80 series overheating problem
Submitted: Thursday, Jan 16, 2014 at 13:44
Member - Judy and Laurie
Hi all, happy new year, quick question on overheating problem with a 80 series landcruiser 1HZ diesel aftermarket turbo towing a 20' van , the vehicle has new injectors, 3" exaust system . any info would be appreciated .
cheers Judy
Reply By: Member - Fab72 (Paradise SA) - Thursday, Jan 16, 2014 at 14:05
Check the viscous fan is doing its job properly....pretty common and easy to fix.
How long has it been overheating....can it be linked to any event eg: parts changed or added.
How long since the radiator was flushed (hope you haven't mixed coolants).
Bit more info please...if you could.
Cheers...Fab-io
524607
Follow Up By: Aussi Traveller - Thursday, Jan 16, 2014 at 14:14
viscous hub x 2
806323
Follow Up By: Member - DOZER - Sunday, Jan 19, 2014 at 21:40
viscous hub x 3.....go to toyota and buy a tube of silicone oil for it, pull the fan appart and fill it up.
806580
Reply By: Members Pa & Ma. - Thursday, Jan 16, 2014 at 14:47
We had the same trouble with the viscous fan in
Kununurra in 2001.
We'd had it checked before we left Vic for our long service leave. It was supposed to be fine.
You wouldn't believe what we were told in
Kununurra.
Wrecked our long service leave.
After we had it floated home. It was the Viscous Fan & a very common problem with this vehicle, ours is the same. We swapped mechanics
There is a special test which can be done by a good mechanic with a piece of cardboard.
I'm told that a Turbo will make a diesel engine run hotter too.
Where are you?
Take care, safe travels & may 2014 be good to you. Ma.
524609
Reply By: Brian 01 - Thursday, Jan 16, 2014 at 15:07
Are you losing
water?
Are there bubbles appearing in the radiator when the cap is off?
524611
Reply By: Member - Judy and Laurie - Thursday, Jan 16, 2014 at 15:48
Hi thank you all for the replies, the fan was serviced and as was the radiator( new 4 core) 18mths ago, they have been towing a 20' van for the first time since November 2013. hence the heating problem has started since then.
524613
Follow Up By: Ross M - Thursday, Jan 16, 2014 at 16:40
Besides the above possibles,
Is it an auto vehicle?
If a manual what gear is used for towing?
Auto may be putting in more heat to the radiator than the system can handle.
Does the vehicle become tail down when towing the van? Different attitude, different cooling flow though the engine bay.
806332
Follow Up By: Road Warrior - Thursday, Jan 16, 2014 at 17:04
Was the radiator upgraded along with the aftermarket turbo conversion?
806340
Follow Up By: mike39 - Friday, Jan 17, 2014 at 07:58
Wonder how the "fan was serviced"?
As an assembled item there is nothing "serviceable" other than a complete dismantle.
I had an identical problem, dismantled the fan clutch and filled to the correct level with a tube of silicon oil from Toyota (~$20).
Not a problem since and that was 30 odd k.km. ago.
mike
806385
Reply By: Member - Judy and Laurie - Thursday, Jan 16, 2014 at 17:30
hi vehicle is a manual, and has only overheated since towing the van
524618
Reply By: Member - Judy and Laurie - Thursday, Jan 16, 2014 at 17:32
hi , radiator only recently upgraded to fix the overheating problem
524619
Reply By: cruiser 3 - Thursday, Jan 16, 2014 at 19:59
Hi Judy and Laurie.
You say the overheating only started when towing the van. I would say that it is normal for a vehicle to run hotter when working harder such as towing although most probably only as much as 5 deg higher.
The same applies for changes in ambient temperature. For example traveling around NSW in temperatures of about 25 degs with no towing then take your van to
Darwin where temps are about 35 you could easily see a change in engine temperature from 85 degs to 90 degs or more.
So the question I would ask is what is the engine temperature when you say overheating. IE is it boiling or just increasing in temperature a little? and under what conditions.
524629
Reply By: Life Member TourBoy, Bundaberg - Thursday, Jan 16, 2014 at 20:56
The factory gauges of all makes will show a marked increase of temp about 8º hotter than normal. They are designed to barely move in normal driving even though the engine will get hotter and cooler. This is designed so drivers don't freak every time a
hill is driven or descended. You could fit an aftermarket degrees gauge to see if it is actually getting hot. Keep in mind that it is a presurised system and the boiling point is above 100º. Having said all that my money is on the viscous fan or the
fuel set too high when the turbo was fitted.
524631
Follow Up By: Member - Fab72 (Paradise SA) - Friday, Jan 17, 2014 at 05:23
Dave has a very good point here regarding gauge calibration.
Normal operating temperatures for many modern vehicles is 100-106 degrees C.
Fab
806380
Follow Up By: get outmore - Friday, Jan 17, 2014 at 20:56
Easiest way to know when your tojo is ggetting warm is aircon stops blowing cold air.
At that stage gauge just moves above normal and alot wouldnt notice
806457
Reply By: Greg K3 - Thursday, Jan 16, 2014 at 22:52
Agree tourboy
I fitted an Engine watchdog with engine and trans temp to my Pajero. Dash gauge reads normal between 55c to 100c !!!! My radiator with glycol and pressure cap is set for 117c. I now have piece of mind in hot conditions Best accessory I have purchased !!!
Trust ur dashboard gauge at ur own peril
524634
Reply By: Malcolm 02 - Friday, Jan 17, 2014 at 10:04
Hi I used to look after these trucks in the mines and they were very reliable machines. None of the
mine vehicles were turbo'd though and have only come in contact with one since leaving the mines and it was having no problems but only towing a camper.
Just a few thoughts, when they fitted the turbo did they upgrade the exhaust system, the bigger the exhaust the more the turbo likes it. But if there is restriction this can hold back the hot exhaust gasses and cause overheating. Did they fit an intercooler? if so I would expect an aftermarket radiator would have been fitted with electric fans for extra cooling, if so are they working? (they would be controlled by an electrical thermostat switch).
An additional suggestion is to change the thermostat in the engine cooling system, they don't cost a lot and they can be tricky to diagnose when they are faulty. If you wish to test the old one heat it up in
water and observe at what temp it starts to open and what temp it fully opens (the temps will be in a workshop manual) this will tell you if it was faulty.
Hope this helps.
Mal
524656
Reply By: get outmore - Friday, Jan 17, 2014 at 20:50
When its running warm quickly pull up. Pop the bonnet and shut it down while you can see the fan
The fan should be vusciusly locked and should give no more than a few spins before stopping.
If it sits there spinning away after the motors shut down its shagged
524697
Follow Up By: Member - Judy and Laurie - Friday, Jan 17, 2014 at 21:07
hi the fan has been serviced correctly and has had the correct oil put in, it also has a new 3" exaust and new thermostat. and radiator is new, thanks
806460
Follow Up By: TTTSA - Saturday, Jan 18, 2014 at 11:18
Hi Judy and Laurie
I am having a similar problem with my 100 series, have done similar to you. I am going to do as others have suggested and buy an Engine Watchdog to see what the temp really is. Who knows, from 1/2 to 2/3 on the factory temp guage may only be 5degC and not worth worrying about.
806493
Reply By: Gone Bush (WA) - Saturday, Jan 18, 2014 at 11:47
I had that issue with my 80 as
well. The temp gauge used to go right to the top towing a camper trailer up prolonged steady inclines.
It seemed to be a combination of things.
I re-oiled the viscous hub, no change.
The biggest factor was that the original radiator was right on the edge of its performance capabilities. I should have upgraded the radiator.
Contributing factors:
The intercooler was in front of the radiator, and
The top and bottom hoses were old and got sucked flat restricting
water flow.
524709
Reply By: howesy - Saturday, Jan 18, 2014 at 13:10
Just a couple things to consider,,, most aftermarket turbo fitters simply screw the fuel up which is fine for normal driving but without actually having the auto advance tweaked and timing to suit turbo which is done on a bench it is a crude compromise and under extreme load over fuels slightly however if its not actually boiling and when you coast downhill the temp comes down quickly you will probably find the super reliable factory guage although it goes up a fair whack may only be registering 5 degrees,,, you need a reliable aftermarket guage and if your pump ever needs doing and you remove it yourself make sure they know its running a turbo and they will set it up accordingly. I too have 1HZ with aftermarket turbo (HZJ75) and I was concerned about guage movements until I got an aftermarket guage. My factory guage shows less than 1/4 on coasting downhills, just under 1/3 for normal flat driving and a tad under half for heavy load. My normal road weight in its std trim is around 2.7T
524714
Follow Up By: awill4x4 - Saturday, Jan 18, 2014 at 14:03
Howesy is about the only one on this thread that has picked up on a possible over fueling issue.
Over fueling gives a much hotter burn in the cylinder and this is transferred to the cooling system through the head.
With all you have done it's now time to look at your fueling and the best way is to fit an EGT (Exhaust Gas Temperature) gauge.
Have the thermocouple fitted just past the turbo exhaust flange and drive the L/Cruiser so it only reaches a maximum of 500-550C.
If in top gear and the EGT's start to climb too high then change down a gear and this can knock off 50C+ of EGT's simply by changing down a gear.
If you are noticing consistently high EGT's then the car should be tuned by a reputable diesel mechanic preferably on a dyno so he can replicate how the engine is coping under load.
Regards Andrew.
806516
Follow Up By: Life Member TourBoy, Bundaberg - Sunday, Jan 19, 2014 at 10:43
Yeah I brought the fuel up in reply 8 :)
806543
Follow Up By: awill4x4 - Sunday, Jan 19, 2014 at 10:54
Sorry TourBoy I missed your comment about over fueling at the end of your post.
Regards Andrew.
806544
Reply By: Member - DOZER - Sunday, Jan 19, 2014 at 21:54
You can try this trick....a mate has thesame issue, and to prove it was the fan, i gave him an old electric fan from a commodore, and he mounted it between the radiator and grill.
It proved his viscous fan wasnt working properly, so he went and got it serviced, but wouldnt give me back my fan because the air conditioning was working so much better aswell....might make all the difference to your issue.
524757
