GQ , TD42 injector pump
Submitted: Wednesday, Feb 26, 2014 at 18:38
Member - mechpete
hi all .
can someone please clarify for me ,
have just fitted DTS turbo an 3in system ,in the fitting instructions ,a bit vague .
it says to adjust the max
fuel scew in 1/4 turn , I have an aftermarket W/Shp
manual which says virtually nothing about the pump , could someone please
explain or email a photo of the screw I need to adjust ,
cheers mechpete
petefiegs@iinet.net.au
Reply By: Member - Niss42 - Wednesday, Feb 26, 2014 at 18:44
G'day Pete.
Suggest you try the "Patrol"
forum here:-
http://www.patrol4x4.com/forum/
There is some great info to be found there !
Barry.
527283
Reply By: pop2jocem - Wednesday, Feb 26, 2014 at 18:46
Pete, not familiar with the Nissan pump but maybe ask the question of a local
fuel injection
shop or post on the Nissan Patrol
forum.
Pop
527284
Reply By: wjh41 - Wednesday, Feb 26, 2014 at 18:58
Hello mechpete,I don't know what state you are in but I had a similar situation with
mine.Forget the guess work I took
mine to MTQ in Dandenong where the vehicle was tuned on the dyno,very happy with the results. Wally sorry just read your in Shep
527286
Reply By: Member - Duncs - Wednesday, Feb 26, 2014 at 20:59
mechpete,
Having owned a GQ with an aftermarket turbo I can recommend using a good diesel
fuel injection workshop to get the turbo sorted.
I note that you are a mechanic but think this is still worthwhile.
The turbo was fitted to
mine by a previous owner and I did have problems. The biggest was overheating but all were caused by over fuelling. Adjusting the
fuel screw by 1/4 turn sounds a bit vague to me. Diesel
fuel injection is not vague.
My problem required a two stage fix.
The first place I took it to fitted a unit which automatically adjusted
fuel supply based on turbo boost, I think they called it a boost compensator. If you look at the top of a diesel pump in a vehicle with a factory turbo you will notice it looks different to one without a turbo, that is the boost compensator. This did improve things but didn't provide a complete fix. I took the car to another
fuel system specialist who properly tuned the
fuel system, balancing the opening pressures on all 6 injectors and getting the
fuel rate right.
Good luck with the upgrade. The GQ is a great old bus and should serve you
well for many many
miles.
Duncs
527300
Reply By: Ross M - Wednesday, Feb 26, 2014 at 21:03
I believe screwing it inwards increases the amount of injected
fuel, but, some caution should be exercised, BECAUSE, you don't know if it is already in or out or where it is.
Theoretically, more air will cater for more
fuel but you just don't know.
Now you are in the realm of SOP testing ie
seat of pants, and to do that you will need to know what is required and have an EGT gauge fitted and have some experience in the concepts involved so excessive EGT's can be avoided.
If you make a mistake, what is the cost of a TD42 now?
527301
Reply By: Brett and Julie - Thursday, Feb 27, 2014 at 08:14
Gday
I had a Denco turbo fitted to my TD42 GQ which was put on a dyno and had the pump adjusted to suit. 5 years later never been touched and has been bulletproof. Best accessory I ever bought. Good luck with yours. cheers
527326
Reply By: mike39 - Thursday, Feb 27, 2014 at 08:36
The max.
fuel adjusting screw you are looking for is directly above where the injection pipes mount to the pump.
A small screw about 25mm. long with a 6mm. hex on the end, a small sleeve and an 11mm locknut.
To adjust (in for more
fuel) you have to remove this screw and grind off
the spot weld on the sleeve to remove it.
Once you have done this you are in "no mans land" this sleeve was to prevent overfuelling of the pump but now you can do whatever you want, possibly at your peril.
Its also nigh impossible to go back to the original calibration
Although extremely robust, all these old NA engines do not suffer overfuelling, particularly with now a turbo boost. Even a 1/8 turn of the screw results in more
fuel than imagined, the pump is initially calibrated y.xx cc's/1000revs. which is why the sleeve is spot welded on.
As an aside, when I turbo'd my 1hz (125000km. ago) I actually had to decrease the
fuel to obtain best power/economy ratio.
mike
527329
Reply By: Member - mechpete - Thursday, Feb 27, 2014 at 11:44
thanks everyone !!
gunna get it dynode
mechpete
527341
Follow Up By: Member - Craig F (WA) - Thursday, Feb 27, 2014 at 22:29
Wise move. The money spent will be returned in Performance and economy. After fitting an aftermarket Exhaust Turbo and Intercooler to
mine I had it tuned resulting in a massive increase on economy. Went from 20ltr per 100km to 15.
809770
