Window mount Air Cond in Jayco Swan Outback
Submitted: Sunday, May 11, 2014 at 11:24
ThreadID: 107720 Views:3566 Replies:2 FollowUps:0
What do you all think about installing a window mount air cond unit in a 2007 Jayco Swan Outback.
I was thinking about installing it at the rear or the van under the bed facing towards the front. The unit would be supported by the rear bar and i was thinking about using hi density foam under it as well.
Reply By: SDG - Sunday, May 11, 2014 at 13:44
A friend of mine installed a reverse cycle aircon (big box thing outside, small long rectangle thing inside.) on the front of an Eagle.
Works well.
Obviously need power, and can't run off the 12volt system.
AnswerID: 532264
Reply By: Bob Y. - Qld - Sunday, May 11, 2014 at 14:52
Rob,
From my experience, you'll be very disappointed in the air con performance, if you fit it anywhere near the floor. You would need a fan to try to circulate the air, to make yourself comfortable.
Far better option, as suggested, is to fit a split system. The indoor unit can be fitted as high as possible, and they give a greater variety of fan speeds, from "full noise" to ultra quiet.
"Wall-bangers" are just that, and even low speed on most of them, is about 8 on the Beaufort Scale.
Bob.
AnswerID: 532270
