2010 Raster Map installation from disk
Submitted: Sunday, Apr 13, 2014 at 09:18
Member - lyndon NT
Hi All
Trying to load a Legit copy of 2010 Hema Raster maps to my computer running windows 7
Wish to copy whole disk to computer(don't wish to have to insert disk to view maps). Unable to do this, auto-run won't load. Can only load short cut which then asks you to load disk.
Idea's anyone?
Lyndon
Reply By: The Explorer - Sunday, Apr 13, 2014 at 09:34
Hello Lyndon
With the disc in the drive click on “Computer”
f1
You should then see a screen (as below) with all your internal and external drives listed.
Right mouse click on the Disc drive with the Hema maps and a menu will appear – select open to show the contents of the disc.
F2
Copy the particular folder you want to the desired location on your computer (i.e. right mouse click on desired folder and select copy…then move to new location and select paste).
F3
Hope that helps
530454
Follow Up By: Member - lyndon NT - Sunday, Apr 13, 2014 at 09:43
Hi Greg
Appreciate your time on a Sunday morning. I wish to copy the whole disk as a functioning entity, not just a particular map that when clicked on will then ask what program do I wish to use to open it. Any idea's?
Lyndon
813363
Follow Up By: The Explorer - Sunday, Apr 13, 2014 at 09:56
They wont let me in church so I have a bit of free time :) Going to beach later but in mean time ....
Thought I had a copy of Hema 2010 but cant find it.. so I probably am not 100% sure what you are trying to achieve....but
What happens if you copy the entire disc (as in second picture above but select copy) and then paste somewhere on PC?
Also you can initiate Auto run from this menu...alternative method to what is shown in post below.
813364
Reply By: Member - Frank P (NSW) - Sunday, Apr 13, 2014 at 09:49
Hi Lyndon,
I have an older copy of the Raster Map collection - 1st Edition - and Win 7.
After inserting the disk, I get:
Autorun dialogue
Choose Run AUTORUN.EXE
After a bit of thinking time, the normal installation routine started and the maps were installed.
530457
Reply By: get outmore - Sunday, Apr 13, 2014 at 11:02
cant you just open the disc, select the files and drag and drop them onto your computer?
530462
Follow Up By: The Explorer - Sunday, Apr 13, 2014 at 11:56
Details provided are a bit vague but it could be that Lyndon is trying to install the required data from the disc so that he can use Hema Navigator Explorer program. The Australia 4WD Raster Map Collection or HN Explorer DVD must be "installed" on your PC for this to work.
Just copying the map files over wont install all the required data files. You must initiate the supplied installer program on the disc for the process to complete successfully. This appears to be the problem as autorun wont start ...you should however be able to initiate the process manually, one way or another.
I could however be yet again barking up the wrong tree..anyway
Read about the program here ...
Hema Navigator Explorer for the Hema Navigator and
HERE
813378
Reply By: K&FT - Sunday, Apr 13, 2014 at 12:12
You may need to be logged on to the computer as administrator or the autorun will not load.
frank
530466
Reply By: Member - lyndon NT - Sunday, Apr 13, 2014 at 12:18
Hi Guys
Seem to have it sorted, copied whole disk to computer and was able to launch and load from there. Appreciate the input.
Lyndon
530467
