Secret to clean windows
Submitted: Sunday, Apr 06, 2014 at 09:57
ThreadID: 107108 Views:2898 Replies:14 FollowUps:5
Just wondering if anyone can help me with tips on getting that clear, streak free windscreen?
I reckon I have tried nearly every product and cloth combination out there and still can't get that super clear streak free appearance.
Any suggestions greatly appreciated.
Reply By: Member - Billmoore1 - Sunday, Apr 06, 2014 at 10:16
When I had a car detailing business, I would wash the car, chamois dry then use a two cloth method. I used to buy old flannelette nappies from a supplier ( they were more expensive than new ones.) I used a widow cleaner from Milestone Chemicals which was good; but it works just as well with Windex or similar. Secret is peter, don't use too much cleaner. Just mist a little on the area then use what will become the "wet" cloth. Dry immediately with the other cloth. Do around the edges first then work to the centre. Do this inside and out and you won't be disappointed. Don't get the cloths mixed up.Works well for me.
Bill
AnswerID: 529921
Follow Up By: Lifetime Member-Gaz@Gove (NT) - Sunday, Apr 06, 2014 at 10:51
I use the same method as Bill, but use a 50/50 mix of Metho and Water.
Does a good job.
Gaz.
Mmmmmmmm, now where do we go next?
FollowupID: 812744
Reply By: Member - Graham N (SA) - Sunday, Apr 06, 2014 at 11:10
Hi Peter,
I wash and dry as usual but use newspaper for the final drying, seems to leave it streak free.
Graham
AnswerID: 529925
Follow Up By: OBJ - Sunday, Apr 06, 2014 at 13:12
Metho and water with newspaper works great for me as well.
OBJ
FollowupID: 812754
Follow Up By: Member - Coldee - Sunday, Apr 06, 2014 at 19:27
A4 office paper scrunched up and rubbed on a dry windscreen works too. Doesn't need to be new. Especially goo at getting rid of that annoying haze on the inside of the windscreen.
FollowupID: 812782
Follow Up By: Shaker - Sunday, Apr 06, 2014 at 19:46
Newspaper used to work in the days of spirit based inks, now with the water based inks you may as well use any paper.
FollowupID: 812787
Reply By: cookie1 - Sunday, Apr 06, 2014 at 11:23
I use CRC Window Cleaner and find it brilliant providing the window is not "dirty"
AnswerID: 529928
Reply By: Neil & Pauline - Sunday, Apr 06, 2014 at 12:41
I use a detergent / water mix and clean and dry off with newspaper. Works for me. I sometimes add metho if some is around That is if I haven't drunk it all!!)
Neil
AnswerID: 529933
Reply By: scandal - Sunday, Apr 06, 2014 at 13:14
I got into a truck that had been sitting for a while and had a built up of oily residue on the inside of the screen, it was difficult to see out of so I stopped at the first servo and used the window squeegy from the servo to do the inside of a windscreen, this servo used some sort of soapy solution in the water.
What i did was dip the squeegy in the bucket and flick of the excess water off, wipe it on the screen and wipe off with heaps of paper towel, the windscreen came up great.
I think the secret is in what you used to wipe off, paper towels seem to work to best
Scandal
AnswerID: 529934
Follow Up By: Shaker - Friday, Apr 25, 2014 at 21:55
You were lucky! Most of those washers have been used for cleaning diesel spills of the sides of vehicles.
FollowupID: 814245
Reply By: TTTSA - Sunday, Apr 06, 2014 at 13:15
Thanks for the tips, I will give them a go.
AnswerID: 529935
Reply By: Rustynails59 - Sunday, Apr 06, 2014 at 15:43
Water / white vinegar
About 20 to 1 mix
Use it ion windows, polished tiles etc
No streaks
AnswerID: 529943
Reply By: The Bantam - Sunday, Apr 06, 2014 at 16:32
No matter what sort of chemical concoction or precleaning method you use the secret to a realy good streak free finish is paper.
In the past news paper was the item of choice, these days I use paper towel...and lots of it.
As soon as the paper starts to get damp..either fold to a dry piece or get a fresh piece.
As for the actual cleaning....it realy depends on what is on the glass and how much.
Vinyl and the oils it contains evaporates from the dash and upholstery and deposits in the glass....this is why vinyl goes hard & cracks.
the various cleaing products and vinyl conditioners evaporate and get deposited on the window.
Stuff you leave in the car, like food, oily clothes, make up and almost anything you can name....yeh guess what...it evaporates and gets deposited on the glass.
if the glass is realy dirty or contaminated it realy does take some cleaning.
I have found the "two bucket, two rag" method works best.
One bucket with your concoction of choice...I like either detergent and metho or detergent and amonia...dishwashig liquid is fine.
One bucket with clean water.
use you detergent bucket to scrub the window clean, till the glass wetts properly showing the grease & what ever has been removed....repeated rinsing and wringing of the rag.
then go over with the clean rag and clean water..repeated rinsing & wringing of the rag.
then go at it with the paper till it squeaks dry.
IF you have a problem with windows fogging up, put a small amount of detergent on dry paper and rub it in well and then polish it out with clean paper.
After that smack people who touch you windscreen
After this treatement and without fingers or sneezing you windows will stay clean for quite some time and defog consistently.
realy clean windows seem to stay clean for longer.
AnswerID: 529948
Reply By: TTTSA - Sunday, Apr 06, 2014 at 17:17
Thanks for all the detail outlined here, certainly some food for thought.
I just had the windscreen replaced and it would be nice to keep that "like new" appearance, nothing worse than a smeared windscreen.
AnswerID: 529953
Reply By: Triggy - Sunday, Apr 06, 2014 at 22:19
On newish cars, or winodws, I use warm clean water and wash / clean with microfibre cloth, then dry straight away with a clean handtowel from our linen press. The missus always dries the towels in the dryer for a fluffy feel and I find the dryer also gets rid of the lint, so none stays on the glass.
I agree TTSA, it is always nice to look out of a sparkling clean window.
AnswerID: 529979
Reply By: misha_boi - Monday, Apr 07, 2014 at 02:44
Hey TTTSA,
My dad makes up a formula all the time and works a treat!
%50 metho and %50 water, and plain paper towel or newspaper.
Hope that works.
Misha
AnswerID: 529984
Reply By: Steve D1 - Monday, Apr 07, 2014 at 09:03
Genuine Audi screen wash. Can't beat it.
Steve
AnswerID: 529994
Reply By: Member - evaredy - Tuesday, Apr 08, 2014 at 13:08
In my working life, when I was a youngster, I worked in quite a few car yards detailing cars. In my adult life I worked in commercial window cleaning for 20 years.
For car windows you don't need any fancy chemicals or cloths. Keep it simple, keep it clean, use a bucket of water, a small dash of dish washing liquid and three terry toweling cloths (nappies).
Use one to wash the window, wring it out so it's not dripping wet and wash the glass. Then with another, wipe off the water, leaving the third cloth to buff it to a streak free finish.
Always wash your car in the shade and when it's cool to touch. trying to wash windows that are hot will only end up with streaks and will take a lot longer to buff them out.
Most window cleaning chemicals actually leave a thin film on the glass, which builds up over time, making it harder to clean.
AnswerID: 530107
Reply By: Sam W5 - Friday, Apr 25, 2014 at 20:06
metho and newspaper
AnswerID: 531213
