Portable Dual Baterry?
Submitted: Sunday, Apr 06, 2014 at 14:31
misha_boi
Hi everyone,
First post today,
well here goes..
I have a Mazda Tribute, and would love to set up a dual battery but, as some of you might be aware there is no space what so ever under the hood. So my only option is to put one in the back. But I don't want it there permanently, as I wouldn't use it every day.
I already have a Pirahana system sitting in the shed, so I won't have to buy one. Came across this site, sort of what I am looking for but not quite sure where to put the Anderson plug? Or exactly how it should be set up.
http://www.offroadaussie.com/2012/01/redarc-dual-battery-system-installation/
Anybody out there have sound knowledge of electrical work? I find myself confident with auto electrical but always good to ask questions.
I am in the process of buying a fridge, but not tempted to buy one of those fancy portable battery packs, as what do you do when the battery carks it?
Any comments/suggestions would be fab.
Misha
Reply By: Ross M - Sunday, Apr 06, 2014 at 19:06
Misha_boi
One of those battery packs can be useful for your situation as it is portable and can be unplugged from the charging source via an Anderson plug and used in a tent or outdoors somewhere.
Always buy one which can be partially disassembled to replace the battery IF and WHEN it fails.
I don't mean a jump starter pack but something more substantial with a 80 to 100 ah battery, depending on proposed use. It doesn't have to be fancy, just one that has a good storage capacity for whatever your use is.
Plenty of people on here have every type of power source, battery chargers and battery banks with solar panels too so there is a host of valuable opinion and examples available.
529960
Follow Up By: misha_boi - Monday, Apr 07, 2014 at 02:34
Hey
Ross M,
With the anderson plug, would it be ideal to run the negative all the way back to the main battery, or would grounding it to the chassis be ok? I know its going to be a challenge either way as there is no grommit at the rear of the car and the grommits through the firewall are small.
Main+Isolator+plug/plug+auxiliary
Main--------------plug/plug-auxiliary
or
Can't think of anything else that could charge the battery without the actual isolator. I have a 12v plug in the boot but that's connected to my main and constant power, hence for this setup.
And is it true what some people say with batteries emitting gas? Is a sealed battery the go?
Thanks in advance
Misha
812812
Reply By: ABR - SIDEWINDER - Sunday, Apr 06, 2014 at 22:10
Hi Misha
If you already have the isolator then one of these will be perfect.
Base-line-FLYER
Derek from ABR
529978
Follow Up By: misha_boi - Monday, Apr 07, 2014 at 02:37
Hey Derek,
That looks fab, few other brands out there but this type already has the anderson, I wouldn't have to add one.
Is there another way around charging the battery without an isolator?
Misha
812813
Follow Up By: ABR - SIDEWINDER - Monday, Apr 07, 2014 at 04:50
The isolator is recommend to protect the main battery from discharge and also stop the car trying to start off the base line FLYER pack. If the main battery is low the car will draw more power from the pack and can result in burnt wiring and melted plugs etc. The FLYER has a 50A breaker as
well as a maxi fuse but please use an isolator. Perhaps look at the FULL FLYER pack that has the isolator in the lid already fitted.
Derek from ABR
812814
