Monday, Feb 10, 2014 at 21:21
Take a spare
fuel filter or two and a 5mm allen key in case you get bad
fuel.
Here is the fitting procedure
1. Remove both electrical plugs from filter assembly.
2. "Crack" the three Allen key studs whilst still connected to vehicle and you have leverage. Keep reasonably firm to prevent
fuel leakage onto vehicle.
3. Undo two nuts holding assembly to vehicle and remove.
4. Hold assembly whilst you undo and remove the three Allen key studs.
5. Carefully remove top of filter assembly (without taking
fuel hoses off). Then take filter "bowl" away from vehicle to drain
fuel and remove filter.
6. Clean filter "bowl" with clean rag.
7. Install new filter with new o-ring/seal.
8. Reinstall assembly to vehicle.
9. Prime the
fuel filter housing using the manual pump on top of assembly. You should know when the housing is primed by the extra, very firm pressure on the manual pump.
10. Follow procedures outlined below to turn off the warning light.
The
fuel system warning light (see LC 200 Owners Manual). There is no information in the Manual on how to reset the warning light .
Follow this procedure to turn light off:
1. Disconnect top wires/plug on filter housing
2. Turn Ignition on
3. Plug top wires/plug back in
4. Turn Ignition Key off
5. Turn Key back on and start vehicle
Light should now be off!!
526160
