increases to reduce the load on the cooling system.
Cheers Kev
Russell Coight:
AnswerID: 523855
Reply By: Member - Rosco from way back - Saturday, Jan 04, 2014 at 11:20
Check the fan resistor (possibly behind glove box). If there're no blown fuses, that's the next thing to check.
AnswerID: 523859
Follow Up By: get outmore - Sunday, Jan 05, 2014 at 08:22
If that dies it should still work on full power as theres no resistance then
FollowupID: 805505
Follow Up By: Member - Rosco from way back - Sunday, Jan 05, 2014 at 10:12
Not if it's the same as in a Nissan. Seems they're not simply a stepped resistor but with more electrickery included than that.
The fan in our Pathfinder would not go at all. Replaced the resistor and all was good.
FollowupID: 805512
Follow Up By: get outmore - Wednesday, Jan 08, 2014 at 10:38
Musnt be the same as a nissan then. Its fairly common tor the tojo ones to die and and only work at full speed
FollowupID: 805671
Follow Up By: Hoyks - Wednesday, Jan 08, 2014 at 20:20
My Nissan started by losing 2, then 3 went and finally 1. I pulled the resistor and found that circuit board was badly corroded. 4 still worked though.
FollowupID: 805698
Reply By: Life Member-Doug T NSW - Sunday, Jan 05, 2014 at 07:06
If they get used a lot the small fan motor can expire, that has happened a couple times with my old Troopy, fan replacement is expensive, go to wreckers and get one and install it yourself, that was my remedy at Broome a few years back.
AnswerID: 523902
Reply By: Member - Cruiser74 - Tuesday, Jan 07, 2014 at 19:41
Thanks everyone,
I wasn't able to fix it on the road. Aircon unit started making a helluva racket and the belt was slipping so I took the belt off completely and just went without aircon for a few days. Not very pleasant as it was a hot few days over in the west. Anyway turns out the clutch in the compressor gave up the ghost and I have it in getting fixed as we speak. Appreciate the offers of assistance.
Craig
AnswerID: 524063
