Tekonsha P3 model differences.
Submitted: Sunday, Apr 27, 2014 at 09:24
ThreadID: 107484 Views:2447 Replies:2 FollowUps:5
While looking at adds for the Tekonsha P3 brake controller I have seen 4 different versions advertised
TEKONSHA P3
TEKONSHA P3 90195
TEKONSHA P3 90195A
TEKONSHA P3-AUS
What is the difference. Is there really an Australian version.
Richard
Reply By: richard - Sunday, Apr 27, 2014 at 09:45
One more to add
I have seen a Tekonsha P3 Heavy Duty one advertised as well.
Richard
AnswerID: 531313
Reply By: scandal - Sunday, Apr 27, 2014 at 14:49
I don't know about all the variations you have listed but I know that the US models have the ability to store settings for individual trailers instead of changing setting for different trailers like you have to with the Australian version (P3 AUS).
You can source the US version via evilbay or the like if you feel that is an important feature.
Shane
AnswerID: 531332
Follow Up By: richard - Sunday, Apr 27, 2014 at 15:42
Shane,
I have one already but are having problems and am chasing all the leads I can find.
The one I have has this feature, not one I care about though.
It is also classified as a "HEAVY DUTY" controller, not sure what that means either.
I thought they meant heavy duty wire but that is not mentioned any where either.
Richard
FollowupID: 814342
Follow Up By: scandal - Monday, Apr 28, 2014 at 15:57
So what problems are you having?
Should've mentioned this in the original post
FollowupID: 814405
Follow Up By: richard - Monday, Apr 28, 2014 at 17:20
Scandal,
Fair question.
But I did not want to confuse my question. At this point I am trying to clarify the difference in the products being advertised.
From what I can gather there there is no difference.
My problem is that when coming to a stop the braking is very jerky unless I set the brake controller down very low (3.6v and no boost).
I think this is a bit low based on my previous experience with them.
I have a new car and a new brake controller but the van has not changed.
I have had the brakes on the van checked by the caravan people and they reckon they are OK. They also believe I should use boost of 2 and a higher setting and that the jerky stopping is acceptable. I did not notice this when towing with my previous car where I had it set to 6.3v and boost of 1.
I must admit I suspected the van brakes but they have been checked as said before.
I am concentrating on the controller because it is the new component and should be the easiest to verify, I thought. So I am grasping at straws at the moment to see if there is anything wrong.
If I can verify the controller and the car braking is OK I will take the van to a brake specialist and get them to look more closely at the brakes, the drums may need machining.
I have raised this question on jerky braking before on the site and got some advice but as said this post was to help clarify/verify the controller side.
Richard
FollowupID: 814410
Follow Up By: scandal - Monday, Apr 28, 2014 at 17:53
AHHH, well, I also have a P3, they MUST be mounted a certain way or the inbuilt gyro will be all wrong.
The P3's are not supposed to have any side tilt, you can lift the face up or down to a certain degree, but no side tilt
Some brake controllers can be mounted on any angle but the P3 can't
I've found that with my 1.4ton camper on it needs to be on a high setting, for the brakes to balance up with my Landcruiser.
FollowupID: 814413
Follow Up By: richard - Monday, Apr 28, 2014 at 18:03
Scandal
Yep the P3 can vary in the vertical but as you say not the horizontal.
Mine seems OK, may be not perfect but very close.
Most people do have a higher setting than what I have to use.
Richard
FollowupID: 814414
