Friday, Jan 10, 2014 at 19:48
As ya say... how long is a piece of string.
What particular bearings are they?
What brand of bearings where used?
How carefully where they handled when they where installed?
How heavily are they loaded in realation to their designe capacity?
What size
wheels are being used?
What sort of grease is being used?
Are they exposed to
water?
How frequently are they repacked?
I've had vehicles with over 300 000km on the clock on the original bearings.....but a large motor car manufacturer designed and specified the bearings in the application.
Trailer manufacturers nearly all of them ( I don't care how much you paid for you camper or caravan) do not have the design capacity of the large manufacturers and they use parts they can buy cheaply.
Almost without exception trailers are carried on bearings closer to their design capacity than motor cars.
Helll the majority of caravans would still be carried on either snotty early holden front wheel bearings or marginally better ford falcon front wheel bearings.
Unless you specifically specified it, your camper or caravan will not be carried on bearings of the capacity or quality of those on the towing vehicle....even if you want it and are prepared to pay...good luck with gettinmg that.
And there lies the problem.
The single most important thing is to check your bearings regularly, simply by jacking up the wheel and rotating it by hand...feeling and listening.
the second most important thing is to have the ability to change your own bearings on the side of the road with reasonable confidence & ease.
The best way to achive this is to carry a complete loaded hub...yeh its bulky..and if your maintenence is good you will never need it.
But it reduces your road side repair time a hell of a lot.
.Now I have a little box trailer that has done quite a few
miles since I built it back in the 80's..and its still on its original bearings.
On the other hand...I can not recall driving
brisbane to sunshine coast and back without seeing some poor unfortunate on the side of the road with seriuos bearing or tyre failures.
I think it comes back to maintenence.
Bearings don't spit the dummy in 5 minutes......if they fail catastrophicly they have almost certainly been dodgy for quite some time.
SO. jack that wheel up and spin it by hand ..then..either
.smile quietly ...mmmm...smooth.
Or
have a little snarl and say.....I got you you little bastard...ya not stranding me! .
524238
Follow Up By: Member - Odog - Friday, Jan 10, 2014 at 20:14
Thanks Bantam
All great advice, I have never had a bearing fail, although I have helped others who have been sitting on the road side over the years. Have always replaced them instead of servicing them on the boat trailer, due to the salt
water. But the
camp trailer doesn't get backed in the ocean... And as yet no river crossings either. Good to know that, when looked after, can last many km though. We will be doing around the 10000km mark, on this trip, so will check them on a regular basis. Cheers Odog
| Some people want it to happen, some people wish it could happen, others make it happen! Lifetime Member My Profile Send Message |
805817
Follow Up By: The Bantam - Saturday, Jan 11, 2014 at 11:12
particularly in the boating market there are a lot of bearings that get replaced for no good reason whatsoever.
If the bearings are clean smooth and in good condition there is no good reason for replacing them.
A wash and a repack with good grease and they will continue for many Km.
That brings up the matter of grease.
There are still those persisting with the old greases...the old lithium ( like castrol LM) and bentonite ( like castrol HTB).
Particularly in trailers ya cant beat the newer BLUE lithium complex greases....( currently castrol LMX or boating grease...formerly APXT).
Every lubricant company sells a "Blue Grease".
These blue greases have more than adequate temperature performance and are highly resistant to
water.
Like the older greases they can also be baught fortified with graphite, molibnium disulphide or teflon....if ya keen.
805845
