Sunday, Apr 20, 2014 at 23:37
Yes there may be specifications and definitions......there is also reality what is actually being supplied.
SO....tell me do you have any documentation that shows undeclared ethanol being supplied in unleaded
fuel.
so are you going to cough up with some actual information or will you persist with personal insults because that is all you have.
so how about some specifications and definitions.
From the
Fuel Quality Information standard ( Ethanol) Determination 2003
Definitions
In this Determination:
ethanol blend means petrol that, as tested in accordance with the
Fuel Standard (Petrol) Determination 2001, contains more than 1% ethanol.
service station means premises at which petrol is sold by retail from a petrol pump.
4 Service stations
(1) The
fuel quality information standard for the supply of ethanol blend from a service station is that one of the following appears, clearly displayed, on any petrol pump at the station dispensing ethanol blend:
(a) the words ‘Contains up to x% ethanol’, where x is no less than the percentage of ethanol in the ethanol blend;
(b) the words ‘Contains y% ethanol’, where y is the percentage of ethanol in the ethanol blend.
(2) For paragraph (1) (b), if the percentage is not a whole number, it may be rounded to the nearest whole percentage, a multiple of 0.5 % being rounded up.
So it is a leagl requirement that
fuel with more than 1%, that is 1 part in 100 must be labled at the pump....one part in 100 is hardly going to cause anybody any problems.
further, the bruhar at the time that triggered the framing of this determination resulted in some of the
fuel companies comming out and specifically saying their
fuel contained no undeclared ethanol.
813947
